i f anyone can get me the oasis on this 2006 f350 6.0l im looking to buy. I know the 6.0L has problems. please and thank you
Standard Claims List For Model Year 2006
1FTWW31P66EC50943 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-JAN-2006 29-APR-2006 4B7034 CAN 14 2E03 100106 * 9350 * D21 28 34427
AWS Claim Key: 3756918 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: B7232 - * Name: COASTAL FORD SALES LTD Ph: 604-2946525 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:01-JUN-2007 Doc #:296170D
Cust Comments: REPORT ON LEAK IN VENT TUBE FUEL TANK SEEMS TO BE LEAKING
Tech Comments: 55405 SMOKE TEST PARTIAL TANK REMOVAL TO INSPECT LEAK SOURCE COMING FROM SENDING UNIT AND SEAL PO DIAG TECH 6 1.4 MT TIME TO REMOVE SEIZED FUEL TANK MOUNT AND CLAMPPARTS ARRIVED INSTALL NEW SENDER UNIT IN TANK REINSTALL FUEL TANK AND DRIVESHAFT RETEST START OK
1FTWW31P66EC50943 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-JAN-2006 29-APR-2006 4B7034 CAN 15 2E06 100101 6C3Z 9275 BA L69 42 36660
AWS Claim Key: 4024336 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: B7034 - * Name: WATKIN MOTORS Ph: 250-5450611 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:23-JUN-2007 Doc #:21219801
Cust Comments: (L69)FUEL GAUGE INOPERATIVER (DOSENT GO DOWN PAST HALF TANK/WATER I
Tech Comments: VERIFIED CONCERN, REPALCED SENDER AND RETEST(42) E FLOAT ON SENDER TOO SHORT, NOT READING FUEL, REPALCED SENDER
1FTWW31P66EC50943 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 14-JAN-2006 29-APR-2006 4B7034 CAN 31 2E03 03XXXX * 9E527 * D13 42 81567
AWS Claim Key: 7413759 Trx Code: S07 Labor Hrs: 5.9
Dlr Cd-Sub Cd: B7232 - * Name: COASTAL FORD SALES LTD Ph: 604-2946525 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:30-OCT-2008 Doc #:319717A
Cust Comments: DIESEL RUNS ROUGH COLD WAS TOLD LAST VISIT #8 ERROR FIX TODAY AND RECHECK AM
Tech Comments: IDS TEST CODES P0284 P0266. INJECTORS # 2 AND 8 PERFORM OASIS CHECK PERFORM TSB 07 5 4 RECALIBRATE PCM RECOLD START IN AM POWER BALANCE TEST INJECTOR #2 PASS INJ #8 VERY LONG RECOVERY TIME PERFOM TSB 05 16 6 OIL LEVEL INTEGRETY GOOD MAINTAINCE RECORDS OIL CHANGED PERFORM PARTIAL PERFORMANCE SHEET TO DETERMINE BASE ENGINE AND SUBSYSTEMS PASS REPLACE INJECTOR #8 RE COLD START IN AM PASS POW
