Standard Claims List For Model Year 2008
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 0 * * * * * * * 32
AWS Claim Key: 37944 Trx Code: 07S49 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 03831 - * Name: MANTILIA MOTORS, INC. Ph: 203-9312800 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2007 Doc #:082808A
Cust Comments: CUST REQ RECALL#07S49
Tech Comments: PERFORMED RECALL FOR UPDATE TO 8C3ADDE
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 6 6Y20 000000 * TAP1 * A99 82 10921
AWS Claim Key: 185826 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 03645 - * Name: MILLER FORD, INC. Ph: 203-3353181 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:08-OCT-2007 Doc #:33591403
Cust Comments: CUSTOMER REQUESTS RENTAL VEHICLE
Tech Comments: FTA $30.00 DAY RENTAL LOANER
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 6 2E03 030008 8C3Z 9A543 A D42 42 10921
AWS Claim Key: 188319 Trx Code: S07 Labor Hrs: 14.3
Dlr Cd-Sub Cd: 03645 - * Name: MILLER FORD, INC. Ph: 203-3353181 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:08-OCT-2007 Doc #:33591401
Cust Comments: CUSTOMOR STATES: CKECK ENGINE LIGHT ON ENGINE HAS NO POWER AFTER 1800 RPM WILL NOT GO OVER 40MPH
Tech Comments: P1285 HIGH PRESSURE PUMP FAILURE PERFORM 6.4L DIESEL DIAG.PER FLOW CHART TRACE TO H.P. PUMP REMOVE CAB AND REPLACE PUMP AND ALL APPROPRIATE HARDWARE NOTE:RADIATOR NEEDED TO BE REMOVED TO ACCESS CAPTIVE NUTS ON FRONT BODY MOUNTS MT REMOVE FRONT BODY BOLTS THAT WERE SPINNING IN CHASSIS
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 12 1F01 030301 8C3Z 8009 B L87 D1 20151
AWS Claim Key: 790720 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 03645 - * Name: MILLER FORD, INC. Ph: 203-3353181 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:30-APR-2008 Doc #:34734001
Cust Comments: C S CK FOR COOLENT LEAK .
Tech Comments: PRESSURE TEST COOLING SYSTEM FOUND RADIATER FDAULTY REPLACED RAD AND REPRESSURE TEST FINE
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 13 2E03 030008 8C3Z 9G756 A E29 42 20521
AWS Claim Key: 1087006 Trx Code: S07 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 03645 - * Name: MILLER FORD, INC. Ph: 203-3353181 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2008 Doc #:34906701
Tech Comments: P0088 FUEL PRESSURE SENSOR PERFORM KOEO KOER FOUND P0088 PERFROM PINPOINT TEST TRACE TO AND REPLACE FUEL PRESSURE SENSOR
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 13 1G01 030008 8C3Z 8592 K L87 D1 20521
AWS Claim Key: 1078105 Trx Code: E84 Labor Hrs: 4
Dlr Cd-Sub Cd: 03645 - * Name: MILLER FORD, INC. Ph: 203-3353181 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2008 Doc #:34906702
Cust Comments: CUSTOMER STATES:THERE IS FLUID LEAKING UNDER FRONT OFF VEHICLE
Tech Comments: COOLANT TUBE FRONT COVER CALLED IN BY CUSTOMER 06 03 08 PRESSURE TEST COOLING SYTEM PIN POINTED LEAK TO COOLANT TUBE FROM FRONT COVER TO REAR OF ENGINE REMOVE TURBO AND INTAKE MANIFOLD FOR ACCESS REPLACE COOLANT TUBE RE TEST OK
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 13 6Y20 000000 * TAP1 * A99 82 20521
AWS Claim Key: 1087005 Trx Code: TAP1 Labor Hrs: 0
Dlr Cd-Sub Cd: 03645 - * Name: MILLER FORD, INC. Ph: 203-3353181 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:02-JUN-2008 Doc #:34906703
Tech Comments: 4 DAYS $120.00 RENTAL LOANER
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 22 7M81 150103 7C3Z 18C804 AB A06 42 34821
AWS Claim Key: 3139135 Trx Code: E83 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 03874 - * Name: STEVENS FORD LINCOLN MERCURY, INC. Ph: 203-8766464 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2009 Doc #:651570C
Cust Comments: CUSTOMER STATES: BASS TUBES KICK ON OFF
Tech Comments: 34821 PERFORMED AUDIO SYSTEM TEST,FOUND SUBWOOFER INOP,REMOVED REAR SEATS, REPLACED SUBWOOFER ASSY.
