Just looking for opinions on this oasis report ...Would this report scare anyone off from purchasing this vehicle ? Carfax is clean and there is a good chance i may be the owner of this truck tomarrow afternoon ...Any opinions good or bad are welcomed ...Thanks in advance ..Ron
Standard Claims List For Model Year 2006
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 24 5C02 050100 * 4602 * K03 D9 45857
AWS Claim Key: 5389303 Trx Code: P05 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2007 Doc #:59833705
Cust Comments: CUSTOMER STATES THE VEH SHIMMIES, VEH FOUND TO HAVE LAUNCH SHUDDER ON ACCEL...WHICH IS PART OF WHAT CUSTOMER IS FEELING (PO5 GOOD WILL...N C PER ED BENTLEY...)
Tech Comments: PERFORMED VIBRATION DIAG .PLACED 3 SHIMS ON CENTER SUPPORT 1 AT A TIME STILL HAD SHUDDER .CHECKED DRIVESHAFT ANGLES OK. CHECKED ALL MOUNTS AND BOLTS .LUBED SLIP YOKE AND INDEXED DRIVESHAFT, 1
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 24 2E03 03XXXX * 9E527 * D13 42 45857
AWS Claim Key: 5389304 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2007 Doc #:59833701
Cust Comments: CUSTOMER STATES THE VEH HAS A DOGGIE CONDITION WHEN COLD, ALSO BLOWS ALOT OF BLACK SMOKE AT THAT TIME. ADVISE.
Tech Comments: ADDRESS CONCERN DIAG PERFORM TSB 07 5 4 REPROGRAM PCM 9E527 42
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 28 2E01 03XXXX 4C3Z 9B246 A D03 42 51007
AWS Claim Key: 6064916 Trx Code: E72 Labor Hrs: 8
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2008 Doc #:61166901
Cust Comments: CUSTOMER STATES THE VEH HAS EXTENDED CRANK AND BLACK SMOKE, SAME AS LAST CONCERN...HARD TO START IF SHUT OFF HOT. HAS TO SET AND COOL TO RE START. ADVISE.
Tech Comments: DEFECTIVE FITTING ASSY CC 01 42 ADDRESS CONCERN DIAG PERFORM TSB 06 17 06 PERFORM HIGH PRESSURE SYSTEM DIAG REPLACE HIGH PRESSURE (STC) FITTING ASSY REASSEMBLE TEST DRIVE M O 51009
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 33 2E06 100106 6C3Z 9G282 AA D13 42 59341
AWS Claim Key: 7155424 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-SEP-2008 Doc #:62576203
Cust Comments: ENGINE RUNS ROUGH SEE ED B.
Tech Comments: DEFECTIVE FUEL PUMP LOW PRESSURE 40 PSI CC 42 DEFECTIVE CAC HOSE CRACKED CC 01 ADDRESS CONCERN DIAG PERFORM DIESEL DIAG PERFORMANCE TEST 1 13 PINPOINT TEST REPLACE DEFECTIVE FUEL PUMP ASSY ONLY 40 PSI . REPLACE CAC HOSE CRACKED SPLIT.REASSEMBLE TEST DRIVE M O 59350
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 36 2E01 03XXXX * 9B246 * D03 42 65536
AWS Claim Key: 7664577 Trx Code: E72 Labor Hrs: 10.9
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:23-DEC-2008 Doc #:63524701
Cust Comments: CUSTOMER STATES THE VEH RUNS ROUGH ESPEC COLD, STARTS HARD EXTENDED CRANK TIMES, BOTH HOT AND COLD, GETTING WORSE. ADV.
Tech Comments: PERF DIAG SHT, LONG CRANK TIME, FOLLOW TSB 08 18 6, AIR CHEC HIGH PRESSURE OIL SYTEM, R I BOTH VALVE COVERS, RETEST, LEAK ON BLOCK OFF TUBE IN PASS OIL RAIL, R R O RING ON TUBE, RETEST, R I OIL RAILS AND CHECK ALL INJECTORS, REASSEMBEL RETEST, TEST DRIVE. M O 65565
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 42 2G05 031405 * RECALEM * D03 04 75777
AWS Claim Key: 8353319 Trx Code: S07 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2009 Doc #:65396001
Cust Comments: CUSTOMER STATES THE VEH STARTS HARD COLD AND HOT, RUNS VERY ROUGH COLD AND IS A DOG UNTILL COMPLETLY WARMED UP...ADVISE.
Tech Comments: M O 75787 PERF DIAG SHT 1 6B,10A 10C, FOLLOW TSB 09 7 11, REFLASH PCM WITH UPDATES, RETEST,TEST DRIVE.
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 44 6Y20 000000 * TAP1 * A99 82 77984
AWS Claim Key: 8576571 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2009 Doc #:65937203
Cust Comments: PROVIDE CUSTOMER WITH RENTAL VEHICLE
Tech Comments: CLAIM FOR TRANSPORTATION ASSISTANCE INVOICE 20353.REF. WARRANTY RO#659372.
