OASIS RESULT:
1FTSW31P34EB15057
04/02/2006
16:34:51
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
4F710N0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/07/2003 BUILD DATE
10/20/2003 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
05E16
ENGINE CONTROL MODULES-RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
02/27/2006
DEALER: Razzari Ford
WARRANTY CLAIM NUMBER: 207171 ODOMETER: 038712M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F25 42 DOES NOT OPERATE PROPERLY
000 9350B
000 12650D30
VERIFIED CONCERN AND FOUND CHECK ENGINE LIGHT ON. CHECKED FOR LATER PCM CALI BRATION AND FOUND NONE AT THIS TIME. KOEO PO404 FOR EGR PERFORMANCE. COMMAND ED VGT UP AND DOWN AND MONITOR REMOVED EGR AND CLEANED PORT FREE OF CARBON B UILD UP FOUND HEAVY BUILD UP ON EGR. REPLACED AND CLEARED CODES. TEST DROVE VEHICLE AND FOUND NO OTHER PROBLEMS AT THIS TIME. THIS VEHICLE WAS Q-C BY RA
12/29/2005
WARRANTY CLAIM NUMBER: 205074 ODOMETER: 035935M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z25022A69AAA PANEL ASY (COWL TOP 001 02344AT 42 DOES NOT OPERATE PROPERLY
REMOVE AND REPLACE DRIVER SIDE LOWER WINDSHIELD SEAL PANEL CENTER PLASTIC BR ACKET IS BROKEN. THIS SERVICE AND REPAIR IS QUALITY CHECK BY KOU VANG
11/07/2005
DEALER: Heritage Ford
WARRANTY CLAIM NUMBER: 074371 ODOMETER: 034754M
LABOR OP
CONDITION CODE
CONDITION DESC
RECALEM ECC PROCESSOR RECAL 000 6005F 04 SOFTWARE REVISION/FLASH MODULE
000 6005F13
000 6005F1
000 6005F2
000 6005F6
000 12650D45
000 6646AC
000 12650D84
000 6005F1X1
000 VERIFY60
CHECK ENGINE LIGHT COMES ON RECALIBRATED PCM
07/18/2005
WARRANTY CLAIM NUMBER: 198817 ODOMETER: 029151M
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
CHECK ENGINE LIGHT AND LACK OF POWER WAS CORRECTED BY RECALLS THAT WERE DONE . EGRTP CONT P0488 KOER P0488 PERFORMED PIN POINT TEST ANDS CHECKED WIRING COMAND EGRTP PLATE OPEN AND REMOVED INNER COOLER TUBE TO INSPECT PLATE MOVEM ENT OK THIS VEHICLE WAS QUAILITY CHECKED BY RAYS
07/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 2560136CAA KIT BK ASY FRT ST 001 64416AA D4 FLAW IN MATERIAL
VERIFIED CUSTOMER COMPLAINT. WILL NEED TO REPLACE ARM REST ASSY. REPLACE A RE REST ASSY AND OK THIS SERVICE AND REPAIR WAS Q-C BY PAO CHANG
07/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 14A099A SHIELD WIRING 001 05S34D
PERFORMED RECALL 05S34 THIS VEHICLE WAS Q-C BY JOSHP
07/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 12224A 3 WAY VACUUM CONNECT 001 05E15D
4C3Z 9J460A SENSOR ASY EGR PR VL 001
PERFORMED RECALL 05E15 THIS VEHICLE WAS Q-C BY JOSHP
06/15/2005
WARRANTY CLAIM NUMBER: 064214 ODOMETER: 026549M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 7210BAB LEVER GEAR SHIFT 001 7210A 42 DOES NOT OPERATE PROPERLY
000 12651D
000 12651D2
INOP REPLACED SHIFTER FOR BAD INTERNAL WIRING
04/23/2005
WARRANTY CLAIM NUMBER: 060582 ODOMETER: 023113M
LABOR OP
CONDITION CODE
CONDITION DESC
3802010 PANEL ASY-COWL TOP 000 17528A D1 POROSITY
000 02010A
COWL ASSY NEED ADJUSTMENT RESEALED COWL ASSY OK AT THIS TIME
END OF OASIS REPORT FOR 1FTSW31P34EB15057
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 6 2G05 031405 * RECAL * E29 42 8294
AWS Claim Key: 795578 Trx Code: 1 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 07941 - * Name: HERITAGE FORD Ph: 209-5295110 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2004 Doc #:03565051
Cust Comments: DIAG FOR CHECK ENGINE LIGHT THAT IS ON
Tech Comments: PERFORMED ENGINE PERFORMANCE TEST 1 18 KOEO PASS CONT PO289 LOW BOOST PERFORMED TEST 1 18 & ALL TEST PASS PID MONITOR VGT & OK WHEN COMMAND UP & DOWN FUEL PRESSURE 60PSI OK RAN OASIS AND FOUND SSM TO REFLASH TO LATEST CALIBRATION SSM 17624 CONTACT ID 212084223 AND CLEARED CODES RECHKED OK AT THIS TIME
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 7 6B07 010102 * 3802010 * B66 33 8749
AWS Claim Key: 1040272 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07941 - * Name: HERITAGE FORD Ph: 209-5295110 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2004 Doc #:03795451
Cust Comments: CUST STATES WINDSHIELD LOWER MOLDING IS COMMING OFF..
