looking to buy. would like oasis 1st thank you
1FMSU43P43ED06134
I wonder if she has got the whistler in her?
Anyone:shrug: please before she sells!!!
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 6 2G05 031405 * RECAL * D41 42 11896
AWS Claim Key: 4273476 Trx Code: 1 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-JAN-2004 Doc #:05678603
Cust Comments: RPMS, CUST. REPORTS WHEN SHE STOPS RPMS GO TO 2 OR HIGHER
Tech Comments: WRONG PROGRAM PERF DIESEL DIAG,KOEO TEST,KOEO INJECTOR TEST,KOER TEST, LOW IDLE TEST,CRANCASE TEST,EXHAUST TEST,BOOST TEST,FUEL
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 6 6N01 010805 1C7Z 16038 AAA B64 02 12294
AWS Claim Key: 4359702 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2004 Doc #:05741001
Cust Comments: CUSTOMER STATES THAT THE RIGHT FRONT MOLDING AROUND THE WHEEL AND THE RIGHT FRONT DOOR MOLDING ARE BAD, THE DOOR
Tech Comments: CC 02 INSTALLED SOP PARTS ORDERED LAST VISIT. REMOVED RIGHT SIDE RUNNING BOARD TO ACCESS RIGHT FRONT WHEEL LIP MOLDING. REMOV
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 7 2G01 * * * * * * 13000
AWS Claim Key: 5035562 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:06320801
Cust Comments: PERFORM RECALL 03L12 EECI LABEL
Tech Comments: RECALL PERFORMED RECALL 03L12, INSTALLED NEW VECI LABEL.
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 7 * * * * * * * 13000
AWS Claim Key: 5035561 Trx Code: 03E04 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-MAR-2004 Doc #:06320802
Cust Comments: PERFORM RECALL 03E04 VECI LABEL
Tech Comments: PERFORMED RECALL 03E04, REMOVED LABEL.
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 9 7H09 120303 XL1Z 19860 AA C01 D1 16810
AWS Claim Key: 5746078 Trx Code: E83 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2004 Doc #:06753401
Cust Comments: C01 CUSTOMER STATES THAT THE A C IS NOT BLOWING COLD.
Tech Comments: D1 PARTIAL CHARGE AND LEAK TEST,RECOVER 134A,VACCUUM TEST REAR EVAP.,R&R 3RD ROW SEAT FOR ACCESS,R&R RUGHT INT.
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 12 6R01 012001 YC3Z 78613E58 AAA S25 42 22121
AWS Claim Key: 7190930 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-JUL-2004 Doc #:07958401
Cust Comments: S25 CUSTOMER STATES THAT THE REAR MIDDLE SEAT BLET, IN THE SECOND ROW, COILS UNDER THE SEAT WHEN RETRACTING
Tech Comments: FP78613E58,CC42 CHECK AND FOUND WHEN THE MIDDLE ROW CENTER SEATBELT IS RELEASED THE BELT RETRACTS DOWN INSIDE OF THE BELT HOLDER.
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 15 1H03 030008 3C3Z 9F452 AC D11 42 27315
AWS Claim Key: 8114737 Trx Code: E84 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:21-OCT-2004 Doc #:08999401
Cust Comments: D11 CUSTOMER STATES THAT AT A STOP, THE IDLE REVED UP BY ITSELF TOO MUCH.
Tech Comments: DEFECTIVE EGR VALVE PERF DIESEL DIAG,KOEO TEST,INJECTOR TEST,KOER TEST,LOW IDLE TEST,CRANCASE TEST,EXHAUST TEST,BOOST TEST,FUEL CONTAMINATIO
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 34 2E06 030008 3C3Z 9E527 AE D50 42 49791
AWS Claim Key: 13807442 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2006 Doc #:15560801
Cust Comments: D50 C.S. ROUGH IDLE, ALSO WHEN ON A STOP WITH FOOT ON THE BRAKE VEH WANTS TO TAKE OFF
Tech Comments: FP 9E527 CC 42 POWERTRAIN ENG PERF DIAG. KOEO,PAS. KOEO INJ,PASS. KOER,PASS. KOEC P0272. LOW IDLE STAB,675 PSI. CRANKCASE 1IN. EXHAUST TEST 36 PSI. BOOST TEST,15 PSI. FUEL CONT,CLEAN FUEL. INTAKE RST NONE. FUEL PRESS,57 PSI. F.P. INLET RST,ZERO. EGR TEST,0.89V FUEL AERATION,CLEAR. INJ PRESS REG,24%. ENHANCE POWER BALANC DETERMINED THAT INJ 4,6 ARE DROPPING,INJ CUT OFF TEST
1FMSU43P43ED06134 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 15-APR-2003 24-AUG-2003 124225 USA 34 * * * * * * * 49791
AWS Claim Key: 13807441 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2006 Doc #:15560803
Cust Comments: PERFORM RECALL 59B01 CUST ASSURANCE TEST DRIVE
Tech Comments: ROAD TEST, NO ENG PERF CONCERN WAS FOUND
AWS Claim Key: 13807440 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04924 - * Name: TROPICAL FORD INC Ph: 407-8513800 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2006 Doc #:15560804
Cust Comments: PERFORM DIESEL REPAIR PER RECALL 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: RECALL REFLASHED PCM AS PEE RECALL
Looks to be a problem child. I thinkI am better off lettin this one go.
