OASIS RESULT:
1FTWX31P55EA53824
10/09/2006
22:55:27
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 S/CAB PICKUP 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
37 ENGINE CALIBRATION
5F710N0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
01/31/2005 BUILD DATE
09/11/2004 SALE MILEAGE
00012
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER REFER TO 06-18-03
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
04/18/2006
DEALER: Jannell Motors, Inc.
WARRANTY CLAIM NUMBER: 021233 ODOMETER: 015136M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640AA CONNECTION A/C DUCT 001 6007D 42 DOES NOT OPERATE PROPERLY
000 6646AC
DIAGNOSIS AND VERFIY OIL LEAK FRON CAC TUBE COLD SIDE RETESTED OK
04/18/2006
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9B249A HEADER-FUEL FILTER 001 060605C 42 DOES NOT OPERATE PROPERLY
PERFORM TSB 06-6-05.REPL.MANIFOLD COVER/WIF SENSOR
04/18/2006
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 7210BAB LEVER GEAR SHIFT 001 7210A 42 DOES NOT OPERATE PROPERLY
6C3Z 9F759A WIRE ASY FUEL VAPOR 001 12651D
000 12651D2
000 14200A
000 3514A
000 MT9F759
VERIFY CONCERN WDS TO DCL NO CODES CHECK FUSE 2.24 CHECK POWER AT PIN 36.O V OLTS.REMOVE COLUMN BOWLS CHECK TOW HAUL LEVER POWER GOING IN,0 VOLTS OUT. RE PLACE LEVER STILL INOP,FURTHER TESTING REPAIR WIRING FROM PCM TO CLUSTER RET EST REPL.F/WIRE RETEST
04/18/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 8620DB BELT-W/PUMP FAN&GENE 001 ADD 42 DOES NOT OPERATE PROPERLY
000 8620F
ADD ON BELT NOISE REPL.BELT
04/17/2006
WARRANTY CLAIM NUMBER: 021211 ODOMETER: 015124M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9J460A SENSOR ASY EGR PR VL 001 05E15M
05E15 COMPLETED.
04/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
COMPLETED. RECALL 59B01
04/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
05B32 COMPLETED.
END OF OASIS REPORT FOR 1FTWX31P55EA53824
