Standard Claims List For Model Year 2003
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 1 5O01 110201 2C3Z 3504 AARM L68 D8 374
AWS Claim Key: 143687 Trx Code: 1 Labor Hrs: 5
Dlr Cd-Sub Cd: 09668 - * Name: GRAND TRAVERSE AUTO COMPANY Ph: 231-9222000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:17-OCT-2002 Doc #:15036101
Tech Comments: FOUND POWER STEERING FLUID LEAKING FROM GEAR BOX.REPLACED GEAR BOX,NEC TO REMOVE COLD SIDE TURBO COOLER HOSE,AIR INTAKE FROM AIRBOX TO TURBO JUST TO GAIN ACCESS TO PS LINES.REPLACED BOX,REASSEMBLED,BLD AIR OUT OF SYSTEM HYDROBOOST.ROADTEST,ALIGN FRONT END.
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 19 7W15 011902 3F2Z 15K859 BA A85 42 15380
AWS Claim Key: 5728914 Trx Code: E83 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 09668 - * Name: GRAND TRAVERSE AUTO COMPANY Ph: 231-9222000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2004 Doc #:19308102
Cust Comments: BACK UP SENSOR SYSTEM FAIL.
Tech Comments: PERFORMED SCAN,CODE C1701.PERFORMED PINPOINT TEST,REPLACED LEFT OUTER SENSOR,RETEST,OK.M TIME DUE TO NO LABOR OP
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 20 1G04 030503 F8TZ 3A733 AA E19 42 15660
AWS Claim Key: 6056233 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 09668 - * Name: GRAND TRAVERSE AUTO COMPANY Ph: 231-9222000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2004 Doc #:19412401
Cust Comments: POWER STEERING NOISE
Tech Comments: DIAG,REPLACED POWER STEERING PULLEY AND SERPENTINE BELT. M TIME DUE TO NO APPLICABLE LABOR OP
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 29 7M01 150101 * 18806 * A16 42 27659
AWS Claim Key: 9667694 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09668 - * Name: GRAND TRAVERSE AUTO COMPANY Ph: 231-9222000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2005 Doc #:21581201
Cust Comments: DELAY IN RADIO WHEN TURNING ON ALL RADIO FUNCTIONS DELAYED
Tech Comments: DIAG RADIO OPERATIONS REMOVEDRADIO AND 6 CDS INSTALL LOANER RADIO SENT ORIGNAL IN FOR REPAIR
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 29 7M01 150101 3C3T 18C815 AA A07 42 27659
AWS Claim Key: 10290858 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:15-FEB-2005 Doc #:62462509
Tech Comments: REQUESTING DEALER'S P/A CODE 09668
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 29 7M01 150101 * 18806 * A16 42 28318
AWS Claim Key: 9798228 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09668 - * Name: GRAND TRAVERSE AUTO COMPANY Ph: 231-9222000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2005 Doc #:21638801
Cust Comments: RADIO WILL NOT EJEC TCD SOP HERE
Tech Comments: RADIO SLOW TO RESPOND INSTALL ORIGINAL REPAIRED RADIO AND VERIFIED REPAIR WORKS GO OD
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 29 5T01 * * * * * * 28318
AWS Claim Key: 9798227 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09668 - * Name: GRAND TRAVERSE AUTO COMPANY Ph: 231-9222000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-FEB-2005 Doc #:21638802
Cust Comments: PERFORM FIELD SERVICE ACTION CAMP 03B03 ADJUSTABLE ACCL. PEDAL SENSOR
Tech Comments: ACTION PER MANUFACTURER NOTIFICATION RFPLACED ACC PEDAL TEST EEC NO CODES
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 31 6P07 01XXXX 2C3Z 7811586 BAB B95 01 30841
AWS Claim Key: 10402152 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 09668 - * Name: GRAND TRAVERSE AUTO COMPANY Ph: 231-9222000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2005 Doc #:22006701
Tech Comments: REPLACED OVERHEAD CONSOLE DOOR,ANOTHER PART ORDERED FOR SAME
1FTNX21F73EA96166 T/F7 F T/BD T/BD T/E A1 T/D8 T/DS 01-OCT-2002 12-OCT-2002 148644 USA 58 2E06 030408 F4TZ 9F538 A E68 D8 70707
AWS Claim Key: 15404971 Trx Code: E72 Labor Hrs: 0
Dlr Cd-Sub Cd: 09668 - * Name: GRAND TRAVERSE AUTO COMPANY Ph: 231-9222000 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:27-JUN-2007 Doc #:27522401
Cust Comments: CUSTOMER STATES DIESEL FUEL LEAKING ALL OVER CHECK ENG LIGHT INT. DIES?
Tech Comments: CYLD 7 INJECTOR SLEEVE LEAKING INSPECT. NO LIGHT. UNABLE TO VERIFY DYING CONCERN. NO CODES. FOUND COOLANT DEGAS BOTTLE OVERFILLED AND LEAKING OUT CAP. FOUND FUEL IN COOLANT. SUSPECT INJECTOR SLEEVE. ADD DYE TO COOLANT AND RUN. REMOVE ALL 8 INJECTORS. PRESSURIZE COOLING SYSTEM AND INSPECT FOR LEAK. FOUND CYLD 7 INJECTOR SLEEVE LEAKING COOLANT. UNABLE TO INSTALL NEW SLEEVE IN VEHICLE.C