Tech Comments: REMOVED COWL RESECURED WATER STRIP OK AT THIS TIME
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 18 6B07 010102 * 3802010 * B66 D1 23113
AWS Claim Key: 5044658 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07941 - * Name: HERITAGE FORD Ph: 209-5295110 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:23-APR-2005 Doc #:06058252
Cust Comments: CUSTOMER STATES THAT FRONT WINDSHIELD MOLDING IS COMMING OFF
Tech Comments: COWL ASSY NEED ADJUSTMENT RESEALED COWL ASSY OK AT THIS TIME
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 20 3N01 110402 5C3Z 7210 BAB P51 42 26549
AWS Claim Key: 5682103 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07941 - * Name: HERITAGE FORD Ph: 209-5295110 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2005 Doc #:06421451
Cust Comments: INSTALL SPO HAND LEVER
Tech Comments: INOP REPLACED SHIFTER FOR BAD INTERNAL WIRING
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 21 * * * * * * * 29151
AWS Claim Key: 6175365 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07920 - * Name: RAZZARI FORD Ph: 209-3833673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:19881701
Cust Comments: CUSTOMER STATES ENGINE LIGHT COMES ON AND VEHICLE LOSES POWE
Tech Comments: CHECK ENGINE LIGHT AND LACK OF POWER WAS CORRECTED BY RECALLS THAT WERE DONE. EGRTP CONT P0488 KOER P0488 PERFORMED PIN POINT TEST ANDS CHECKED WIRING COMAND EGRTP PLATE OPEN AND REMOVED INNER COOLER TUBE TO INSPECT PLATE MOVEMENT OK THIS VEHICLE WAS QUAILITY CHECKED BY RAYS
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 21 6E01 011001 3C3Z 2560136 CAA S50 D4 29151
AWS Claim Key: 6175364 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07920 - * Name: RAZZARI FORD Ph: 209-3833673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:19881702
Tech Comments: VERIFIED CUSTOMER COMPLAINT. WILL NEED TO REPLACE ARM REST ASSY. REPLACE ARE REST ASSY AND OK THIS SERVICE AND REPAIR WAS Q C BY PAO CHANG
AWS Claim Key: 6175363 Trx Code: 05S34 Labor Hrs: 1
Dlr Cd-Sub Cd: 07920 - * Name: RAZZARI FORD Ph: 209-3833673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:19881703
Cust Comments: RECALL 05S34
Tech Comments: PERFORMED RECALL 05S34 THIS VEHICLE WAS Q C BY JOSHP
AWS Claim Key: 6175362 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07920 - * Name: RAZZARI FORD Ph: 209-3833673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:19881704
Cust Comments: RECALL 05E15
Tech Comments: PERFORMED RECALL 05E15 THIS VEHICLE WAS Q C BY JOSHP
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 25 2G05 031405 * RECALEM * E29 04 34754
AWS Claim Key: 8183457 Trx Code: S07 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 07941 - * Name: HERITAGE FORD Ph: 209-5295110 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2005 Doc #:07437153
Cust Comments: CHECK ENGINE LIGHT COMES ON AND OFF
Tech Comments: CHECK ENGINE LIGHT COMES ON RECALIBRATED PCM
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 27 6F49 010102 4C3Z 25022A69 AAA R01 42 35935
AWS Claim Key: 8120178 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07920 - * Name: RAZZARI FORD Ph: 209-3833673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2005 Doc #:20507401
Cust Comments: LOWER WINDSHIELD SEAL SOP IS IN
Tech Comments: REMOVE AND REPLACE DRIVER SIDE LOWER WINDSHIELD SEAL PANEL CENTER PLASTIC BRACKET IS BROKEN. THIS SERVICE AND REPAIR IS QUALITY CHECK BY KOU VANG
1FTSW31P34EB15057 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 20-OCT-2003 07-NOV-2003 172300 USA 29 1H03 030008 4C3Z 9F452 A E29 42 38712
AWS Claim Key: 8676570 Trx Code: S07 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 07920 - * Name: RAZZARI FORD Ph: 209-3833673 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-FEB-2006 Doc #:20717101
Cust Comments: VEHICLE HAS BEEN HERE SEVERAL TIMES FOR CHECK ENGINE LIGHT AND POWER LOSS.REQUESTS DIAGNOSIS
Tech Comments: VERIFIED CONCERN AND FOUND CHECK ENGINE LIGHT ON. CHECKED FOR LATER PCM CALIBRATION AND FOUND NONE AT THIS TIME. KOEO PO404 FOR EGR PERFORMANCE. COMMANDED VGT UP AND DOWN AND MONITOR REMOVED EGR AND CLEANED PORT FREE OF CARBON BUILD UP FOUND HEAVY BUILD UP ON EGR. REPLACED AND CLEARED CODES. TEST DROVE VEHICLE AND FOUND NO OTHER PROBLEMS AT THIS TIME. THIS VEHICLE WAS Q C BY RAYS
Thanks very much
Can you tell if they cleaned or replaced my E.G.R. valve? From reading it, I can't tell if they mean cleaned the housing and replaced E.G.R. or cleaned E.G.R. and put it (old one) back in??? Again, Thanks a bunch.