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 44 1B03 030204 3C3Z 6A642 CA D13 55 77984
AWS Claim Key: 8594534 Trx Code: E72 Labor Hrs: 12.6
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2009 Doc #:65937201
Cust Comments: CUSTOMER STATES THE VEH RUNS ROUGH AND UNDER POWERED IN AM. ON GOING, SUDDENLY THE VEH STARTED BLOWING LARGE AMTS OF SMOKE FROM THE EXHAUST AND RUNS BADLY. ADVISE.
Tech Comments: CC 55 DEFECTIVE EGR & OIL COOLERS ADDRESS CONCERN DIAG PERFORM TSB 09 8 3 PERFORMING 090803A DIAGNOSING EGR COOLER & COOLING SYSTEM 090803B REPLACING EGR COOLER & OIL COOLER KIT.090803C REPLACE DEGAS BOTTLE 080803E VENT LIQUID FROM CYLS ENGINE HYDROLOCKED 090803G RECONDITION TURBOCHARGER.PERFORM TSB 082301A AS PER HOT LINE TO FLUSH COOLING SYSTEM OF OIL CONTAIMINATION.REPLACE ALL HOSES RADIATOR
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 46 6Y20 000000 * TAP1 * A99 82 83514
AWS Claim Key: 8740981 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2009 Doc #:66681204
Tech Comments: CLAIM FOR TRANSPORTATION ASSISTANCE INVOICE 20792.REF. WARRANTY RO#666812.
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 46 2E03 031403 4C3Z 12B599 ABRM D03 42 83514
AWS Claim Key: 8737708 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2009 Doc #:66681202
Cust Comments: CUSTOMER STATES VEH HAS AN EXTENDED CRANK TIME COLD, HAS TO LET VEH WARM UP FOR 15 20 MINS. BEFORE TRYING TO DRIVE COLD OR CANT PULL OUT ON HWY WITH OUT GETTING RUN OVER. VERY DOGGIE. (CAN
Tech Comments: DEFECTIVE FICM CC 42 ADDRESS CONCERN DIAG PERFORM TSB 08 26 3 PERFORMING DIAG AS PER TSB CODES P0611 REPROGRAM & MONITOR PIDS AS PER TSB FICM PID DROP BELOW 24 VOLTS REPLACE FICM MODULE & PROGRAM TEST DRIVE M O 83520
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 49 6Y20 000001 * DEDUCT * D03 42 90243
AWS Claim Key: 8954361 Trx Code: P18 Labor Hrs: 0
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:25-JAN-2010 Doc #:67550504
Cust Comments: CUSTOMER STATES THIS IS THE SAME CONCERN FROM LAST VISIT, FICM REPLACED.PROGRAM CODE P18,CUDLS#334660500.
Tech Comments: CLP GOODWILL CUSTOMERS POWERTRAIN DEDUCTIBLE FOR EXCESSIVE 6.0L DIESEL ENGINE PROBLEMS.
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 49 1B02 030401 3C3Z 9C065 AA D03 42 90243
AWS Claim Key: 8954362 Trx Code: E72 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:25-JAN-2010 Doc #:67550501
Cust Comments: CUSTOMER STATES THE VEH IS HARD TO START AND RUNS VERY ROUGH WHEN COLD STARTED...SEE HISTORY AND PAUL...ADVISE.
Tech Comments: DEFECTIVE INJECTOR CC 42 LEAKING FUEL REGULATOR GASKET CC D8 ADDRESS CONCERN DIAG PERFORM DIESEL DIAG PERFORMANCE TEST 1 10A CYL 7 LOW ON POWER BALANE TEST WHEN COLD PASSES ALL OTHER TESTS RELATIVE COMPRESSION PASSES CONTACT PRIOR APPROVAL CONTACT ID 103572696 APPROVAL CODE PAA1Z RR RIGHT VALVE COVER REPLACE NO 7 INJECTOR ASSY REASSEMBLE RETEST TEST DRIVE , FOUND FUEL LEAK AT REGULATOR GASKET RE
1FTSW21P96EB95476 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 10-NOV-2005 20-JAN-2006 124461 USA 55 2E03 030402 4C3Z 9E527 BRM D13 42 99933
AWS Claim Key: 9278912 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 04790 - * Name: GARY YEOMANS FORD LINCOLN MERCURY Ph: 386-2536771 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:19-JUL-2010 Doc #:69322701
Cust Comments: CUSTOMER STATES ON COLD START ENGINE RUNS VERY ROUGH RUNS OK WARM
Tech Comments: VERIFIED CUSTOMERS CONCERN, RAN POWER BALANCE AND FOUND NUMBER 6 INJECTOR MISSING ON ACCEL WHEN COLD, CHECKED FUEL PRESSURE, 50 PSI, FUEL RESTRICTION WAS 3 PSI, PERFORMED BUBBLE TEST, NO BUBB REPLACED NUMBER 6 INJECTOR AND RETESTED, EVERYTHING OK AT THIS TIME
Run away. It seems like the early low fuel pressure is making the fuel injectors fail and who knows how many more are going to fail (I'm guessing the remaining 6).
