OASIS RESULT:
1FTSW31P64EB44181
See bottom of the OASIS result for contact ID
02/07/2006
17:42:11
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
D1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/14/2003 BUILD DATE
11/03/2003 SALE MILEAGE
00010
ARN MESSAGES
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
CUDL MESSAGES
THIS VEHICLE HAS A CLOSED CUDL CONTACT
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
12/30/2005
DEALER: Phil Long Ford of Chapel Hills
WARRANTY CLAIM NUMBER: 430468 ODOMETER: 035725M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 2A451A PUMP ASY-BRAKE VACUU 001 2219D 42 DOES NOT OPERATE PROPERLY
000 2451A
CHECK VACUME AT PUMP 2PSI, PUMP FAILING REPLACE VACUME PUMP RETEST OK
08/31/2005
WARRANTY CLAIM NUMBER: 419760 ODOMETER: 030369M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15F
REPLACED EBP AND RECALIBRATED MODULES TO (BFG) LEVEL.
08/31/2005
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
COMPLETED TEST DRIVE
06/24/2005
WARRANTY CLAIM NUMBER: 413434 ODOMETER: 027033M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 12224A 3 WAY VACUUM CONNECT 001 05S34G
4C3Z 14A099A SHIELD WIRING 001 05S34E
ADDED WIRING SHIELD AND PIGTAIL TO THE ICP SENSOR
06/01/2005
WARRANTY CLAIM NUMBER: 411295 ODOMETER: 025746M
LABOR OP
CONDITION CODE
CONDITION DESC
OSP 002 6007D D8 FAILED GASKET/SEAL
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 7000A
000 7000A39
1 ADDED OIL DYE AND TEST DROVE USED BLACK LIGHT TO VERIFEY NO EXTERNAL OI L LEAKS, ONLY WETNESS FROM INTERNAL BELL HOUSING, R-R TRANNY AND FLEX PLATE AND REPLACED REAR MAIN SEAL AND INSPECTED FOR SEEPAGE FORM BED PLATE. ONLY L EAK-SEEPAGE FOUND IS FROM REAR MAIN SEAL AREA, HAD ROY K. INSPECT, REPLACED SEAL AND SPEEDY SLEAVE, REINSTALLED
06/01/2005
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F6
000 12650D84
COMPLETED INSPECTIONS AND WDS ECC TESTS KOEO,CLEAR-RETRIVE KOER,INJ. TESTS A ND PID DATA MONITER, FOUND NO DTCS STORED PASSED ALL EGR AND VGT VALVE, BOOS T TEST AND SENSOR READINGS FOUND OLD LEVEL CALIBRATION IN MODULES REPRGRAMED TO (BFE) LEVEL AND TEST DROVE 10 MILES, ALL NORMAL BOOST AT 23 PSI COULD NO T DUPLICATE ANY OTHER CONCERNS.
02/22/2005
WARRANTY CLAIM NUMBER: 402322 ODOMETER: 021683M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 2604810AAD RECEPTACLE-INST PNL 001 01 BROKEN/CRACKED
R&R ASHTRAY, (NO LABOR)
02/22/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z25278D12AAA PNL BDY RR CNR TR 001 29314AR 01 BROKEN/CRACKED
FADED COLOR R&R RR CORNER TRIM PANEL
12/29/2004
WARRANTY CLAIM NUMBER: 397077 ODOMETER: 020380M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 6007D D8 FAILED GASKET/SEAL
3C3Z 6D083AA GASKET-RR COVER 001 MT7000A
OSP 003 7000A39
3C3Z 7E395EA CABLE ASY TRNS SHIFT 001 MT6D083
378941S440 006 7395A
4C3Z 12A690BA WIRING ASY EC SENSOR 001 6007A
4C3Z 12A690AA WIRING ASY EC SENSOR 001 MT6007
3C3Z 6710AA GASKET SET-OIL PAN 002
3C3Z 6020CA GASKET CYL TIMING GE 001
3C3Z 6753AA GASKET OIL LEVEL IND 001
378941S440 006
W300020 001
4C3Z 7A020CA INDICATOR-TRANSOIL L 001
XO 10W30DSD 014
XT 6QSP 001
D7TZ 13466A SMALL BULBS 001
YC3Z 2613229AAA PLATE-DR SCUFF RR 000
F81Z 2604810AAD RECEPTACLE-INST PNL 000
PM 195005920A 001
CK WITH DYE LITE...LEAKING AT REAR MAIN AND REAR ENGINE COVE R TO BLOCK GASK ET. CK RUNOUT (LESS THAN .0005)J, CK R&I TRANNY, R&R REAR MAIN SEAL AND WEAR SLEEVE, M-TIME TO R &R REAR COVER PLATE GASKET.
