Still kickin
This could be interesting:
1FTSW31P13EB78804
OASIS RESULT:
1FTSW31P13EB78804
11/06/2006
12:06:11
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
6 SPEED MANUAL AXLE CODE
D1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
ARN MESSAGES
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/17/2003 BUILD DATE
02/26/2003 SALE MILEAGE
00000
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
06E17
CONTROL MODULE RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
03/27/2006
DEALER: Jones Ford, Inc.
WARRANTY CLAIM NUMBER: 016313 ODOMETER: 092570M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 001 6007A 30 CHAFED,EXCESSIVE WEAR,FRAYED
3C3Z 6009AARM CYLINDER BLOCK 001 6007A1
3C3Z 6701AA CRANKSHAFT REAR SEAL 001 6007E
3C3Z 6D083AA GASKET-RR COVER 001
3C3Z 6710AA GASKET SET-OIL PAN 001
3C3Z 9433AA GASKET SET-MANIFOLD 001
3C3Z 6710BA GASKET SET-OIL PAN 001
3C3Z 6710CA GASKET SET-OIL PAN 001
3C3Z 6A008DA DOWEL-CYL HEAD TO CY 004
3C3Z 6065AA BOLT CYL HEAD 020
3C3Z 9229AA GASKET CARB FUEL INL 008
5C3Z 6079B GASKET SET-VALVE GRI 001
4C3Z 6675AA PAN ASY OIL 001
4C3Z 6564AA ARM-VALVE ROCKER 002
VC 7B 002
3C3Z 6731AA ELEMENT ASY OIL FILT 001
XO 15W40QSD 016
02/10/2006
DEALER: Ken Garff Ford
WARRANTY CLAIM NUMBER: 053679 ODOMETER: 089470M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 005 9527AT 42 DOES NOT OPERATE PROPERLY
4C3Z 9J460A SENSOR ASY EGR PR VL 001 12650D9
3C3Z 6766BA CAP ASY OIL FILLER 001 6005F9
000 6005F
000 6005F1
000 6005F1X1
000 6005F13
000 6005F2
000 6005F14
000 6005F20
000 6005F11
000 6005F18
000 6005F6
89470 5 FAILED INJECTORS & EBP SENSOR. 42. PERFORM TESTS ON LINES #1 THRU # 11 ON PERFORMAN CE SHEET FOR DTCS PO266,PO336,PO341,PO478,& P22 63 IN CONT INIOUS MEMEORY.ALLOW VEHICLE TO COLD SOAK OVERNIGHT & PERFORM ENHANCED COLD START UP POWER BALANCE TO VERIFY MISS ON #1,#5,#6,& #8 C YLINDERS WHEN CO LD.PERFORM PINPOINT TEST FOR D TCS PO336,PO341,WAS UNABLE TO VERIFY FAULTS
END OF OASIS REPORT FOR 1FTSW31P13EB78804
Still kickin
Thanks for the quick post, however, I know there is supposed to be more in the report than what was posted. Is there a way to get the rest of it? I'm trying to get an idea for all the recalls done on the truck. I'm about to roll 100k and wanted to try to get as much updated stuff as possible before warranty runs out. The tech here seems to be a pretty good guy and would probably help me to get whatever hasn't been done as long as I bring it up.
Standard Claims List For Model Year 2003
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 1 1A03 030101 * 6007 * D02 42 2845
AWS Claim Key: 943302 Trx Code: 2 Labor Hrs: 32.9
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER SUPER FORD - DOWNTOWN Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:01-APR-2003 Doc #:59988301
Cust Comments: TRUCK TOWED IN FROM HEBER FORD. FORD DEALER STATES ENGINE WONT RUN AND THEY DRAINED 25 QUARTS OF OIL FROM OIL PAN AND
Tech Comments: 1 HOOKED UP WDS PULLED CODES FOUND CYL #1 AND CYL #6 OUT OF BALANCE COMPRESSION TESTED FOUND NO COMPRESSION IN CYL #1 THERE IS NO PUBLISHED FLAT RATE FOR 6.0L POWERSTROKE ENGINE REPAIRS. ALL REQUESTED TIMES ARE DOCUMENTED WITH TIME PUNCHES AND TECH WAS WORKING DIRECTLY WITH THE TECH HOTLINE.
