5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 16 7P01 * * * * * * 17350
AWS Claim Key: 12064462 Trx Code: 00B40 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2000 Doc #:173456A
Cust Comments: RECALL NOTICE
Tech Comments: 17350 PERFORMED RECALL 00B40,RR SWITCH
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 16 * * * * * * * 17350
AWS Claim Key: 12064463 Trx Code: 00S05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2000 Doc #:173456D
Tech Comments: 17350 PERFORMED RECALL 00S05,INSTALLED TRAILER HITCH HARDWARE OSP BODY UNDERCOATING
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 17 6Y20 * * * * A98 * 17998
AWS Claim Key: 12563258 Trx Code: 00B57 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2000 Doc #:174396C
Cust Comments: 00B57 CONT TIRE CK
Tech Comments: 17998 ALL 5 TIRES ARE NOT AFFECTED BY CONT. RECALL 00B57A
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 27 7F03 011605 XL1Z 17508 AA W06 28 30623
AWS Claim Key: 18179917 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-SEP-2001 Doc #:189108B
Cust Comments: REAR WIPER INOP ADVISE W06
Tech Comments: 30623 28 SHORTED REAR WIPER MOTOR NGS TEST , OPEN CIRCUIT ,REPLACE REAR WIPER MOTOR
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 28 7A01 140101 BXT 65 650 D02 28 31506
AWS Claim Key: 18660056 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2001 Doc #:190125A
Cust Comments: MUST JUMP START BATTERY ADVISE C25
Tech Comments: 31506 VARIFIED CUSTOMER COMPLAINT,RAN CHARGING SYSTEM TEST,BATTERY FAILED LOAD TEST,REPLACED BATTERY AND RETEST,TESTED FINE. ACES CODE HE4AN DTC CODE 9C5 14S
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 31 2D03 030002 2L7Z 6C324 AA E29 42 34721
AWS Claim Key: 19754637 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-JAN-2002 Doc #:193332B
Cust Comments: CHECK ENGINE LIGHT COMES ON RUNNING ROUGH E29
Tech Comments: 34729 ROADTESTED,HIGH IDLE,MIL LAMP ON 15650E1 PASS P0171.P0174 15650E5 15650E18 15650E10 15650E20 15650E24 VISUALLY INSPECTED,CHECKED AND DIAG FOR VACCUME LEAKS,RR PCV HOSE,BROKEN,CLEARED CODES AND ROAD TESTED,OK
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 33 7H01 120301 F7LZ 19703 AA C05 D1 36965
AWS Claim Key: 20252720 Trx Code: E83 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:25-FEB-2002 Doc #:196304A
Cust Comments: CS THE AC IS BLOWING WARM C05
Tech Comments: 36965 COMPORESSOR CHECK FOR LEAKS WITH BLACK LIGHT FOUND AC COMPRESSOR LEAKING REOVERD FREON AND REPLACE LEAKING AC COMPRESSOR EVAC AND RECHARGE CCD1
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 34 7H09 120303 XL7Z 19860 AA E23 D1 39160
AWS Claim Key: 20680892 Trx Code: E83 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-APR-2002 Doc #:199364A
Cust Comments: GREEN FLUID LEAK ADVISE E23
Tech Comments: 39160 EVAP INSPEC FOR GREEN FLUID FOUND EVAP LEAKING RECOVERD FREON AND PRESURE TEST REMOVED CENTER CONSOLE DASH ASSEMBLY AND REPLACED EVAP AND ACCUMALATOR EVAC AND RECHARGE CCD1
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 35 7M72 150108 * 18C830 * A07 42 39305
AWS Claim Key: 21006967 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 67701 - * Name: VISTEON AFTERMARKET-U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2002 Doc #:08198207
Tech Comments: REQUESTING DEALER'S P/A CODE 10570
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 35 7M72 150108 * 18D806 * A07 42 39305
AWS Claim Key: 20731413 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2002 Doc #:199885A
Cust Comments: CD PLAYER SAYS ERROR SUBLET TO GOLDCOAST AUTO A85
Tech Comments: 39305 CD PLAYER SAYS ERROR REMOVE AND REPLACE C D PLAYER OSL TO GOLD COAST RADIO INV 31795. R R CD PLAYER AND INSTALL EXCHANGE UNIT.
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 36 7M72 150102 * 18C830 * A07 42 40975
AWS Claim Key: 21321242 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 67701 - * Name: VISTEON AFTERMARKET-U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2002 Doc #:32166908
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 36 2G02 031403 * 9B989 * E29 28 40975
AWS Claim Key: 21075221 Trx Code: S07 Labor Hrs: 2.9
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2002 Doc #:202475A
Cust Comments: SERVICE ENGINE SOON LIGHT COMES ON AND BUCKS INTO GEAR E29
Tech Comments: 40984 OPEN AT CONNECTOR C120,GY WH WIRE CIRCUIT 355 YKOEOPASSCP0122,KOERPASS,REPAIR CONNECTOR PIN AT C120 GY WH WIRE CIRCUIT 355 PERFORMED SBDS STARTUP,EEC TESTS,DCL DISPLAY, IDLE DATA DISPLAY,PERFORMED BREAKOUT BOX TESTS PERFORMED PINPOINT TESTS,REMOVE PROCESSOR CONNECTOR,PINPOINT TEST TP SENSOR 28
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 36 7M72 150108 * 18D806 * A07 42 40975
AWS Claim Key: 21085066 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2002 Doc #:202475B
Cust Comments: CD PLAYER INOP SEE FILE
Tech Comments: 40984 CD PLAYER INOP REMOVE AND REPLACED C D PLAYER OSL TO GOLD COAST RADIO INV 31891. R R CD PLAYER AND INSTALL EXCHANGE UNIT.
5LMRU27A4XLJ34999 T/B4 L T/WB T/EL T/B AP T/DE T/WC 03-JUN-1999 05-JUL-1999 325160 USA 60 2D03 030002 XL1Z 6C324 EA D36 42 56071
AWS Claim Key: 23242751 Trx Code: P05 Labor Hrs: 2
Dlr Cd-Sub Cd: 10570 - * Name: WALLACE LINCOLN MERCURY Ph: 772-2836000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-MAY-2004 Doc #:239850B
Cust Comments: CUST STATES CAR HAS A MISFIREING AT STOPS ALSO AT IDLE WITHOUT PUTTING INTO GEAR
Tech Comments: 56071 PCV VACUUM LINE LEAKING NKOEOPASSCPASS,KOERPASS,REPL PCV LINE ASSY PERFORMED SBDS STARTUP,EEC TESTS,FINAL QUICK TESTS,DCL DISPLAY,FUEL PRESSURE,RELATIVE INJ FLOW,POWER BALANCE,PINPOINT TESTS 42
OASIS RESULT:
5LMRU27A4XLJ34999
10/09/2007
17:00:04
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1999 NAVIGATOR BODY STYLE
4 DR MPV 4X2 ENGINE
5.4L DOHC 4V EFI
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
H6 ENGINE CALIBRATION
9WCABAFA
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING AIR SUSPENSION COMPRESSOR (5319) FOR NOISE, SEE TSB 05-26-18
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/05/1999 BUILD DATE
06/03/1999 SALE MILEAGE
00030
05S28
PERFORM PRIOR TO VEHICLE DELIVERY: SPEED CONTROL SYSTEM MODIFICATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
| On-line 1878
END OF OASIS REPORT FOR 5LMRU27A4XLJ34999
