Thinking of buying a 2001 Excursion that was made in the bad Mechanical Diode Transmission time frame and want to see if it has been replaced.
1FMSU43F41EB38399
Thanks,
-Gabe
OASIS RESULT:
1FMSU43F41EB38399
10/15/2006
19:09:24
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
1L119Y0A
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/23/2001 BUILD DATE
11/30/2000 SALE MILEAGE
00057
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FMSU43F41EB38399
Standard Claims List For Model Year 2001
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 5 7H11 120305 YC3Z 19835 CA C05 D8 9287
AWS Claim Key: 3436541 Trx Code: 2 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 07934 - * Name: SUNNYVALE FORD Ph: 408-7381800 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-AUG-2001 Doc #:44064301
Cust Comments: CUSTOMER STATES AIR CONDITIONER BLOWS WARM SOP PART IS PLEASE INSTALL
Tech Comments: EVAC. SYS & REPLACED LEAKING LINES, RECHARGED SYS & RECKD FOR LEAKS, NO MORE LEAKS FOUND SYS IS COOLING TO 40 DEGREES.
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 12 * * * * * * * 25653
AWS Claim Key: 8291206 Trx Code: 01S21 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2002 Doc #:135599A
Cust Comments: SERVICE RECALL1S21 SEAT BELTS
Tech Comments: CHECKED SEAT BELTS AS PER RECALL INSTRUCTIONS, OKAY AT THIS TIME
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 12 7D07 17XXXX F4CZ 13466 A L26 46 25653
AWS Claim Key: 8291207 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2002 Doc #:135599B
Cust Comments: LEFT REAR TAIL LIGHT INOP
Tech Comments: REPLACE BURNED OUT BULB AS NEEDED
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 12 2H01 030008 * 6K682 * L65 42 25653
AWS Claim Key: 8291208 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2002 Doc #:135599F
Cust Comments: ENGINE LEAKING OIL
Tech Comments: VERIFIED CONCERN, FOUND AND REPAIRED LEAKING TURBO INTAKE TUBES, LOOSE AND POSITIONED INCORRECTLY, RECHECKS OKAY
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 12 7S12 NANANA F81Z 9D930 AB E29 42 25653
AWS Claim Key: 8291209 Trx Code: S07 Labor Hrs: 3
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:12-APR-2002 Doc #:135599G
Cust Comments: CHECK ENGINE LUIGHT IS COMING ON
Tech Comments: REMOVE AND REPLACE LEFT VALVE COVER AND REPLACE WIRING HARNESS, LOOSE PIN CONNECTIONS
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 14 7D07 170000 F5DZ 13466 C L30 46 28549
AWS Claim Key: 8816767 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2002 Doc #:136621A
Cust Comments: LEFT REAR TURN SIGNAL INOP
Tech Comments: CHECKED AND REPLACED BURNED OUT BULB AS NEEDED.
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 14 5R88 000615 * NPF * C50 82 28549
AWS Claim Key: 8816768 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2002 Doc #:136621B
Cust Comments: CUSTOMER STATES THE REAR OF VEHICLE SETS LOWER THAN THE FRONT
Tech Comments: MEASURED STANDING HEIGHT FRONT AND REAR, REAR OF VEHICLE IS SLIGHTLY HIGHER THAN FRONT, BOTH FRONT AND REAR HEIGHTS ARE WITH FACTORY SPECI FICATION, INSPECTION ONLY
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 17 3A11 070100 1C3Z 7000 FBRM P59 42 34213
AWS Claim Key: 10534343 Trx Code: E84 Labor Hrs: 7.5
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2002 Doc #:139010A
Cust Comments: CHECK AND REPORT ON OVERDRIVE LIGHT FLASHING, AND TRANS FLUID IS BURNT
Tech Comments: VERIFIED CONCERN, CHECKED TRANSMISSION FLUID LEVEL AND CONDITION, FULL BUT BURNT, REMOVE TRANSMISSION OIL PAN AND INSPECT, FULL OF METAL REMOVED AND REPLACED TRANSMISSION AND INSTALL REMANUFACTURED UNIT, FLUSH COOLER LINES, CFECK FOR LEAKS AND ROAD TEST, OKAY... MT TIME DUE TO REMOVE AND INSPECTED TRANS FOR COSTCOMPARISON
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 27 3A11 070100 1C3Z 7000 FBRM P66 42 51825
AWS Claim Key: 15187425 Trx Code: SSP Labor Hrs: 9
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2003 Doc #:146795A
Cust Comments: REPORT ON TRANSMISSION SEEMS TO SLIP WHILE DRIVNIG, IN DRIVE RPMS WILL GO HIGH
Tech Comments: INSPECTED TRANS,FLUID BURNT, ROAD TESTED VERIFIED ERRATIC 2 3 UPSHIFTS, COAST CLUTCH INOP, NO ENGINEBRAKING. CONTROL PRESSURE OK, NO CHANGE UNSING TR ANS TESTER, REMOVED TRANSMISSION AND TEARDONW FOR INSPECTION, EXCESSIVE DAMAGE, REASSEMBLED CORE. INSTALLED NEW TRANSMISSION, FLUSHED COOLER LINES, REPLACED COOLER AND ROAD TESTED ALL OK
1FMSU43F41EB38399 T/L1 F T/WD T/BD T/E A1 T/D8 T/DS 30-NOV-2000 23-APR-2001 172033 USA 31 2E06 030008 XC3Z 9E527 AARM D42 42 58495
AWS Claim Key: 16536363 Trx Code: S07 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 07712 - * Name: MISSION VALLEY FORD TRUCK SLS Ph: 408-9332300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-OCT-2003 Doc #:149088A
Cust Comments: ADVISE ON TURBO NOT ENGAGEING, LACK OF POWER, PINGING.
Tech Comments: CONFIRMED COMPLAINT, RAN PERFORMANCE SHEET TEST ,PULLED CODE P0284. # 8 CYLINDER, RAN CYLINDER CONTRIBUTION TEST. R AND R #8 INJECTOR, RE TES T OK NOW. TEST DROVE AGAIN. OK NOW.HEARD NOISE FROM INSID E VEHICLE AROUND DASH AREA, CHECKED FORD OASIS FOUND SSM16859 AND 314290, CONDITION NORMAL PART #9E527
