Standard Claims List For Model Year 2007
1FTWW31P17EA86275 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-AUG-2006 05-OCT-2006 4B7207 CAN 2 7C05 180107 FOAZ 14N089 B S56 42 2076
AWS Claim Key: 136349 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: B7207 - * Name: WEST COAST FORD LINCOLN Ph: 604-4655434 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:01-DEC-2006 Doc #:03813501
Cust Comments: CHECK AND REPAIR FOR DRIVERS HEATED SEAT IN OP
Tech Comments: CHECKED BOTH SEAT HEATERS INOP,TRACED TO FUSE 227 REPLACED FUSE,CHECKED FOR SHORTS AT HEATER ELEMENT...OK.RE &RE SEATREMOVED RELAY TESTED FAILED,R
1FTWW31P17EA86275 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-AUG-2006 05-OCT-2006 4B7207 CAN 7 5U01 000502 5C3Z 5D008 A N25 42 4294
AWS Claim Key: 647372 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B7207 - * Name: WEST COAST FORD LINCOLN Ph: 604-4655434 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:10-APR-2007 Doc #:04138201
Cust Comments: CHECK & ADVISE FOR A REAR END SHUDDER WHILE DRIVING BETWEEN 70 75
Tech Comments: ROADTESTED REAR END. SHUTTER HAS TIRE HOP. CHECKED OASIS. TSB 07 5 11.REPLACED STEERING DAMPNER
1FTWW31P17EA86275 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-AUG-2006 05-OCT-2006 4B7207 CAN 24 1F05 030306 4C3Z 8A616 AA E23 42 22023
AWS Claim Key: 3445911 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: B7207 - * Name: WEST COAST FORD LINCOLN Ph: 604-4655434 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:05-SEP-2008 Doc #:05466301
Cust Comments: CUSTOMER REPORTS CLUTCH FAN INOPERATIVE
Tech Comments: COMPLETED TSB 07 3 10
1FTWW31P17EA86275 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-AUG-2006 05-OCT-2006 4B7207 CAN 24 7W15 131302 3F2Z 15K859 BA E40 42 22023
AWS Claim Key: 3445912 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: B7207 - * Name: WEST COAST FORD LINCOLN Ph: 604-4655434 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:05-SEP-2008 Doc #:05466302
Cust Comments: CUSTOMER REPORTS BACK UP SENSORS ARE NOT WORKING PROPERLY SOMETIMES
Tech Comments: CHECK FOR PARK AID SYSTEM GOES OFF FOR NO REASON INTERMITTENTLY. CNF, EEC TEST , NO CODES. MONITEREDPID DATA, RIGHT OUTER SENSOR INOPERATIVE. REPL
1FTWW31P17EA86275 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-AUG-2006 05-OCT-2006 4B7207 CAN 26 7D07 17XXXX * 13465 * L26 42 23825
AWS Claim Key: 3697510 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B7207 - * Name: WEST COAST FORD LINCOLN Ph: 604-4655434 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:20-NOV-2008 Doc #:05628001
Cust Comments: REPLACE BURNT OUT BULBS AS NECESSARY
Tech Comments: RE&RE AND REPLACED R/F PARK LIGHT BULB
1FTWW31P17EA86275 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-AUG-2006 05-OCT-2006 4B7207 CAN 34 5B03 050300 8C3Z 4L616 B L88 42 30152
AWS Claim Key: 4800326 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: B7207 - * Name: WEST COAST FORD LINCOLN Ph: 604-4655434 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:24-JUN-2009 Doc #:06072102
Cust Comments: CHECK FOR OIL LEAK , FRT DIFF
Tech Comments: CHECK AND REPLACE FRONT PINION SEAL, CLEAN OFF EXCESS OIL.
1FTWW31P17EA86275 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-AUG-2006 05-OCT-2006 4B7207 CAN 34 1D01 03XXXX 3C3Z 6701 B L85 42 30152
AWS Claim Key: 4800325 Trx Code: E84 Labor Hrs: 5.2
Dlr Cd-Sub Cd: B7207 - * Name: WEST COAST FORD LINCOLN Ph: 604-4655434 St:BC Ctry Cd: CAN Reg Cd: NA Repr Date:24-JUN-2009 Doc #:06072101
Cust Comments: CHECK AND REPORT FOR OIL LEAK AT BACK OF TRANS BLACK FLUID DRIPPING
Tech Comments: CHECK FOR OIL LEAKS, INSTALL DYE AND BLACK LIGHT TEST, NO OIL AT BACK OF TRANSMISSION, BUT OIL ON BELL HOUSINGTRACE TO REAR MAIN ENGINE OIL SEAL,