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 22 2E03 030008 8C3Z 9A543 B E29 42 34821
AWS Claim Key: 3179993 Trx Code: S07 Labor Hrs: 0
Dlr Cd-Sub Cd: 03874 - * Name: STEVENS FORD LINCOLN MERCURY, INC. Ph: 203-8766464 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2009 Doc #:651570A
Cust Comments: CUSTOMER STATES PERFORM SERVICE ENGINE LIGHT DIAGNOSIS
Tech Comments: 34821 ROADTEST,FOUND VEHICLE WITH LOW POWER CK ENGINE LAMP ON,PERFORMED KOEO SELF TEST,CODES P0088,PERFORMED PINPOINT TEST,PERORMED FUEL SYSTEM PRESSURE TEST,PERFORMED FUEL INLET RESTRICTION TEST 6 HG REMOVED FUEL TAN FUEL PICK UP SCREEN,REPLACED LOW PRESSURE FUEL PUMP,PERFORMED ROADTEST,RECHECK FUEL PRESSURE UNDER LOAD,FUEL PRESSURE IS AT 4PSI.VEHICLE HAS
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 22 7T09 191001 8C3Z 15604 A L26 28 34821
AWS Claim Key: 3139134 Trx Code: E84 Labor Hrs: 5
Dlr Cd-Sub Cd: 03874 - * Name: STEVENS FORD LINCOLN MERCURY, INC. Ph: 203-8766464 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2009 Doc #:651570B
Cust Comments: CUSTOMER STATES: LOW BEAMS INOP.
Tech Comments: 34821 TEST POWER GROUNDS TO LOW BEAM HEAD LAMPS,PARTIALLY REMOVED INSRUMENT CLUSTER,TEST MULTI FUNCTION SWITCH,REMOVED FRT HEAD LAMPS AND GRILL, PERFORMED TEST ON SMART JUNCTION BOX,FOUND SMART JUNCTION WITH OPEN CIRCUITS INTERNALLY.REPLACED SMART JUNCTION BOX,REPROGRAMMED PATS KEYS,AN REMOTES,POST REPAIR ROADTEST.
1FTXW43R08EA44870 T/F7 F T/BC T/DB T/E A1 T/BE T/QL 21-FEB-2007 10-MAY-2007 113211 USA 23 1D01 03XXXX 5C3Z 6710 AA L65 D8 35120
AWS Claim Key: 3221911 Trx Code: E84 Labor Hrs: 19.5
Dlr Cd-Sub Cd: 03874 - * Name: STEVENS FORD LINCOLN MERCURY, INC. Ph: 203-8766464 St:CT Ctry Cd: USA Reg Cd: NA Repr Date:20-MAR-2009 Doc #:652791A
Cust Comments: CUSTOMER STATES: CK FOR FLUID LEAKS
Tech Comments: 35120 PERFORMED ENGINE OIL LEAK DIAGNOSIS,FOUND ENGINE BED PAN LEAKING,REMOVED CAB EQUIPPED WITH ADD ON SSS.REPLACED ENGINE BED PAN GASKETS,REPLACED REAR ENGINE COVER GASKET,REINSTALLED CAB,REFILLED WITH COOLANT,BLEED FUEL SYSTEM,RECHARGE A C SYSTEM.POST REPAIR ROADTEST.
08C01
FRONT DRIVERS SEAT BACK INSPECTION AND REPAIR
