Standard Claims List For Model Year 2004
1FTSW31P24EE05807 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JUN-2004 21-JUL-2004 121261 USA 0 6P07 010301 * 5420124 * L15 07 10
AWS Claim Key: 1314596 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 09967 - * Name: COURTESY FORD Ph: 864-2889899 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:14-JUL-2004 Doc #:01351001
Cust Comments: DRIVERS SIDE DOOR HARD TO CLOSE , PLEASE ADJUST.
Tech Comments: VERIF CONCERN FOUND DRIVERS SIDE DOOR WAS OUT OF ADJUST ADJU ST OK
1FTSW31P24EE05807 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JUN-2004 21-JUL-2004 121261 USA 5 5I01 110204 3C3Z 3A674 AARM L68 D8 14076
AWS Claim Key: 2732108 Trx Code: E84 Labor Hrs: 3
Dlr Cd-Sub Cd: 09967 - * Name: COURTESY FORD Ph: 864-2889899 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2004 Doc #:01665401
Cust Comments: CUSTOMER STATES POWER STEERNG FLUID LEAKING
Tech Comments: ADD DYE & FILL. RUN & CHECK FOR LEAK AT PS PUMP PRESSURE HOSE. NEEDS HOSE & PUMP. REMOVE FAN SHROUD & FAN FOR ACCESS
1FTSW31P24EE05807 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JUN-2004 21-JUL-2004 121261 USA 5 2G05 031405 * RECAL * D42 82 14076
AWS Claim Key: 2732107 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 09967 - * Name: COURTESY FORD Ph: 864-2889899 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2004 Doc #:01665402
Cust Comments: MILAGE VERY POOR 11MPG
Tech Comments: CHECK FOR CODES PASS. CHECK OASIS. SSM17691 ABOUT FUEL ECON OMY. CHECK BOOST PER SSM OK. CHECK FOR LATEST UPDATE.
1FTSW31P24EE05807 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JUN-2004 21-JUL-2004 121261 USA 11 1H03 030008 4C3Z 9F452 A D36 42 33472
AWS Claim Key: 5475362 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 09967 - * Name: COURTESY FORD Ph: 864-2889899 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2005 Doc #:02125501
Cust Comments: WHEN REACHING SPEEDS OF 70MPH ENGINE STARTS MISSING AND BLOWS BLACK SMOKE
Tech Comments: PERFORM DIAG. WDS CODES P0299,401,404,&405. CHECK OP OF VGT SOLENOID & EBP SENSOR EBP CHANGES WHEN RAISING VGT%. REMOVE EGR VALVE & INSPECT CARBONED UP. REPLACE EGR. REPROGRAM PCM,TCM,&FICM MODULES. 4U7A 12A650 EGD, FILENAME VXBC5N6. ROAD TEST OK. RECHECK FOR CODES PASS.
1FTSW31P24EE05807 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JUN-2004 21-JUL-2004 121261 USA 21 2H01 031202 5C3Z 6C640 AA N11 01 71664
AWS Claim Key: 9115984 Trx Code: E72 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08221 - * Name: STOKES TRAINOR FORD Ph: 864-2889899 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2006 Doc #:02861101
Cust Comments: ENGINE NOISE AND WHISTLE
Tech Comments: DIAGNOSE AND FOUND HOLE IN CAC TUBE UPPER.REPLACE RUBBER TUBE AND ROAD TEST OK
1FTSW31P24EE05807 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-JUN-2004 21-JUL-2004 121261 USA 28 * * * * * * * 94095
AWS Claim Key: 10569669 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 00929 - * Name: VIC BAILEY FORD INC Ph: 864-5853600 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2006 Doc #:03465540
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A94
Tech Comments: RECALL EP SENSOR, CONNECTOR, AND RECALIBRATION
AWS Claim Key: 10569670 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00929 - * Name: VIC BAILEY FORD INC Ph: 864-5853600 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:25-OCT-2006 Doc #:03465541
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: RECALL CUSTOMER ASSURANCE TEST DRIVE REPLACE
