1FTSW21P85EB91434
thanks a lot!
OASIS RESULT:
1FTSW21P85EB91434
09/11/2006
21:32:25
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/30/2005 BUILD DATE
01/04/2005 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE ADDRESSING VEHICLE VIBRATION CONCERNS, SEE TSB 05-26-24
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
06/14/2006
DEALER: Cogswell Motors, Inc.
WARRANTY CLAIM NUMBER: 226409 ODOMETER: 036704M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9433AA GASKET SET-MANIFOLD 001 6005E D8 FAILED GASKET/SEAL
5C3Z 9G805B KIT-CVR PMP FUEL 001 6005E2
W301727 OIL PUMP FITTING 001 6005E3
5C3Z 9C854A BLK-FUL DSTR 001 6005E4
W301970 001 6584AL
3C3Z 9N693DA RING-SEALING 001 9543A
3C3Z 6840AA GASKET-OIL FILLER AD 001 MT9543
3C3Z 6A831AA GSKT-OIL FLTR ELEM S 001
3C3Z 6766BA CAP ASY OIL FILLER 001
5C3Z 9G804B O-RING KIT 001
TA 29 MOTORCRAFT BATTERY 001
3C3Z 9J469AA SEAL EGR TUBE 001
36712 ATTEMPT TO START ENGINE, NORMAL CRANK NO START. EEC TEST KOEC P2291, KOEO PASS, KOEO INJ. SELF TEST PASS. MONITOR PIDS WHILE CRANKING ICP 300 P SI, TOO LOW TO START. REMOVE LEFT VALVE COVER, PRESSURIZE HIGH PRESSURE OIL SYSTEM WITH SHOP AIR, CLOSE IPR, AUDIBLE LEAK COMING FROM HIGH PRESSURE P UMP AREA. REMOVE HIGH PRESSURE PUMP, FOUND HIGH PRESSURE COUPLING SEPERATED
03/23/2006
DEALER: Whitson-Morgan Motor Company,
WARRANTY CLAIM NUMBER: 023332 ODOMETER: 029671M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6700BA OIL SEAL CYL FRT COV 001 6700A 42 DOES NOT OPERATE PROPERLY
W301970 001
INSPECT VEHICLE, OIL IS 2 QUARTS LOW, P2291, ICP LOW, CHANGED OIL AND FILTE R CLEARED CODES ENGING WILL CRANK NO START HAS NO HI PRESSURE ICP TEST INTER NAL LEAKAGE R AND I INTAKE MANIFOLD AND TURBO AND HI PRESSURE OIL PUMP REPLA CED HI PRESSURE OIL PUMP COUPLER ASSEMBLY
01/12/2006
WARRANTY CLAIM NUMBER: 021947 ODOMETER: 022740M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
REPLACED EBP SENSOR AND REPROGRAMMED PCM/FICM/TCM WITH PART 5U7A 12A650CUB PER RECALL
01/12/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
PERFORMED RECALL THEN ROAD TESTED
01/12/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
INSTALLED LABEL PER RECALL
12/02/2005
WARRANTY CLAIM NUMBER: 020971 ODOMETER: 018084M
LABOR OP
CONDITION CODE
CONDITION DESC
15K866 MODULE - PARKING AID 000 MT15D866 28 OPEN CIRCUIT
F2UZ 14526P FUSE-ELECTRICAL CIRC 002
PERFORMED DIAG TEST C1706 DID PP TEST B CIRCUIT 1439, 1440 ADN 1442 OPEN, TESTED CIRCUITS FROM SENSOR TO PAR KING AID MODULE CHECKED AT CONNECTORS C4041 AT C300 AT C211 AT C4001 FOUND O PEN IN ALL THREE CIRCUITS 1431, 1440, 1442 NEAR REAR OF TRUCK REPAIRED OPEN IN CIRCUITS RETEST REINSTALLED ALL TRIM AND WIRING HOLDERS AND CONNECTORS F
END OF OASIS REPORT FOR 1FTSW21P85EB91434
