OASIS RESULT:
1FTSX31F0XEB85768
07/28/2006
00:00:24
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1999 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
D1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/30/1998 BUILD DATE
09/01/1998 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FTSX31F0XEB85768
Standard Claims List For Model Year 1999
1FTSX31F0XEB85768 T/F7 F T/BD T/CD T/E A1 T/DE T/DS 01-SEP-1998 30-SEP-1998 4B7196 CAN 12 1A88 000615 * NPF * N11 82 5286
AWS Claim Key: 4481345 Trx Code: 2 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 08736 - * Name: HARRIS FORD, INC. Ph: 425-7744141 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:20-SEP-1999 Doc #:04194503
Tech Comments: RD TEST. CITY HIGHWAY.SOME TIRE WHINE AND NORMAL ENGINE TURBO NOISE HEARD ONLY. CONNECT NGS AND RUN QUICK NPF TESTED TURBO AND PULLEYS ENGINE MOUNTS
1FTSX31F0XEB85768 T/F7 F T/BD T/CD T/E A1 T/DE T/DS 01-SEP-1998 30-SEP-1998 4B7196 CAN 20 * * * * * * * 7447
AWS Claim Key: 8921751 Trx Code: 99S32 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08736 - * Name: HARRIS FORD, INC. Ph: 425-7744141 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2000 Doc #:05659501
1FTSX31F0XEB85768 T/F7 F T/BD T/CD T/E A1 T/DE T/DS 01-SEP-1998 30-SEP-1998 4B7196 CAN 20 6F17 011101 * 3803100 * R21 D8 7447
AWS Claim Key: 8921750 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 08736 - * Name: HARRIS FORD, INC. Ph: 425-7744141 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:10-MAY-2000 Doc #:05659502
Tech Comments: RUBBER MOLDING ORDERED ROAD TEST NOISE SOUNDED LIKE COMEING FROM TOP OF WIND SHIELD AREA RE TEST WITH TECH 395 AND A STETHASCOPE FIND WIND NOISE
1FTSX31F0XEB85768 T/F7 F T/BD T/CD T/E A1 T/DE T/DS 01-SEP-1998 30-SEP-1998 4B7196 CAN 24 6F18 010702 F81Z 2851222 AA R22 D8 8573
AWS Claim Key: 11372777 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08736 - * Name: HARRIS FORD, INC. Ph: 425-7744141 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:06-SEP-2000 Doc #:06416101
Cust Comments: INSTALL SO WEATHER STRIP FOR WIND NOISE RIGHT SIDE
Tech Comments: I9NSTALLED SO WEATHER STRIP
1FTSX31F0XEB85768 T/F7 F T/BD T/CD T/E A1 T/DE T/DS 01-SEP-1998 30-SEP-1998 4B7196 CAN 24 6X04 010902 YC3Z 17683 FAA M05 13 8573
AWS Claim Key: 11372776 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08736 - * Name: HARRIS FORD, INC. Ph: 425-7744141 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:06-SEP-2000 Doc #:06416102
Tech Comments: VERIFY INSTALLED NEW MIRROR HAD TO REMOVE DOOR PANNEL AND SPEAKER TO ACCESS CONNECTOR FOR MIRROR REPLACED DR DOOR MIRROR FOR VIBRATION SMALL MIRROR IS MOUNTED IN FIXED POSS AT FACTORY
1FTSX31F0XEB85768 T/F7 F T/BD T/CD T/E A1 T/DE T/DS 01-SEP-1998 30-SEP-1998 4B7196 CAN 34 2A01 031202 YC3Z 6C646 AA N12 07 11821
AWS Claim Key: 16920400 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03242 - * Name: STETSON FORD INC Ph: 406-9325732 St:MT Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2001 Doc #:01194251
Cust Comments: CK ENGINE NOISE AND LOSS OF POWER HISSING
Tech Comments: DIAGNOSED FOUND INTER COOLER TUBE BLOWN OFF, RAN OASIS AND REPLACED AS PER
1FTSX31F0XEB85768 T/F7 F T/BD T/CD T/E A1 T/DE T/DS 01-SEP-1998 30-SEP-1998 4B7196 CAN 35 5Y02 060302 YC3Z 2200 AA N27 42 15979
AWS Claim Key: 17513551 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08736 - * Name: HARRIS FORD, INC. Ph: 425-7744141 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:06-AUG-2001 Doc #:08424703
Tech Comments: ROAD TEST AND TRY TO VERIFY A CONCERN. ON PANIC STOPS THE BRAKES APPEAR TO BE WORKING AS DESIGNED. THE PEDAL WILL INSTALL THE NEW REAR PADS AND RETEST. OK AT THIS TIME
1FTSX31F0XEB85768 T/F7 F T/BD T/CD T/E A1 T/DE T/DS 01-SEP-1998 30-SEP-1998 4B7196 CAN 35 6P06 010303 * 3840700 * B05 41 15979
AWS Claim Key: 17513550 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08736 - * Name: HARRIS FORD, INC. Ph: 425-7744141 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:06-AUG-2001 Doc #:08424707
Tech Comments: ADJUSTED TAILGATE AS NEEDED
