Smokin
I would like to see if you can pull this one 1LNHM87A01Y667668
OASIS RESULT:
1LNHM87A01Y667668
07/30/2006
21:13:29
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 LINCOLN LS BODY STYLE
4 DR SEDAN ENGINE
3.9L DOHC EFI
TRANSMISSION
AUTOMATIC AXLE CODE
29 ENGINE CALIBRATION
1LQ18S0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/09/2001 BUILD DATE
01/18/2001 SALE MILEAGE
00820
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0875 - EXPIRED
STANDARD DEDUCTIBLE: 0
OWNER NAME: VALUED LINCOLN CUSTOMER
OPTIONS:
EXPIRATION DATE: 11/09/2004
DISTANCE: 40,000
RENTAL: 0 UP TO 0 DAYS
TOWING: 0
CONTRACT SOLD BY: USA 48440
ESP CONTRACT START DATE: 07/09/2001
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1LNHM87A01Y667668
Standard Claims List For Model Year 2001
1LNHM87A01Y667668 C/LQ L C/FC C/XQ C/B BA C/TD C/WH 18-JAN-2001 09-JUL-2001 367170 USA 4 6Y05 000001 * MAINT * A9* 82 5613
AWS Claim Key: 4598465 Trx Code: 0875S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 11408 - * Name: WEST POINT LINCOLN-MERCURY Ph: 713-5292611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2001 Doc #:34469701
Cust Comments: 5000 MILE MAINTENANCE. LUBE, CHANGE OIL & FILTER. MULTI POINT INSPECTION. ROTATE TIRES.LQCM PROGRAM QCL
Tech Comments: 5,000 MILE SERVICE MULTIPOINT INSPECTION CHANGE OIL & FILTER LUBE ROTATE TIRES PER SCHEDULE MAINTENANCE LINCOLN QUALITY CARE MAINTENANCE PROGRAM QCL
1LNHM87A01Y667668 C/LQ L C/FC C/XQ C/B BA C/TD C/WH 18-JAN-2001 09-JUL-2001 367170 USA 6 6Y05 000001 * MAINT * A9* 82 10235
AWS Claim Key: 6051493 Trx Code: 0875S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 11408 - * Name: WEST POINT LINCOLN-MERCURY Ph: 713-5292611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN-2002 Doc #:35213901
Cust Comments: 10,000 MILE MAINTENANCE LUBE, OIL FILTER,MULTIPOINT INSPECTION,ROTATE TIRES LQCMPROGRAM QCL
Tech Comments: 10,000 MILE SERVICE MULTIPOINT INSPECTION CHANGE OIL & FILTER LUBE ROTATE TIRES PER SCHEDULE MAINTENANCE LINCOLN QUALITY CARE MAINTENANCE PROGRAM QCL
1LNHM87A01Y667668 C/LQ L C/FC C/XQ C/B BA C/TD C/WH 18-JAN-2001 09-JUL-2001 367170 USA 9 6Y05 000001 * MAINT * A9* 82 15685
AWS Claim Key: 7668060 Trx Code: 0875S Labor Hrs: 1.6
Dlr Cd-Sub Cd: 11408 - * Name: WEST POINT LINCOLN-MERCURY Ph: 713-5292611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2002 Doc #:35985801
Cust Comments: 15,000 MILE MAINTENANCE CHANGE ENGINE OIL AND REPLACE OIL FILTER; INSPECT BRAKE PADS, ROTORS, BRAKE LINES & HOSES AND PARKING BRAKE MULTIPOINT INSPECTION
Tech Comments: 15,000 MILE SERVICE MULTIPOINT INSPECTION CHANGE OIL & FILTER INSPECT BRAKES COOLING SYSTEM STEERING LINKAGE SUSPENSION ROTATE TIRES REPLACE CABIN FLTER PER SCHEDULE MAINTENANCE LINCOLN QUALITY CARE MAINTENANCE PROGRAM QCL
1LNHM87A01Y667668 C/LQ L C/FC C/XQ C/B BA C/TD C/WH 18-JAN-2001 09-JUL-2001 367170 USA 9 7P01 110501 XW4Z 13K359 AA W03 42 15685
AWS Claim Key: 7668059 Trx Code: E83 Labor Hrs: 2
