OASIS RESULT:
1FTNX21P13EB63711
06/05/2006
22:13:22
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/04/2003 BUILD DATE
12/20/2002 SALE MILEAGE
04372
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
CUDL MESSAGES
THIS VEHICLE HAS A CLOSED CUDL CONTACT
WARNING MESSAGES
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
08/18/2005
DEALER: Nichols Ford
WARRANTY CLAIM NUMBER: 439245 ODOMETER: 035509M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9G270AA CAP F/T SENDR O/L TU 001 9155A 01 BROKEN/CRACKED
35509 9155A-.5 .5 REPLACE FUEL FILTER CAP CRACKED AND LEAKING
08/18/2005
LABOR OP
CONDITION CODE
CONDITION DESC
YN 19 042 19700A 42 DOES NOT OPERATE PROPERLY
19703 COMPRESSOR-A/C 000 19700A27
35509 19700A-.6 19700A27-.6 1.2 CK AC SYSTEM CK CORE LOW ON FREON AND RECHA RGE
END OF OASIS REPORT FOR 1FTNX21P13EB63711
Standard Claims List For Model Year 2003
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 1 2A01 031201 3C3Z 9N622 AA A85 42 5
AWS Claim Key: 1494387 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 06336 - * Name: MIKE BROWN FORD Ph: 817-2795900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2003 Doc #:02531101
Cust Comments: AIR FILTER MINDER LIGHT IS ON IN DASH BOARD
Tech Comments: CKED OUT AND VERIFY CONCERN REPLACE AIR MINDER AT AIR FILTER HOUSING
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 1 2E01 * * * * * * 5
AWS Claim Key: 1494388 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06336 - * Name: MIKE BROWN FORD Ph: 817-2795900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2003 Doc #:02531102
Cust Comments: RECALL 03B05, INJECTION CONTROL PRESSURE SENSOR REPLACEMENT
Tech Comments: INSTALL INJECTION CONTROL PRESSURE SENSOR AS PER RECALL
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 1 2G05 * * * * * * 5
AWS Claim Key: 1494389 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06336 - * Name: MIKE BROWN FORD Ph: 817-2795900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-JUN-2003 Doc #:02531103
Cust Comments: RECALL 03B06, COLD OPERATION CALIBRATION PRODUCT ENHANCEMENT
Tech Comments: PERFORM COLD OPERATION CALIBRATION AS PER RECALL
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 1 6Y05 000001 * TDRIVE * A9* 82 6
AWS Claim Key: 1551931 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06336 - * Name: MIKE BROWN FORD Ph: 817-2795900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2003 Doc #:02588001
Tech Comments: ROAD TEST 6.0
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 1 * * * * * * * 6
AWS Claim Key: 1646983 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 06336 - * Name: MIKE BROWN FORD Ph: 817-2795900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-JUN-2003 Doc #:02588002
Cust Comments: 57B98 OIL CHANGE
Tech Comments: PERFORM OIL AND FILTER CHANGE
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 8 5K04 040402 * ALBAL * N25 D9 10826
AWS Claim Key: 4061672 Trx Code: 1 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 06336 - * Name: MIKE BROWN FORD Ph: 817-2795900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JAN-2004 Doc #:013558B
Cust Comments: CUSTOMER STATES TRUCK SHAKES AT HIGHWAY SPEEDS
Tech Comments: CKED OUT AND ROAD TEST TO VERIFY CONCERN PERFORM VIB HARSHNESS DIAG CHECK LATERAL RUN OUT ON WHEELS ROAD FORCE BALANCE 4 TIRES AND WHEELS ROAD TEST OK
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 15 * * * * * * * 20648
AWS Claim Key: 7401635 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 06336 - * Name: MIKE BROWN FORD Ph: 817-2795900 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2004 Doc #:019465A
Cust Comments: RECALL 04S15 NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
Tech Comments: INSTALL NEG GOUND CABLE BOLT TO BLOCK AS PER RECALL
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 27 5S01 030008 3C3Z 9G270 AA L10 01 35509
AWS Claim Key: 11776917 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02511 - * Name: NICHOLS FORD Ph: 817-5353673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:439245A
Cust Comments: CUST STATES SECONDARY FUEL CAP CRACKED
Tech Comments: 35509 9155A .5 .5 REPLACE FUEL FILTER CAP CRACKED AND LEAKING
1FTNX21P13EB63711 T/F7 F T/BD T/BD T/E A1 T/BE T/YB 20-DEC-2002 04-JUN-2003 152412 USA 27 7H01 120301 * 19703 * C02 42 35509
AWS Claim Key: 11776918 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02511 - * Name: NICHOLS FORD Ph: 817-5353673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-AUG-2005 Doc #:439245B
Cust Comments: CUST STATES AC NOT GETTING COLD IN HEAT OF DAY
Tech Comments: 35509 19700A .6 19700A27 .6 1.2 CK AC SYSTEM CK CORE LOW ON FREON AND RECHARGE
