Standard Claims List For Model Year 2005
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 3 7M01 150101 * 18C815 * A16 42 5128
AWS Claim Key: 583183 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00869 - * Name: NORTH COUNTY FORD Ph: 760-9459900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2005 Doc #:366161C
Cust Comments: CUSTOMER STATES THE CD PLAYER SKIPS ON EVERY CD,DIAGNOSE AND ADVISE.
Tech Comments: 5128 0.5 REMOVED CD PLAYER FOR REPAIRS 18805 REINSTALLED AFTER REPAIRS 0.5
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 3 7F01 011601 * 17526 * W05 17 5128
AWS Claim Key: 583182 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00869 - * Name: NORTH COUNTY FORD Ph: 760-9459900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAR-2005 Doc #:366161B
Cust Comments: CUSTOMER STATES THE DRIVERS SIDE WIPER DOES NOT TOUCH THE WINDSHIELD INTERMITTANTLY,DIAGNOSE AND ADVISE.
Tech Comments: 5128 WIPER NOT MAKING FULL CONTACT REQ MT 0.5 AJUSTED WIPER ARM RETESTED OK QUALITY TESTED WORKING AS DESIGNED
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 3 7M01 150101 5L3T 18C815 FH A07 42 5128
AWS Claim Key: 1038999 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-MAR-2005 Doc #:37837400
Tech Comments: REQUESTING DEALER'S P/A CODE 00869
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 7 5V01 060301 5L3Z 1102 AB N27 91 11197
AWS Claim Key: 1348914 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00869 - * Name: NORTH COUNTY FORD Ph: 760-9459900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:376714B
Cust Comments: CUSTOMER STATES THE BRAKES ARE PULSATING WHEN BRAKES ARE APPLIED,DIAGNOSE AND ADVISE.(ALSO SQUEEKING)
Tech Comments: 11197 .7 VERIFIED BRAKE PULSATION DID NOT VERIFY BRAKE SQUEAK MEASURED LATERAL ROTOR RUN OUT .005RF LF .006 ROTOR THICK IS 29.44MM MIN THICK IS 29. 10MM REPLACED BOTH FRONT ROTORS ROAD TESTED BRAKE VIBRATION GONE
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 11 5V03 060302 6L3Z 2B121 A N27 42 17564
AWS Claim Key: 2504787 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 00869 - * Name: NORTH COUNTY FORD Ph: 760-9459900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-NOV-2005 Doc #:387373B
Cust Comments: BRAKE PLUSATE WHEN BRAKING BETWEEN 45 AND 65MPH ALSO BRAKE SQUEAL WHEN COMING TO A STOP SLOW
Tech Comments: 17564 1.4 052119C VERIFIED BRK PULSATION AND SQUEAK REPL FRT CALI PERS PER TSB 05 21 19 MACH ROTORS L FRT 29.9 AFTER MACH 29.5 R FRT 29.9 AFTER 29.5 MM CONCERN REPAIRED
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 15 2E06 100101 5L3Z 9H307 BB L69 42 20729
AWS Claim Key: 3700684 Trx Code: S07 Labor Hrs: 3.4
Dlr Cd-Sub Cd: 00869 - * Name: NORTH COUNTY FORD Ph: 760-9459900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-FEB-2006 Doc #:394940E
Cust Comments: FUEL GAUGE TAKES 1 2 1 HR TO REGISTER FULL AFTER FILL UPS,ADVISE
Tech Comments: 20729 FAULTY FUEL TANK SENDING UNIT 3.8 12651D TO PERFORMED BCE TEST. NO CODES. 12650D80 TO PID MONITOR. ALL PIDS OK 2219D13 TO PERFORMED PIN POINT TESTS. 9275D TO PERFORM SENDING UNIT TEST. 4602A TO REMOVE DRIVESHAFT FOR ACCESS TO TANK 9350E TO RR FUEL PUMP. 9000D TO PERFORMED EVAP TEST TO VERIFY NO LEAKS WERE PRESENT. PASSED 12650DX1 TO PERFORMED BCE RETEST. ALL OK. NO
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 48 * * * * * * * 53511
AWS Claim Key: 10592389 Trx Code: 08S05 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 05476 - * Name: FAIRWAY FORD Ph: 714-5241200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2008 Doc #:09334040
Cust Comments: 08S05 BRAKE BOOSTER VACUUM HOSE REPLACEMENT
Tech Comments: 08S05 RECALL PERFORMED FACTORY RECALL 08S05B
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 48 7N02 011108 6L3Z 1627001 AA G07 42 53511
AWS Claim Key: 10592390 Trx Code: P18 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05476 - * Name: FAIRWAY FORD Ph: 714-5241200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:18-NOV-2008 Doc #:09334052
Cust Comments: CHECK WINDOW IS INOP DRIVERS SIDE REAR
Tech Comments: REGULATOR TRIM PANEL REAR DOOR REMOVE AND INSTALL
1FTPW12535KC34916 T/F6 F T/BC T/AM T/B AJ T/FV T/WX 19-NOV-2004 26-DEC-2004 171079 USA 52 2E03 * * * * * * 55378
AWS Claim Key: 10832136 Trx Code: 07M08 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05476 - * Name: FAIRWAY FORD Ph: 714-5241200 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2009 Doc #:09751251
Cust Comments: SES LIGHT IS ON CK AND ADVISE
Tech Comments: #2 INJECTOR PERFORMED 07M08C REPLACED DEFECTIVE #2 FUEL INJECTOR
