Could someone run me an oasis on IFTWW32FWXED32404 Thanks.
alright I will have to take a look at it tomorrow
1FTWW32F4XED32404 is the correct VIN
OASIS RESULT:
1FTWW32F4XED32404
06/02/2006
10:48:39
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1999 F-SERIES BODY STYLE
F-350 CREW CAB 4X2 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
F2 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/15/1999 BUILD DATE
01/28/1999 SALE MILEAGE
00035
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTWW32F4XED32404
Standard Claims List For Model Year 1999
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 16 5O01 110200 * 3504 * A99 D8 21876
AWS Claim Key: 9244116 Trx Code: E84 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:25-MAY-2000 Doc #:01233851
Cust Comments: CUST STS POWER STEERING IS NOISEY
Tech Comments: PERFORM P S PRESSURE TEST, R&R STEERING GEAR, OHAUL STEERING GEAR, LEAKING AT TOP SECTOR COVER
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 16 5A01 0502XX * 4209 * A99 42 21876
AWS Claim Key: 9244117 Trx Code: E84 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:25-MAY-2000 Doc #:01233854
Cust Comments: CUST STS LOW SPEEDES AND TURNNING REAR END SHUTTERS
Tech Comments: REAR END DIAGNOSIS, CHATTERING ON TURNS, INSPECT CLUTCHES O.K.,, REPLACE FLUID AND ADD FRICTION MODIFIER TO CURE CHATTER DANA90
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 16 7H01 120301 F77Z 19703 AB A99 D8 21876
AWS Claim Key: 9244118 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:25-MAY-2000 Doc #:01233855
Cust Comments: CUST STS WHEN A C BLOWS WARM INTER WHEN DRIVING OR SEAST AT LT
Tech Comments: LEAK TEST A C REPLACE LEAKING COMP
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 20 * * * * * * * 28636
AWS Claim Key: 11677321 Trx Code: 99S32 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 305-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2000 Doc #:045596A
Cust Comments: RECALL 99S32 FUEL SYSTEM INTEGRITY
Tech Comments: INSTALLED AND REPOSITIONED STRAPS PER RECALL
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 20 3A08 070105 XL3Z 7902 DARM N18 42 28636
AWS Claim Key: 11677322 Trx Code: E84 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 305-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2000 Doc #:045596D
Cust Comments: N18, TRANSMISSION MAKING RATTLING NOISE
Tech Comments: DID EEC TESTS AND DROPPED PAN. REMOVED TRANS AN D REPLACED TORQUE CONVERTER. FLUSHED ALL LINES AND ROAD TESTED. M TIME TO INSTALL TRANS AUX CO OLER AND FILTER AND TO WELD DIPSTICK TUBE BRACK ET BACK ONTO BELL HOUSING AND PAINT
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 20 7V01 180101 * 14289 * L26 X1 28636
AWS Claim Key: 11677323 Trx Code: E83 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 305-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2000 Doc #:045596E
Cust Comments: L26, LEFT FRONT HEADLIGHT BULB WILL NOT STAY IN LAMP ASSY
Tech Comments: CHECKED WIRES, FOUND BOTH HEADLIGHT CONNECTORS BURNED OUT. TESTED CIRCUITS AND FOUND GROUND G1 00 WAS ATTACHED TO PAINTED SURFACE AND HAD POOR CONNECTION. M TIME TO REPAIR GROUND AND REPLAC E BOTH HEADLIGHT CONNECTORS AND TEST SWITCHA DN WIRING
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 20 7S22 1801XX * 14A067 * L26 X2 28636
AWS Claim Key: 11705898 Trx Code: E83 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 305-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2000 Doc #:045596F
Cust Comments: L26, REVERSE LIGHTS INOP
Tech Comments: TESTED FOR NO BACKUP LIGHTS. CHECKED BULBS, FOU ND NO POWER TO CONNECTORS. TESTED WIRING, FOUND LOOSE TERMINAL IN FUSE BOX AT C243. WIRE WAS P OORL CRIMPED AND LOOSE. HAD TO REMOVE COMPLETE FUSE PANEL TO ACCESS CONNECTOR AND REINSTALL WI RE CORRECGTLY. M TIME OP
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 20 6E01 011001 F81Z 2560136 AAF B95 01 28636
AWS Claim Key: 11677324 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 305-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-2000 Doc #:045596G
Cust Comments: B95, COIN HOLDER ASSY SPRUNG APART
Tech Comments: COIN HOLDER BROKEN AND PARTS LOST. NECESSARY TO REPLACE ENTIRE CENTER CONSOLE CONTAINING COIN HOLDER
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 20 2J88 000615 * NPF * D50 82 28662
AWS Claim Key: 11822385 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04901 - * Name: ATLANTIC FORD TRUCK SALES, INC Ph: 305-5878220 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2000 Doc #:045690A
Cust Comments: D50, ENGINE INTERMITTENTLY SHAKING AT LOW RPM UNDER LIGHT ACCELLERATION
Tech Comments: HOOKED UP TEST EQUIMENT, MONITORED SENSORS AND CHECKED FLUIDS. NO CODES. ROAD TSTED TRUCK 20 M ILES, CANNOT DUPLICATE COMPLAINT. RELEASED TRUC K TO OWNER, NO PROBLEM FOUND
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 27 5N01 110301 F7UZ 3E651 AB A99 42 35978
AWS Claim Key: 15829695 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04977 - * Name: WORLD FORD/PEMBROKE PINES Ph: 954-4437000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2001 Doc #:05605351
Cust Comments: CUST STS WHEN HITTING BUMPS IN THE ROAD, STEERING SHAKES
Tech Comments: ROAD TESTED THE VEHICLE FOUND THE WHEEL SHAKING AT 60 MPH AND UP.. INSTALLED A STEERING DAMPNER KIT.. ROAD TESTED OK..
1FTWW32F4XED32404 T/F7 F T/BC T/CD T/B A1 T/DE T/DS 28-JAN-1999 15-FEB-1999 124008 USA 55 7C01 170503 XF1Z 14018 BA L19 42 49581
AWS Claim Key: 22505237 Trx Code: E81 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 03853 - * Name: PARK FORD Ph: 330-6336222 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2003 Doc #:20517701
Cust Comments: INTERIOR LIGHTS COME ON, AND ALSO DOOR AJAR WARNING LIGHT COMING ON $75.00
Tech Comments: CHECK OUT AND REPLACED BOTH FRONT DOOR AJAR SWTICHES T25026
Looks like a bunch of simple complaints and nothing major so I guess I might as well throw a low bid on this just to see if I can get it really cheap... Thanks a lot