Dlr Cd-Sub Cd: 11408 - * Name: WEST POINT LINCOLN-MERCURY Ph: 713-5292611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2002 Doc #:35985802
Cust Comments: CUSTOMER STATES RIGHT WINDSHIELD WASHER QUIT SPRAYING AND NOW, BOTH WINDSHIELD WASHERS INOP. WONT SPRAY
Tech Comments: BOTH WINDSHIELD WASHERS INOPERATIVE DISABLE AIR BAG SYSTEM CHECK SWITCH OPERATION REPLACE MULTIFUNCTION SWITCH INOPERATIVE
1LNHM87A01Y667668 C/LQ L C/FC C/XQ C/B BA C/TD C/WH 18-JAN-2001 09-JUL-2001 367170 USA 12 6Y05 000001 * MAINT * A9* 82 20696
AWS Claim Key: 9419426 Trx Code: 0875S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 11408 - * Name: WEST POINT LINCOLN-MERCURY Ph: 713-5292611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2002 Doc #:36809901
Cust Comments: 20,000 MILE MAINTENANCE LUBE OIL FILTER MULTIPOINT INSPECTION ROTATE TIRES LQCM PROGRAM QCL
Tech Comments: 20,000 MILE SERVICE MULTIPOINT SERVICE CHANGE OIL AND FILTER LUBE ROTATE TIRES PER SCHEDULE MAINTENANCE LINCOLN QUALITY CARE MAINTENANCE PROGRAM QCL
1LNHM87A01Y667668 C/LQ L C/FC C/XQ C/B BA C/TD C/WH 18-JAN-2001 09-JUL-2001 367170 USA 15 6Y05 000001 * MAINT * A9* 82 25546
AWS Claim Key: 10690672 Trx Code: 0875S Labor Hrs: 0.9
Dlr Cd-Sub Cd: 11408 - * Name: WEST POINT LINCOLN-MERCURY Ph: 713-5292611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-SEP-2002 Doc #:37539501
Cust Comments: 25,000 MILE MAINTENANCE LUBE OIL AND FILTER MULTIPOINT INSPECTION TIRE ROTATION LQCM PROGRAM QCL
Tech Comments: 25,000 MILE SERVICE MULTIPOINT INSPECTION CHANGE OIL AND FILTER LUBE ROTATE TIRES PER SCHEDULE MAINTENANCE LINCOLN QUALITY CARE MAINTENANCE PROGRAM QCL
1LNHM87A01Y667668 C/LQ L C/FC C/XQ C/B BA C/TD C/WH 18-JAN-2001 09-JUL-2001 367170 USA 17 6Y05 000001 * MAINT * A9* 82 31572
AWS Claim Key: 11855851 Trx Code: 0875S Labor Hrs: 1.9
Dlr Cd-Sub Cd: 11408 - * Name: WEST POINT LINCOLN-MERCURY Ph: 713-5292611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-NOV-2002 Doc #:38227901
Cust Comments: 30,000 MILE MAINTENANCE CHANGE OIL FILTER,INSPEC.COMPLETE BRAKE SYSTEM,INSPEC. ENGINE COOLING SYSTEM AND HOSES,INSPEC.EXHAUST SYSTEM
Tech Comments: 30,000 MILE SERVICE MULTIPOINT INSPECTION CHANGE OIL AND FILTER INSPECT BRAKES COOLING SYSTEM EXHAUST SYSTEM HEAT SHIELDS STEERING LINKAGE SUSPENSION REPLACE AIR FILTER CABIN FILTER DRAIN PLUG SERVICE AUTOMATIC TRANSMISSION ROTATE TIRES PER SCHEDULE MAINTENANCE LINCOLN QUALITY CARE MAINTENANCE PROGRAM PCM
1LNHM87A01Y667668 C/LQ L C/FC C/XQ C/B BA C/TD C/WH 18-JAN-2001 09-JUL-2001 367170 USA 34 6H08 011404 3W4Z 5427009 AA G07 01 43761
AWS Claim Key: 17848051 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 11408 - * Name: WEST POINT LINCOLN-MERCURY Ph: 713-5292611 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2004 Doc #:42396501
Cust Comments: LR PWR. WINDOW INOPERATIVE
Tech Comments: LEFT REAR WINDOW INOPERATIVE ACCESS LEFT REAR DOOR TRIM PANEL REPLACE LEFT REAR DOOR WINDOW REGULATOR BROKEN
