1FTSW31FX3EA27743
09S09
SPEED CONTROL SYSTEM MODIFICATION
Standard Claims List For Model Year 2003
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 12 5V01 0603XX * 1102 * N27 13 12010
AWS Claim Key: 2335071 Trx Code: 1 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2003 Doc #:09021101
Cust Comments: DETERMINE SOURCE OF BRAKE PULSATION, DESCRIBED BY CUSTOMER AS:
Tech Comments: AT THIS TIME WE TURNED ALL ROTORS ON THE VECH AND ALSO CLEANED AND LUBED ALL SLIDERS
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 14 7B02 140201 2C3Z 10346 BARM D02 28 13506
AWS Claim Key: 3073154 Trx Code: 1 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:16-OCT-2003 Doc #:09146201
Cust Comments: CUST STATES THAT DROVE INTO CITY AND HAD TO JUMP START THE VECH WHEN GOT HOME CHARGED BOTH BATTERYS NOW STARTS OK
Tech Comments: WE CHKED THE VECH AND FOUND THAT IT WAS NOT CHARGING AND WE REPLACED THE ALTERNATOR AND THE VECH WAS STILL NOT CHARGING
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 20 5V01 050301 F81Z 1125 DA N27 14 19473
AWS Claim Key: 5534610 Trx Code: E84 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:13-APR-2004 Doc #:09445501
Cust Comments: BRAKES SHAKE VEHICLE WHEN APPLIED (BRAKES HAVE BEEN RESURFACED ONCE)
Tech Comments: INSPECT BRAKES ALL 4 WHEELS AND ROAD TEST, MEASURE ROTOR RUNOUT AND MACHINE BRAKE ROTORS, MEASURE AFTER MACHINING
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 24 5G04 040100 1C3Z 5K483 BB N50 42 23763
AWS Claim Key: 7142469 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:06-AUG-2004 Doc #:09664901
Cust Comments: RATTLE IN FRONT END WHEN DRIVING AND HITTING BUMPS
Tech Comments: ISOLATE RATTLE TO DRIVERS SIDE SWAY BAR LINK AND REPLACE DRIVERS SIDE SWAY BAR LINK
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 27 7D07 170202 E6DZ 13466 B L26 46 29618
AWS Claim Key: 8126708 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:21-OCT-2004 Doc #:09785702
Cust Comments: TECH NOTICED DURING INSPECTION THAT 3RD BRAKE LIGHT WAS INOP
Tech Comments: REPLACED BULB
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 27 7A01 140101 BXT 65 650 C25 42 31158
AWS Claim Key: 8559002 Trx Code: E83 Labor Hrs: 7.1
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2004 Doc #:09812001
Cust Comments: DIAGNOSE NOT START, VEHICLE TURNS OVER BUT WILL NOT FIRE TO START.
Tech Comments: TESTED SYSTEMS, REPLACED HIGH PRESSURE OIL PUMP, TEST DROVE, ALL WORKS PROPERLY NOW
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 31 7B02 140201 2C3Z 10346 BB C26 42 34891
AWS Claim Key: 9674550 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2005 Doc #:09954601
Cust Comments: CUSTOMER WANTS TO TEST LOAD ON ALTERNATOR WITH PLOW ON TO ENSURE IT CAN HANDLE PLOW
Tech Comments: TESTED ALTERNATOR AND FOUND IT WAS ONLY CHARGING AT 11.5V CHECKED ALL WIRING. FOUND ALTERNATOR TO BE FAULTY.
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 31 6P07 010301 * 3820124 * B19 33 34891
AWS Claim Key: 9674549 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2005 Doc #:09954602
Cust Comments: MOULDING ON R F DOOR COMES OFF WHEN YOU PUT WINDOW UP
Tech Comments: FOUND WINDOW MOLDING WAS POPPING OFF. PINCHED MOULDING CLIPS BACK TOGETHER AND REINSTALLED
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 57 1A03 030101 * 6007 * L65 42 51410
AWS Claim Key: 15142310 Trx Code: E72 Labor Hrs: 9.3
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2007 Doc #:11207801
Cust Comments: OIL LEAK FROM UNDER FRONT END OF TRUCK, LOOKS LIKE ENGINE OIL, OIL PAN IS WET
Tech Comments: OIL PAN LEAKING, REMOVED ENGINE FROM TRUCK, AND REPLACED OIL PAN AND DIPSTICK TUBE. ALSO REPLACED OIL JET FOR CYLINDER 7. REINSTALLED ENGINE, FILLED ALL FLUIDS, TEST DROVE AFTER REPAIRS.
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 59 2G02 030008 F81Z 9278 AA G29 42 52463
AWS Claim Key: 15322914 Trx Code: E72 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2007 Doc #:11312601
Cust Comments: CUSTOMER STATES THAT EVERY NOW AND AGAIN OIL GUAGE DROPS TO ZERO AND LIGHT COMES ON
Tech Comments: TEST DROVE, NEVER LOST OIL PRESSURE. REPLACED OIL PRESSURE SWITCH. RETEST DROVE, ALL OKAY NOW
1FTSW31FX3EA27743 T/F7 F T/BC T/CD T/E A1 T/D8 T/DS 07-AUG-2002 23-AUG-2002 113553 USA 70 * * * * * * * 57412
AWS Claim Key: 16008714 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00536 - * Name: DAVE PIRRO FORD, INC. Ph: 315-6853441 St:NY Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2008 Doc #:11806104
Cust Comments: CHECK FOR OPEN RECALLS
Tech Comments: 1 07S57B,0.3 INSPECTED AND REPLACED CAM SENSOR
Reactions: Gumby
