Thank You:
1FTSW21P85EA50279
OASIS RESULT:
1FTSW21P85EA50279
07/25/2006
17:19:25
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
5F710C0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/03/2005 BUILD DATE
09/21/2004 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-14-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
BEFORE REPLACING FS-10 A/C COMPRESSOR (19703), PLEASE SEE TSB 06-04-09
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
03/28/2006
DEALER: Woltz & Wind Ford, Inc.
WARRANTY CLAIM NUMBER: 081476 ODOMETER: 016583M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
TECH 244 PERFORM RECALL 05E15
03/28/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
TECH 244 PERFORM RECALL 05B32
03/28/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
TECH 244 PERFORM CUSTOMER ASSURANCE ROADTEST AS PER 59B01
12/19/2005
WARRANTY CLAIM NUMBER: 075453 ODOMETER: 013820M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 8A080A COOLANT O/FLO BOTTLE 001 8080A D8 FAILED GASKET/SEAL
F6DZ 8100A CAP ASY RADIATOR 001 8100A
TECH 124 VERIFY CONCERN VISUALLY CK FOR LEAKS CONDITION OF COOLANT RESERVOIR SHOWS SIGNS OF LEAKAGE TAT CAP TEST PER TSB 05-26-23 PRESS TEST SSY LEAKING AT CAP BOTTLE AREA REPLACE CAP AND RESERVOIR RETEST OK TEST EGR COOLER OK R OADTEST WITH DATALOGGER AT PIDS IN SPEC BOOST AT 25 .5 PSI AND COOLANT PRESS NEVER OVER 15 PSI OK
END OF OASIS REPORT FOR 1FTSW21P85EA50279
Standard Claims List For Model Year 2005
1FTSW21P85EA50279 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2004 03-JAN-2005 144021 USA 0 * * * * * * * 10
AWS Claim Key: 261246 Trx Code: TDE Labor Hrs: 2.9
Dlr Cd-Sub Cd: 07467 - * Name: WOLTZ & WIND FORD, INC. Ph: 412-2794551 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:09-DEC-2004 Doc #:04947451
Cust Comments: TRANSPORTATION CLAIM CC 919 B L FSSL2218938 DELIVERY DATE 12 9 04 04 12 1 REAR BUMPER HAS SCRATCH ABOUT 1
Tech Comments: TECH 600 BODY SHOP KIRK TAYLOR REMOVE REAR BUMPER REFINISH REAR BUMPER DUE TO SCRATCHED REINSTALL REAR BUMPER TRANSPORTATION DAMAGE CC 919 B L FSS2218938 DELIVERY DATE 12 09 2004 DAMAGE CODE 04 12 1 REAR BUMPER HAS SCRATCH ABOUT ONE INCH
1FTSW21P85EA50279 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2004 03-JAN-2005 144021 USA 12 1F06 030304 6C3Z 8A080 A L87 D8 13820
AWS Claim Key: 3051425 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 07467 - * Name: WOLTZ & WIND FORD, INC. Ph: 412-2794551 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:19-DEC-2005 Doc #:07545351
Cust Comments: CUST STATES WHEN UNDERLOAD IS BLOWING COOLANT APPEARS OILY
Tech Comments: TECH 124 VERIFY CONCERN VISUALLY CK FOR LEAKS CONDITION OF COOLANT RESERVOIR SHOWS SIGNS OF LEAKAGE TAT CAP TEST PER TSB 05 26 23 PRESS TEST SSY LEAKING AT CAP BOTTLE AREA REPLACE CAP AND RESERVOIR RETEST OK TEST EGR COOLER OK ROADTEST WITH DATALOGGER AT PIDS IN SPEC BOOST AT 25 .5 PSI AND COOLANT PRESS NEVER OVER 15 PSI OK
1FTSW21P85EA50279 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-SEP-2004 03-JAN-2005 144021 USA 15 * * * * * * * 16583
AWS Claim Key: 4178394 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 07467 - * Name: WOLTZ & WIND FORD, INC. Ph: 412-2794551 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2006 Doc #:08147651
Cust Comments: RECALL ON EMMISIONS 05E15 DROP CUST STTES ROUGH IDLE AND BLOWS SMOKE WHEN STARTED
Tech Comments: TECH 244 PERFORM RECALL 05E15
AWS Claim Key: 4178395 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07467 - * Name: WOLTZ & WIND FORD, INC. Ph: 412-2794551 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2006 Doc #:08147652
Cust Comments: 05B32
Tech Comments: TECH 244 PERFORM RECALL 05B32
AWS Claim Key: 4178396 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07467 - * Name: WOLTZ & WIND FORD, INC. Ph: 412-2794551 St:pA Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2006 Doc #:08147653
Cust Comments: 59B01
Tech Comments: TECH 244 PERFORM CUSTOMER ASSURANCE ROADTEST AS PER 59B01
