Standard Claims List For Model Year 2006
1FTWW31PX6EA82367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-AUG-2005 26-AUG-2005 121444 USA 1 3A04 070102 3C3Z 7J136 BA G29 42 378
AWS Claim Key: 30507 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 00193 - * Name: JACKY W JONES FORD INC Ph: 706-8652168 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:29-AUG-2005 Doc #:11175902
Cust Comments: CHECK ENGINE LIGHT IS ON CCC E29
Tech Comments: WDS KOEO P0700, P0773, P0770. SSE SOL OPEN. REMOVE TRANS PAN REPLACE SOL. REINSTALL PAN. FILL. CLEAR CODES. RETEST. OK
1FTWW31PX6EA82367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-AUG-2005 26-AUG-2005 121444 USA 1 7H11 120305 * 19972 * C19 33 378
AWS Claim Key: 30508 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 00193 - * Name: JACKY W JONES FORD INC Ph: 706-8652168 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:29-AUG-2005 Doc #:11175901
Cust Comments: AC IS BLOWING OUT DEFROST
Tech Comments: CK A C. CK VAC AND MOTORS. FOUND CONTROL PANEL MAIN VAC HARNESS UNHOOKED AT CONN BEHIND GLOVE BOX. RECONNECT. RETEST STILL NO VENT OPERATION. R R TRIM AND CONTROL PANEL. FOUND VAC LINES PINCHED DUE TO ROUTING. REROUTED VAC LINES. RETEST NORMAL OPERATION
1FTWW31PX6EA82367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-AUG-2005 26-AUG-2005 121444 USA 14 2E01 03XXXX 4C3Z 9B246 A D02 42 34677
AWS Claim Key: 1946497 Trx Code: E84 Labor Hrs: 8
Dlr Cd-Sub Cd: 00193 - * Name: JACKY W JONES FORD INC Ph: 706-8652168 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:02-OCT-2006 Doc #:12393301
Cust Comments: WILL SPIN BUT NOT START WAS TOWED
Tech Comments: TOWED IN SHOP. RETRIEVE AND CLEAR CODES. P2290. MONITOR PIDS ONLY 107PSI OIL PRESSURE. REMOVE BOTH VALVE COVERS. AIR CHECK OIL SYSTEM. FOUND LEAK AT HIGH PRESSURE PUMP FITTING. CHECK OASIS. FOUND TSB 06 17 06. INSTALLED UPDATED BRACKET KIT AND COMPLETE TSB 06 17 06. RETEST. OK
1FTWW31PX6EA82367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-AUG-2005 26-AUG-2005 121444 USA 18 2E03 0304XX 5C3Z 9C968 CA D21 42 45801
AWS Claim Key: 2941821 Trx Code: S07 Labor Hrs: 11.8
Dlr Cd-Sub Cd: 00193 - * Name: JACKY W JONES FORD INC Ph: 706-8652168 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2007 Doc #:12791101
Cust Comments: VEH QUIT WHILE DRIVING WILL NOT START BATT DEAD
Tech Comments: TOWED IN SHOP. RETRIEVE AND CLEAR CODES WITH IDS. ALL PASS. MONITOR ALL PIDS. FOUND ONLY 48PSI ICP. R R BOTH VALVE COVERS. AIR CHECK HIGH PRESSURE OIL SYSTEM. FOUND LEAK AT PUMP. R R TURBO, INTAKE MANIFOLD, AND PUMP COVER. FOUND HOLE IN END OF IPR. REPLACE PUMP AND IPR. REINSTALLED ALL. ROAD TEST. OK. 20 MILES
1FTWW31PX6EA82367 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 17-AUG-2005 26-AUG-2005 121444 USA 19 6Y20 000001 * MISC * A99 82 45805
AWS Claim Key: 2999893 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 00193 - * Name: JACKY W JONES FORD INC Ph: 706-8652168 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2007 Doc #:12828201
Cust Comments: REFUND FOR RENTAL $300.00
Tech Comments: DIESEL RENTAL REFUND
