My Girlfriend is looking at a 2004 Explorer, can I get a report please??:deal:
VIN: 1FMZU73K94ZA15031
:thanks:
Here you go.
OASIS RESULT:
1FMZU73K94ZA15031
09/25/2006
07:10:29
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 EXPLORER 4DR BODY STYLE
4 DR XLT MPV 4X4 ENGINE
4.0 SOHC - FLEX FUEL
TRANSMISSION
5R55S AUTOMATIC AXLE CODE
45 ENGINE CALIBRATION
4U51AF0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/28/2003 BUILD DATE
09/19/2003 SALE MILEAGE
00074
ARN MESSAGES
BEFORE DIAGNOSING SHIFT/SOLENOID RELATED CONCERNS, SEE TSB 05-21-08
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 3 2G05 031405 * RECALEM * D03 42 3738
AWS Claim Key: 455865 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 00847 - * Name: FORD OF KIRKLAND, INC. Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:24-FEB-2004 Doc #:36617601
Cust Comments: CUSTOMER STATES SINCE NEW IN DEC ON 4 OCCASIONS THE VEH WOULD CRANK BUT NO START RADOMLY.
Tech Comments: ROAD TEST PERFORM DIAGNOSIS,NO CODES STORED IN MEMORY. MONITOR DATA,REPRGRAM PROCESSOR,RETEST OK.
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 6 2G05 031405 * RECALEM * D02 42 6852
AWS Claim Key: 1231470 Trx Code: S07 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00847 - * Name: FORD OF KIRKLAND, INC. Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-2004 Doc #:37149801
Cust Comments: CUSTOMER STATES THE ENG RANDOMLY WILL CRANK BUT NO START.
Tech Comments: TESTED SEVERAL TIMES,UNABLE TO VERIFY CONCERN PERFORM DIAGNOSIS,FOUND SERVICE MESSAGE FOR UPDATED PROGRAM,REPROGRAM RETEST OK.
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 6 7G09 12XXXX * 19893 * N33 07 6852
AWS Claim Key: 1209455 Trx Code: 2 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 00847 - * Name: FORD OF KIRKLAND, INC. Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-2004 Doc #:37149802
Cust Comments: CUSTOMER STATES THERE IS A GIRGGLING NOISE FROM DASH WHEN ENG IS RUNNING ALSO OCCURS AFTER TURNING OFF
Tech Comments: ROAD TEST VERIFIED NOISE FROM MISSROUTED WIRE HARNESS RUBBING ON AIR DUCTS. REPOSITIONED HARNESS AND DUCTS. OK NOW
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 6 6L04 170501 4L1Z 11661 AA A85 01 6852
AWS Claim Key: 1209454 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00847 - * Name: FORD OF KIRKLAND, INC. Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:12-MAY-2004 Doc #:37149803
Cust Comments: CUSTOMER STATES THE HEAD LIGHT SWITCH KNOB FALLS OFF.
Tech Comments: VERIFIED THAT THE KNOB WILL NOT STAY IN PLACE, INSTALLED NEW HEAD LIGHT KNOB. OK NOW
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 16 3A11 * * * * * * 22865
AWS Claim Key: 4179838 Trx Code: 04B22 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04805 - * Name: FORD OF KIRKLAND Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2005 Doc #:01119601
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 18 3A15 070100 4L2Z 7G391 AA P69 42 25887
AWS Claim Key: 5277863 Trx Code: S07 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 04805 - * Name: FORD OF KIRKLAND Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:01486801
Tech Comments: INSPECTED AND FOUND TSB 05 06 12 PERFORMED TSB AND REPROGRAMED PCM RETESTED ALL OK
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 18 2G05 031405 * RECALEM * E29 04 25887
AWS Claim Key: 5277862 Trx Code: S07 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 04805 - * Name: FORD OF KIRKLAND Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:01486802
Tech Comments: INSPECTED AND FOUND TSB 05 09 15 REPLACED POTENTIOMETER AND RETESTED ALL OK 1
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 18 7J05 0502XX 4L2Z 9E731 BA H19 42 25887
AWS Claim Key: 5277861 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04805 - * Name: FORD OF KIRKLAND Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:01486803
Tech Comments: INSPECTED AND FOUND TSB 03 26 03 REPLACED REAR WHEEL SPEED SENSOR RETESTED ALL OK
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 18 5G02 040102 * 3078 * C50 33 25887
AWS Claim Key: 5277860 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 04805 - * Name: FORD OF KIRKLAND Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:01486804
Tech Comments: PID MONITOR RETOURQED CROSSMEMBER BOLTS RETESTED ALL OK BOLTS,RETST OK. 1
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 30 7N02 011103 3L2Z 7823394 BA G07 42 34400
AWS Claim Key: 9212872 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 04805 - * Name: FORD OF KIRKLAND Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:26-APR-2006 Doc #:03428101
Tech Comments: TESTED SYSTEM REPLACE LR POWER WINDOW MOTOR.
1FMZU73K94ZA15031 T/U5 F T/WD T/EF T/E AV T/TL T/NE 19-SEP-2003 28-NOV-2003 174495 USA 30 2G05 031405 * RECAL * C50 04 34400
AWS Claim Key: 9212871 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04805 - * Name: FORD OF KIRKLAND Ph: 425-8216611 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:26-APR-2006 Doc #:03428102
Tech Comments: TESTED ROAD TEST VERIFIED CONCERN REPROGRAM PCM RETEST OK.
Thanks,
Vivian
