Senior Member, on a stick
Just wanted to verify that my OASIS really is clean, so NO hurry on this one. I had it run at the Flatratetech.com website, but they only tell you the high points in their own words, not a complete rundown like you get here.
1FTWW31P95EB15776
:thanks:
OASIS RESULT:
1FTWW31P95EB15776
See bottom of the OASIS result for contact ID
02/07/2006
17:40:30
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/31/2004 BUILD DATE
10/11/2004 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING THROTTLE BODY (-9E926-) SEE TSB 05-14-04
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
05E15
EXHAUST PRESSURE SENSOR REPLACEMENT, ON-BOARD DIAGNOSTIC SYSTEM AND ENGINE CONTR OL MODULES RECALIBRATION
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 FOR DETAILS.
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
11/03/2005
DEALER: Anderson Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 232803 ODOMETER: 035455M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 4947AA PLATE-DIFF CLUTCH 001 4205A 42 DOES NOT OPERATE PROPERLY
XY 75W140QL 004 4205A12B
35498 POSITRAC INOP WHEN COLD REMOVE THRID MEMBER REPLACE P-TRAC PLATES 3642 K03 42
11/02/2005
WARRANTY CLAIM NUMBER: 232697 ODOMETER: 035454M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z78611B09AAC S/BELT FRT/SEAT RETR 001 61108A 41 STICKS/BINDS/GRABS
35454 LEFT FRONT SEAT BELT WONT PULL OUT S25 CHECK SEAT BELT OPERATION R AN D R B PILLAR TRIM REPLACE LEFT FRONT SEAT BELT ASSY BINDS 41
11/02/2005
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 16720SA PLATE,NAME 001 MT16720 81 TARNISHED/FADED
35454 F350 EMBLEM ON RIGHT IS PEELING B66 PLACE F-350 EMBLEM RIGHT FRONT FEN DER 81
10/06/2005
WARRANTY CLAIM NUMBER: 230947 ODOMETER: 030518M
LABOR OP
CONDITION CODE
CONDITION DESC
F65Z 17B676AB CONTROL ASY-O/S MIR 001 17676A 28 OPEN CIRCUIT
30518 MIRRIR INOP MO5 CHECK MIRROR OPERATION TEST MIRROR SWITCH REPLACE OUTS IDE MIRROR SWITYCH OPEN 28
10/04/2005
WARRANTY CLAIM NUMBER: 230751 ODOMETER: 029044M
LABOR OP
CONDITION CODE
CONDITION DESC
PAINT 002 P101 P3 SPRAY PANEL REPAIR (PAINT)
3840700 GATE ASY-TAIL 000 P39
000 P39D
29044 CUST STATES TAILGATE IS PEELING STIPED OFF PEELING PAINT AND REPAINTE D TAILGATE
09/15/2005
WARRANTY CLAIM NUMBER: 229526 ODOMETER: 029037M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 4947AA PLATE-DIFF CLUTCH 001 4205A12B 30 CHAFED,EXCESSIVE WEAR,FRAYED
XL 3 002
XY 75W140QL 004
29043 VERIFIED CONCERN. REAREND CLUTCHES WERE FOUND TO BE SLIPPING. CARRIER WAS REMOVED AND DISASSEMBLED. CLUTCHES WERE THEN REPLACED AND VEHICLE WAS REASSEMBLED AND DRIVEN. NO PROBLEMS WERE FOUND AFTER REPAIR. 30 K03
END OF OASIS REPORT FOR 1FTWW31P95EB15776
1FTWW31P95EB15776 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-OCT-2004 31-DEC-2004 153420 USA 9 5A06 050204 F81Z 4947 AA K03 30 29037
AWS Claim Key: 1940029 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 01743 - * Name: ANDERSON FORD LINCOLN MERCURY OF ST. JOSEPH Ph: 816-2797485 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:15-SEP-2005 Doc #:229526A
Cust Comments: C S THAT THE LIMITED SLIP IS INOP
Tech Comments: 29043 VERIFIED CONCERN. REAREND CLUTCHES WERE FOUND TO BE SLIPPING. CARRIER WAS REMOVED AND DISASSEMBLED. CLUTCHES WERE THEN REPLACED AND VEHICLE WAS REASSEMBLED AND DRIVEN. NO PROBLEMS WERE FOUND AFTER REPAIR. 30 K03
