Standard Claims List For Model Year 2006
1FTWW31P56EB85597 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-NOV-2005 09-FEB-2006 153507 USA 27 2G02 031403 * 9S428 * E29 V3 34164
AWS Claim Key: 5952141 Trx Code: S07 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 20323 - * Name: POWER FORD NORTH SCOTTSDALE Ph: 480-9913333 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:03-APR-2008 Doc #:070801A
Cust Comments: CHECK ENGINE LIGHT ON
Tech Comments: 34164 9S428 CC 55 PERFORM DIESEL PERF DIAG CK FLUIDS OK EEC TESTS KOER KOEO PASS CONT P0299 RUN PIDS PINPOINT TESTS PERFORM EGR SYSTEM TESTS MAP READING LOW DURING TEST 12 PSI REPAIR MAP SENSOR SUPPLY HOSE LEAKING RETEST OK ROAD TEST OK AT THIS TIME CLEAR CODE RETEST SYSTEM PASS
1FTWW31P56EB85597 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-NOV-2005 09-FEB-2006 153507 USA 27 2H01 030407 5C3Z 6K682 CARM E29 42 34209
AWS Claim Key: 5952142 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 20323 - * Name: POWER FORD NORTH SCOTTSDALE Ph: 480-9913333 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:07-APR-2008 Doc #:070999A
Cust Comments: CHECK ENGINE LIGHT ON ADVISE
Tech Comments: 34209 6K682 CC 42 EEC TESTS KOEO KOER CONT P0299 TEST TURBOCHARGER AS PER TSB 08 04 07F DIASAAEMBLE TO INSPECT ENTIRE TURBO RUSTED INSIDE CAUSING POOR PERFORMANCE REPL TURBOCHARGER ASSY CLEAR CODE ROAD TEST 10 MILES OK AT THIS TIME RETEST KOEO KOER CONT PASS
1FTWW31P56EB85597 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-NOV-2005 09-FEB-2006 153507 USA 54 2E03 0304XX 5C3Z 9C968 CA D42 42 72909
AWS Claim Key: 9248942 Trx Code: E72 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 02969 - * Name: FREMONT MOTOR SHERIDAN, INC. Ph: 307-6744423 St:WY Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2010 Doc #:141752A
Cust Comments: CUSTOMER STATES VEHICLE IDLES ROUGH, ENGINE SURGING.
Tech Comments: VERIFIED CONCERN, RUNS VERY ROUGH, NO POWER. DIESEL PERFORMANCE DIAG. VISUAL OK. FUEL CLEAN, OIL FULL. DTC P0281, PROGRAMMED MODULES PER TSB 09 24 03. STILL RUNNING ROUGH. PINPOINTS P FOR INJECTOR CODE. PRELIMINARY DIAG FOR PINPOINTS P, FUEL CLEAN CETANE 40. INJECTOR ELECTRICAL, NO DTC'S, OIL LEVEL OK, OIL QUALITY GOOD. KOER NO DTC'S PRESENT. P1 YES, DTC P0281, P9 YES, POWER BALANCE LOW ON CYL 7.