END OF OASIS REPORT FOR 1FTSW31P64EB44181
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 0 6Y05 000001 * TDRIVE * A9* 82 5
AWS Claim Key: 141427 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03144 - * Name: MEDVED FORD LINCOLN-MERCURY, INC. Ph: 303-6883137 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:14-NOV-2003 Doc #:11658501
Cust Comments: PERFORM 6.0L DIESEL TEST DRIVE
Tech Comments: PERFORMED 6.0 TEST DRIVE 1
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 1 5V09 12XXXX F81Z 2A451 BA N12 42 1498
AWS Claim Key: 203827 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03140 - * Name: PHIL LONG FORD, LLC Ph: 719-6336661 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:11-DEC-2003 Doc #:65445401
Cust Comments: CUSTOMER STATES VACUUM PUMP IS EXCESSIVELY NOISY
Tech Comments: R&R VACUUM PUMP
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 4 1D01 030008 3C3Z 6701 AA L65 D8 5949
AWS Claim Key: 470628 Trx Code: 2 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:28-FEB-2004 Doc #:36839301
Cust Comments: CUSTOMER STATES HE IS SEEING OIL DRIP OFF BELL HOUSING
Tech Comments: ADD DYE, CK WITH DYE LITE...LEAKING FROM REAR MAIN SEAL R&I TRANNY, TO R&R REAR MAIN SEAL, VERIFY NO FURTHER OIL LEAKS AT THIS TIME
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 4 2G05 031405 * RECAL * D03 42 6089
AWS Claim Key: 520315 Trx Code: 2 Labor Hrs: 2
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2004 Doc #:36881101
Cust Comments: CUSTOMER STATES THAT VEHICLE IS HARD TO START COLD , WILL ROMP HARD FOR SEVERAL MINS.
Tech Comments: REPROGRAM WDS TESTED RAN KEY ON ENGINE OFF TEST, KEY ON ENGINE RUNNING TEST AND FOUND NO CODES OR FAULTS. RAN GLOW
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 4 2E02 030008 3C3Z 9N693 GA L65 D8 6517
AWS Claim Key: 520316 Trx Code: 2 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:10-MAR-2004 Doc #:36932401
Cust Comments: CUSTOMER STATES THERE IS AN ENGINE OIL LEAK DRIPPING OFF THE BOTTOM OF BELL HOUSING. HAS HAD REAR MAIN DONE HERE
Tech Comments: ADD DYE, ROAD TEST, PULL TRANNY, CK WITH DYE LITE...TRAIL COMING FROM ABOVE TRANNY AT BACK OF HIGH PRESSURE INJECTION R&R ICP PLUG O RING ON BACK OF ENGINE, THEN RE INSTALL TRANNY REMOVED FOR ACCESS. VERIFY NO FURTHER OIL LEAKS AT
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 5 1D01 030008 3C3Z 6701 AA L65 D8 7143
AWS Claim Key: 625845 Trx Code: 2 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:23-MAR-2004 Doc #:37075301
Cust Comments: CUSTOMER STATES THERE IS OIL LEAKING OFF BELL HOUSING
Tech Comments: DYE TEST...LEAKING AT REAR MAIN SEAL R&R REAR MAIN SEAL
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 7 5G05 040001 * FRONT * H62 W6 10446
AWS Claim Key: 1074944 Trx Code: 2 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:10-JUN-2004 Doc #:37845002
Cust Comments: CUSTOMER STATES THERE IS INSIDE TIRE WEAR IS ALIGN NEEDED?
Tech Comments: SET TOE AND LEVED STEERING WHEEL AND TEST DROVE
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 9 2G05 031405 * RECAL * D21 42 13471
AWS Claim Key: 1503089 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2004 Doc #:38394301
Cust Comments: CUSTOMER STATES VEHICLE WAS COASTING WITH CRUISE CONTROL ON AND ENGINE SPUTTERED THEN STALLED.
