will somebody please help me out with an oasis report. I would greatly appreciate it! thanks in advance.....
1FTWW33P74ED18497
OASIS RESULT:
1FTWW33P74ED18497
USA
EN
08/04/2010
10:03:20
FCXWS446
© Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
PAINT COLOR
OXFORD WHITE WB C/C-W/B RADIO
AM/FM STRO/CD CHANGER/CLK GROSS VEHICLE WEIGHT
11,500 LB. GVW
AXLE RATIO
4.10 FINAL DRIVE RATIO WHEEL SIZE
6.0 X 16" FORGED ALUM WHL FRONT TIRE
LT235/85R-16E OWL A-T
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
INSTALL 6A642-CA KIT WHEN REPLACING EGR COOLER UNDER 09-08-03
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 09-08-03
TO ENSURE OPTIMUM COOLING SYSTEM PERFORMANCE, REFER TO 09-08-05
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/30/2004 BUILD DATE
04/18/2004 SALE MILEAGE
00025 New Vehicle Base Warranty
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
THE WARRANTY HISTORY IS DOWN AND WILL BE BACK UP ON THE 7TH. REMIND ME AGAIN AND I WILL TRY THEN.
thank you so much. I greatly appreciate it. If you have time i would love to have the warranty history if the system is back up. No rush though. thanks in advance.
Standard Claims List For Model Year 2004
1FTWW33P74ED18497 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-APR-2004 30-MAY-2004 171176 USA 16 * * * * * * * 28049
AWS Claim Key: 6743390 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03789 - * Name: SUPERSTITION FORD, INC. Ph: 480-4742500 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:150477C
Cust Comments: 05E15 C 2004 M Y F250 350 450 550, E, E350 450 V E 6.0L D E E P S R, O B D S
Tech Comments: 28059 3390 RECALL 05E15D 1.30 HRS. PERFORMED RECALL 05E15 REPLACED EP SENSOR AND CONNECTOR.REPCALIBRATED CONTROL MODULES.
1FTWW33P74ED18497 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-APR-2004 30-MAY-2004 171176 USA 16 2A01 031202 * 6C646 * L65 42 28049
AWS Claim Key: 6743391 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03789 - * Name: SUPERSTITION FORD, INC. Ph: 480-4742500 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:150477D
Cust Comments: CUSTOMER STATES THERE IS AN OIL LEAK UNDER THE HOOD
Tech Comments: 28059 3390 6C646 42 VERIFIED OIL ON TO HOOD.CHECKED OASIS FOUND TSB 05 14 8 REPLACED CAC TUBE AND CLAMPS..40HR .
AWS Claim Key: 6743388 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03789 - * Name: SUPERSTITION FORD, INC. Ph: 480-4742500 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:150477A
Cust Comments: S R 05S34: C 2004 M Y F250 350 450 550, E, E350 450 V E 6.0L D F I C M W H R
Tech Comments: 28059 3390 RECALL 05S34F 1.30 HR. PERFORMED RECALL 05S34 INSPECT INSTALL FICM REPAIR KIT AND ICP CONNECTOR KIT.
AWS Claim Key: 6743389 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03789 - * Name: SUPERSTITION FORD, INC. Ph: 480-4742500 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2005 Doc #:150477B
Cust Comments: 59B01 CUSTOMER ASSURANCE TEST DRIVE FOR 05E15 AND OR 05S34
Tech Comments: 28059 3390 RECALL 59B01A .30 HR. PERFORMED RECALL 59B01 CUSTOMER ASSURANCE TEST DRIVE.
1FTWW33P74ED18497 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-APR-2004 30-MAY-2004 171176 USA 29 2E03 030402 4C3Z 9E527 AA D36 42 46003
AWS Claim Key: 10472029 Trx Code: S07 Labor Hrs: 9.4
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:05-OCT-2006 Doc #:938459A
Cust Comments: C S TRUCK SURGES AT HIGHWAY SPEEDS CHECK AND ADVISE
Tech Comments: 46010 CC42 9E527 6F089 9F452 CUST STATES ENGINE SURGES AND RUNS ROUGH TEST DRIVE AND PERFORM ENGINE PERFORMANCE DIAG. PERFORM VISUAL ENGINE CHASSIS INSP. PASS CHECK ENGINE OIL LEVEL PASS CHECK FOR SUFFICENT CLEAN FUEL PASS PERFORM KOEO TEST PASS RETRIEVE CONTINUOUS DTC. P0299 P0404 PERFORM KOEO INJECTOR ELEC. SELF TEST PASS PERFORM POWER BALANCE TEST P0272 P0281 CHECK FOR
1FTWW33P74ED18497 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 18-APR-2004 30-MAY-2004 171176 USA 32 1A03 030008 5C3Z 6009 AARM L87 D1 49627
AWS Claim Key: 11142146 Trx Code: E72 Labor Hrs: 28.7
Dlr Cd-Sub Cd: 03786 - * Name: EARNHARDT FORD SALES COMPANY Ph: 480-8930000 St:AZ Ctry Cd: USA Reg Cd: NA Repr Date:11-JAN-2007 Doc #:947061A
Cust Comments: C S THERE IS A COOLANT LEAK CHECK AND ADVISE
Tech Comments: 49634 CUSTOMER STATES THERE IS A COOLANT LEAK PERFORMED 6.0 PERFORMANCE DIAGNOSTICS PERFORMED VISUAL ENGINE CHASSIS INSPECTION PASS PERFORMED SUFFICIENT CLEAN FUEL TEST PASS PERFORMED ENGINE OIL LEVEL CHECK PASS PERFORMED KOEO ON DEMAND TEST PASS PERFORMED RETRIEVE CONTINUOUS DTCS FOUND P0118 OVERHEAT CODE PERFORMED COOLING SYSTEM PRESSURE TEST AND PERFORMED BLOCK TEST AND FOUND EXHAUST GAS
Reactions: fredwilliamson
