lookin at purchasing this truck, but would like some background info first...
1FTNW21P23ED23632
thanks!
OASIS RESULT:
1FTNW21P23ED23632
See bottom of the OASIS result for contact ID
03/09/2006
22:03:45
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/19/2003 BUILD DATE
05/08/2003 SALE MILEAGE
00014
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
01/24/2006
DEALER: Victory Ford Lincoln Mercury
WARRANTY CLAIM NUMBER: 085051 ODOMETER: 062440M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6007D 42 DOES NOT OPERATE PROPERLY
OSP 001 9838A
DIAGNOSTIC TEST-FOUND ICP LEAKING R&R ICP
10/04/2005
DEALER: Youngblood Motor Co Inc
WARRANTY CLAIM NUMBER: 033392 ODOMETER: 062070M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9F838EA SENSR ASY F/I TIMING 001 6007D D1 POROSITY
XO 15W405QSD 001 9838A
OSP 002
DIAG AND RR SENSOR LEAKING
10/04/2005
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6C640AA CONNECTION A/C DUCT 001 6646AC 33 LOOSE PART
3C3Z 6K786CA CLAMP AIR COOLING 002
NEC TO REPLACE HOSE CONNECTOR AND CLAMPS
04/15/2005
WARRANTY CLAIM NUMBER: 031031 ODOMETER: 042214M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9G282AF PMP & FLTR ASY-FUL 001 12650D 42 DOES NOT OPERATE PROPERLY
000 12650D80
000 12650D45
000 12650DX1
000 9350E
000 9350B
DIAG AND RR PUMP ASSMBLY RETEST
END OF OASIS REPORT FOR 1FTNW21P23ED23632
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 4 7C05 180107 FOAZ 14N089 A A85 28 7266
AWS Claim Key: 3401089 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:13-NOV-2003 Doc #:07629755
Cust Comments: ON COLD START IN AM NO GAUGES WILL WORK AT TIMES TAKES AS MUCH AS TEN MILES TO START WORKING
Tech Comments: CONTACT INSIDE RELAY BURNED BODY CHASSIS ELECTRIAL (BCE) TEST
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 5 7K11 130101 3C3Z 10849 HA A85 42 9321
AWS Claim Key: 3766313 Trx Code: 1 Labor Hrs: 2.6
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:13-DEC-2003 Doc #:07906551
Cust Comments: CUST STATES GAUGES WILL NOT REGISTER 4OUT OF 10 TIMES FOR APPX 1 TO 10 MINUTES (RADIO,GAS,OIL,DOOR LOCKS,WINDOWS ETC INOP) SEE HISTORY
Tech Comments: INTERNAL FAILURE IN ACC DELAY CKTBODY CHASSIS ELECTRIAL (BCE) TEST CODES B1352, P0460, P052
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 9 2E05 100106 3C3Z 9B249 AB G29 42 15502
AWS Claim Key: 5310567 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 09566 - * Name: LOGANVILLE FORD Ph: 770-5549994 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2004 Doc #:01070152
Cust Comments: CUSTOMER STATES WATER IN FUEL LIGHT COMES ON AND STAYS ON
Tech Comments: REPLACED FUEL MODULE
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 9 2E05 100103 * 9155 * D21 53 15502
AWS Claim Key: 5310568 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 09566 - * Name: LOGANVILLE FORD Ph: 770-5549994 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2004 Doc #:01070153
Cust Comments: C S SURGING WHILE DRIVING
Tech Comments: ENGINE STALLS, REPLACED FUEL FILTER AT CUSTOMER PAY, CHECK FUEL FILTER ON FRAME, FUEL FOAMY, R&R FUEL MODULE, RUN PUMP AND WATCH FUEL, PUMPS RUNS BUT NOT MUCH FUEL PRESSURE, CLEAN OUT LINES TO TANK, RETRY FUEL PUMP, RESTORE FITTINGS AND LINES AND RETEST OK
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 12 2G01 031401 * 12B599 * D02 X1 23927
AWS Claim Key: 6896769 Trx Code: S07 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 00402 - * Name: AKINS FORD CORPORATION Ph: 770-8679136 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:09-JUL-2004 Doc #:09990451
Cust Comments: CUST STATES WILL NOT START SEE HISTORY (NEED CORRECT MILEAGE) ADVISE
Tech Comments: PERFORM DIESEL DIAG, PASS CODES, CLUSTER INOP & WONT SPIN OVER, ONLY CLICKING FROM RELAY. UNABLE TO SELF TEST, CHECK FUSES. FUSE 116 30 AMP BLOWN, TEST HARNESS, SHORTED TO GROUND, CKT 1044 WH YE. REPOSITION DEGAS BOTTLE, REMOVE TURBL INLET HOSES, & FICM. HARNESS SHORTED ON INTAKE BOLT. REPAIR & REPOSITION HARNESS. RETEST CKT, OK. INSTALL FUSE, CLUSTER WORKS & STARTS. CLEAR CODES, P0102, P0
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 22 2E06 100106 3C3Z 9G282 AF D02 42 42214
AWS Claim Key: 10539420 Trx Code: E72 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 00342 - * Name: YOUNGBLOOD MOTOR CO INC Ph: 706-3422242 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:15-APR-2005 Doc #:031031A
Tech Comments: DIAG AND RR PUMP ASSMBLY RETEST
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 27 2E06 030008 3C3Z 9F838 EA L65 D1 62070
AWS Claim Key: 12217780 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 00342 - * Name: YOUNGBLOOD MOTOR CO INC Ph: 706-3422242 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2005 Doc #:033392A
Tech Comments: DIAG AND RR SENSOR LEAKING
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 27 2H01 031202 5C3Z 6C640 AA D50 33 62070
AWS Claim Key: 12217781 Trx Code: E72 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00342 - * Name: YOUNGBLOOD MOTOR CO INC Ph: 706-3422242 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2005 Doc #:033392B
Tech Comments: NEC TO REPLACE HOSE CONNECTOR AND CLAMPS
1FTNW21P23ED23632 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 08-MAY-2003 19-JUL-2003 121480 USA 31 2E06 030008 3C3Z 9F838 EA L65 42 62440
AWS Claim Key: 13046341 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02779 - * Name: VICTORY FORD LINCOLN MERCURY Ph: 706-8821401 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:24-JAN-2006 Doc #:08505151
Cust Comments: CUSTOMER STATES ENGINE HAS OIL LEAK ADVISE
Tech Comments: DIAGNOSTIC TEST FOUND ICP LEAKING R&R ICP
