Standard Claims List For Model Year 2007
1FTWW32P17EB19421 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 19-OCT-2006 22-MAR-2007 171169 USA 7 1G04 030509 3C2Z 6B209 CA D50 30 18625
AWS Claim Key: 1239532 Trx Code: E84 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD LINCOLN MERCURY Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:01-OCT-2007 Doc #:06082352
Cust Comments: CUSTOMER STATES UNDER LOAD LOUD HIPITCHED WHINE FROM UNDER HOOD AREA
Tech Comments: WATER PUMP PULLEY WEAR,BELT TENSIONER OUT OF ADJUSTMENT DAMAGE BELT FAN SHROUD REMOVE AND INSTALL OR REPLACE
1FTWW32P17EB19421 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 19-OCT-2006 22-MAR-2007 171169 USA 7 7N02 011105 6C3Z 7823394 AA G07 41 18625
AWS Claim Key: 1239533 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD LINCOLN MERCURY Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:01-OCT-2007 Doc #:06082353
Cust Comments: CUSTOMER STATES REAR SLIDING WINDOW INOP
Tech Comments: SLIDER REGULATOR SEIZED BODY CHASSIS ELECTRICAL PIN POINT TEST DIAGNOSIS
1FTWW32P17EB19421 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 19-OCT-2006 22-MAR-2007 171169 USA 7 2E03 030402 4C3Z 9E527 AA D42 42 18625
AWS Claim Key: 1247185 Trx Code: S07 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD LINCOLN MERCURY Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:01-OCT-2007 Doc #:06082351
Cust Comments: CUSTOMER STATES CK ENGINE LIGHT ON RUNS ROUGH NO POWER HESITATES ON ACCELL
Tech Comments: INJ.#7 ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTWW32P17EB19421 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 19-OCT-2006 22-MAR-2007 171169 USA 7 2E03 03XXXX 4C3Z 12B599 AARM D42 42 18693
AWS Claim Key: 1223580 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD LINCOLN MERCURY Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:09-OCT-2007 Doc #:06169051
Cust Comments: RECHECK ENGINE LIGHT ON HESITATES ON ACCELL NO POWER
Tech Comments: FICM INJECTOR DRIVER MODULE (IDM) FUEL INJECTOR CONTROL MODULE (FICM)
1FTWW32P17EB19421 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 19-OCT-2006 22-MAR-2007 171169 USA 8 5A12 0502XX EOTZ 1244 A N50 42 20089
AWS Claim Key: 1320987 Trx Code: E84 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 03915 - * Name: TEAM FORD LINCOLN MERCURY Ph: 702-3955100 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:29-OCT-2007 Doc #:06364451
Cust Comments: CUST STATES THAT THERE IS A GRINDING TYPE NOISE POSS COMING FROM THE FRONT WHEEL AREA WHEN DRIVING ABOUT 30 MPH AND UP CK AND ADV
Tech Comments: NOISE REAR AXLE ASSEMBLY IN VEHICLE DIAGNOSIS
1FTWW32P17EB19421 T/F7 F T/BC T/CD T/B A1 T/BE T/YB 19-OCT-2006 22-MAR-2007 171169 USA 22 5A12 050201 F81Z 1244 BA K02 30 50851
AWS Claim Key: 4068936 Trx Code: E95 Labor Hrs: 8.2
Dlr Cd-Sub Cd: 07869 - * Name: GAUDIN FORD Ph: 702-7312121 St:NV Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2009 Doc #:08497751
Cust Comments: CHECK NOISE IN REAR END AND OIL LEAK ROARING SOUND AT SLOW SPEED SEEMS TO DRAG ON ACELL COLD AM LIKE HOLDING BACK ESP PREM 100.00 DED (VIBRATION 58 MPH ) POWERTRAIN WARRANTY 100.00 D
Tech Comments: CK KIT & SEALS. REPLACED REAR HUB BEARINGS & SEALS, PINION CUPS, BEARINGS & PINION GEAR, SET PINION ROTATIONAL TORQUE TO 40IN LBS, SPEC 25 45IN LBS, CLEANED DIFF CARRIER & REPLACED CLUTCH PACK KIT, RING GEAR & CARRIER BEARINGS, INSTALLED CARRIER, MEASURED RING GEAR BACKLASH .005, RUNOUT .000, REINSTALLED DIFF COVER & AXLES, ADDED FLUID, STEAM CLEANED REAR AXLE & ROAD TESTED NO LONGER HEAR CU