1FTWW31P95EB15776 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-OCT-2004 31-DEC-2004 153420 USA 10 6A06 010303 * 3840700 * F06 P3 29044
AWS Claim Key: 2267541 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 01743 - * Name: ANDERSON FORD LINCOLN MERCURY OF ST. JOSEPH Ph: 816-2797485 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2005 Doc #:230751A
Cust Comments: CUST STATES TAILGATE IS PEELING
Tech Comments: 29044 CUST STATES TAILGATE IS PEELING STIPED OFF PEELING PAINT AND REPAINTED TAILGATE
1FTWW31P95EB15776 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-OCT-2004 31-DEC-2004 153420 USA 10 6X04 01XXXX F65Z 17B676 AB M05 28 30518
AWS Claim Key: 2112168 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01743 - * Name: ANDERSON FORD LINCOLN MERCURY OF ST. JOSEPH Ph: 816-2797485 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2005 Doc #:230947A
Cust Comments: PASS MIRROR WONT MOVE IN
Tech Comments: 30518 MIRRIR INOP MO5 CHECK MIRROR OPERATION TEST MIRROR SWITCH REPLACE OUTSIDE MIRROR SWITYCH OPEN 28
1FTWW31P95EB15776 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-OCT-2004 31-DEC-2004 153420 USA 11 6R01 012001 5C3Z 78611B09 AAC S25 41 35454
AWS Claim Key: 2348966 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 01743 - * Name: ANDERSON FORD LINCOLN MERCURY OF ST. JOSEPH Ph: 816-2797485 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:232697A
Cust Comments: C S THAT THE DRIVERS SEAT BELT PULL OUT SOP
Tech Comments: 35454 LEFT FRONT SEAT BELT WONT PULL OUT S25 CHECK SEAT BELT OPERATION R AND R B PILLAR TRIM REPLACE LEFT FRONT SEAT BELT ASSY BINDS 41
1FTWW31P95EB15776 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-OCT-2004 31-DEC-2004 153420 USA 11 6N04 010802 5C3Z 16720 SA B66 81 35454
AWS Claim Key: 2348967 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01743 - * Name: ANDERSON FORD LINCOLN MERCURY OF ST. JOSEPH Ph: 816-2797485 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2005 Doc #:232697B
Cust Comments: C S THAT THE PAINT ON R F EMBLEM IS PEALING SOP
Tech Comments: 35454 F350 EMBLEM ON RIGHT IS PEELING B66 PLACE F 350 EMBLEM RIGHT FRONT FENDER 81
1FTWW31P95EB15776 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 11-OCT-2004 31-DEC-2004 153420 USA 11 5A06 050204 F81Z 4947 AA K03 42 35455
AWS Claim Key: 2478960 Trx Code: E90 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 01743 - * Name: ANDERSON FORD LINCOLN MERCURY OF ST. JOSEPH Ph: 816-2797485 St:MO Ctry Cd: USA Reg Cd: NA Repr Date:03-NOV-2005 Doc #:232803A
Cust Comments: CUST STATES P T INOP P T
Tech Comments: 35498 POSITRAC INOP WHEN COLD REMOVE THRID MEMBER REPLACE P TRAC PLATES 3642 K03 42
Thanks Squatch!:thanks:
So if I am reading this correctly, I have two outstanding racalibrations to be done? Is there something I need to do to get the notices to come to me? I bought the truck used from a Ford dealer, but I have not received any notices.
There are 3 recalls on your truck, only one has a recalibration in it {05e15} You do not need the notice to get them done just take it to the dealer and have them check for recalls
OK, cool. Thank you again.