Tech Comments: ROAD TEST MONITORING PIDS BOOST OK COULD NOT GET TO ACT UP FOLLOWED DIAG SHEET NOTHING OUT OF SPEC RAN OASIS TSB REPROGRAMMED PCM CALL IF CONCERN CONTINUES
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 14 1D01 03XXXX 3C3Z 6701 AA L65 D8 20380
AWS Claim Key: 3937521 Trx Code: E84 Labor Hrs: 26.9
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2004 Doc #:39707701
Cust Comments: CUST SEES FLUID LEAK DRIPPING DOWN FROM REAR OF ENGINE CUST REQUESTS ALL PERTAINENT MEASUREMENTS BE TAKEN AND
Tech Comments: CK WITH DYE LITE...LEAKING AT REAR MAIN AND REAR ENGINE COVE R TO BLOCK GASKET. CK RUNOUT (LESS THAN .0005)J, CK R&I TRANNY, R&R REAR MAIN SEAL AND WEAR SLEEVE, M TIME TO R &R REAR COVER PLATE GASKET.
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 16 6L05 010506 F81Z 2604810 AAD T52 01 21683
AWS Claim Key: 3985811 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2005 Doc #:40232201
Cust Comments: RR ASHTRAY SOP ARRIVE
Tech Comments: R&R ASHTRAY, (NO LABOR)
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 16 6C06 010507 3C3Z 25278D12 AAA B95 01 21683
AWS Claim Key: 3985810 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:22-FEB-2005 Doc #:40232203
Cust Comments: C PILLAR TRIM SOP ARRIVED
Tech Comments: FADED COLOR R&R RR CORNER TRIM PANEL
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 19 1D01 03XXXX 3C3Z 6701 AA L65 D8 25746
AWS Claim Key: 5794854 Trx Code: E84 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2005 Doc #:41129501
Cust Comments: CUST STATES FLUID LEAK ON REAR OF ENGINE DRIPPING DOWN ON TO TRANS BELL HOUSING
Tech Comments: 1 ADDED OIL DYE AND TEST DROVE USED BLACK LIGHT TO VERIFEY NO EXTERNAL OIL LEAKS, ONLY WETNESS FROM INTERNAL BELL HOUSING, R R TRANNY AND FLEX PLATE AND REPLACED REAR MAIN SEAL AND INSPECTED FOR SEEPAGE FORM BED PLATE. ONLY LEAK SEEPAGE FOUND IS FROM REAR MAIN SEAL AREA, HAD ROY K. INSPECT, REPLACED SEAL AND SPEEDY SLEAVE, REINSTALLED
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 19 2G05 031405 * RECAL * D42 42 25746
AWS Claim Key: 5567726 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:01-JUN-2005 Doc #:41129502
Cust Comments: CUST REPORTS POOR POWER ACCEL WHEN COLD (INTERMIT) OK WHEN WARM
Tech Comments: COMPLETED INSPECTIONS AND WDS ECC TESTS KOEO,CLEAR RETRIVE KOER,INJ. TESTS AND PID DATA MONITER, FOUND NO DTCS STORED PASSED ALL EGR AND VGT VALVE, BOOST TEST AND SENSOR READINGS FOUND OLD LEVEL CALIBRATION IN MODULES REPRGRAMED TO (BFE) LEVEL AND TEST DROVE 10 MILES, ALL NORMAL BOOST AT 23 PSI COULD NOT DUPLICATE ANY OTHER CONCERNS.
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 20 * * * * * * * 27033
AWS Claim Key: 5751560 Trx Code: 05S34 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2005 Doc #:41343401
Cust Comments: RECALL #05S34 WIRING HARNESS
Tech Comments: ADDED WIRING SHIELD AND PIGTAIL TO THE ICP SENSOR
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 22 * * * * * * * 30369
AWS Claim Key: 6813456 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:41976001
Cust Comments: RECALL #05E15 EXHAUST PRESSURE SENSOR REPLACEMENT
Tech Comments: REPLACED EBP AND RECALIBRATED MODULES TO (BFG) LEVEL.
AWS Claim Key: 6813455 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:41976002
Cust Comments: RECALL #59B01 ONE TIME CUST ASSUR TEST DRIVE
Tech Comments: COMPLETED TEST DRIVE
1FTSW31P64EB44181 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-NOV-2003 14-NOV-2003 156461 USA 26 5V09 120307 6C3Z 2A451 A D42 42 35725
AWS Claim Key: 8102108 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 03134 - * Name: PHIL LONG FORD OF CHAPEL HILLS Ph: 719-5722200 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:30-DEC-2005 Doc #:43046801
Cust Comments: CUST STATES VACUUM PUMP RUNS CONTINUALLY
Tech Comments: CHECK VACUME AT PUMP 2PSI, PUMP FAILING REPLACE VACUME PUMP RETEST OK