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 3 2E06 030008 3C3Z 9E527 AE D50 D8 64084
AWS Claim Key: 1320570 Trx Code: E72 Labor Hrs: 3
Dlr Cd-Sub Cd: 08303 - * Name: GAYLEN S. WRIGHT FORD, INC. Ph: 435-6544910 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:21-MAY-2003 Doc #:08590201
Cust Comments: ENGINE OIL IS OVER FULL
Tech Comments: DRAIN 19 QTS OF OIL OUT OF THE CRANK CASE; RUN FICM; FUEL LEAKS OUT OF PAN AFTER ABOUT 1 MIN; REMOVE LH VALVE COVER GASKET; #2 INJECTOR LEAKING;REPLACE INJECTOR; RETEST; OK NOW
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 12 5C01 050100 F81Z 4635 AB K03 30 32376
AWS Claim Key: 4561662 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER SUPER FORD - DOWNTOWN Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2004 Doc #:023779A
Cust Comments: REPAIR VEHICLE WILL NOT GO INTO 4WD PROPERLY
Tech Comments: 32380 REAR U JOINT ON REAR DRIVESHAFT,EXCESSIVE WEAR ROAD TEST TO VERIFY CONCERN,4WD OPERATES NORMAL COULD HEAR SQUEEL NOISE ON DECEL,R R REAR AND REPLACED REAR U JOINT. REROAD TEST AND RECHECEKED. MILEAGE ON THIS REPAIR IS CORRECT. MILEAGE ON RO 85902 FROM WRIGHT FORD PROBABLY SHOULD HAVE BEEN 6408 UNLESS THE GUY DROVE 61000 MILES IN 7 WEEKS.
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 18 1A05 030008 3C3Z 9431 AB E42 14 51811
AWS Claim Key: 7766067 Trx Code: E72 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER SUPER FORD - DOWNTOWN Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2004 Doc #:032738A
Cust Comments: REPAIR EXHAUST LEAK FROM ENGINE AREA S O PARTS HERE
Tech Comments: 51811 TURBO INLET PIPES TRACED LEAKS TO BOTH EXHAUST MANIFOLDS AND TURBO INLET PIPES. PULLED AND REPLACED BOTH EXHAUST MANIFOLDS PULLED AND REPLACED TURBO INLET PIPES. REASSEMBLED AND RT
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 18 * * * * * * * 51811
AWS Claim Key: 7766068 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08240 - * Name: LARRY H. MILLER SUPER FORD - DOWNTOWN Ph: 801-5781000 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2004 Doc #:032738C
Cust Comments: RECALL ON NEGATIVE TERMINAL
Tech Comments: 51811 DONE DONE
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 25 2E06 030008 * 9E527 * D50 01 69251
AWS Claim Key: 10236562 Trx Code: E72 Labor Hrs: 18.4
Dlr Cd-Sub Cd: 08303 - * Name: GAYLEN S. WRIGHT FORD, INC. Ph: 435-6544910 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2005 Doc #:09199701
Cust Comments: DRIVING DOWN THE FREEWAY THE TRUCK STARTED GAINING SPEED W/O PUSHING ON THE GAS. THEN THE TRUCK QUIT AND WOULD NOT START.
Tech Comments: RO OPENED 2/18/05; R&R COMPLETED 3/16/05; REFER TO OASIS #215003297; STILL NEED TO FINISH ENTERING ALL PARTS & INFO. TECH HOTLINE APPR #PAAZX OBTAIN APPROVAL FROM OUR CSM FOR 1 MTH CUST PMT
AWS Claim Key: 10253830 Trx Code: E72 Labor Hrs: 0
Dlr Cd-Sub Cd: 08303 - * Name: GAYLEN S. WRIGHT FORD, INC. Ph: 435-6544910 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:16-MAR-2005 Doc #:09199703
Tech Comments: TOW BILL FROM MOORE'S TOWING, COALVILLE, UT. THIS IS NOT REPEAT REPAIR DIFF TOW BILL/DIFF REPAIR
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 25 6Y20 000001 * MISC * A9* 82 69251
AWS Claim Key: 10194277 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 08303 - * Name: GAYLEN S. WRIGHT FORD, INC. Ph: 435-6544910 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:19-MAR-2005 Doc #:09199702
Tech Comments: TO GIVE CUSTOMER CREDIT FOR 1 MTH PMT; APPROVAL PER CSM, FRANK CONDINO
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 36 2E06 030008 3C3Z 9E527 AE D41 42 89470
AWS Claim Key: 13118396 Trx Code: E72 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 08254 - * Name: KEN GARFF FORD Ph: 801-7636800 St:UT Ctry Cd: USA Reg Cd: NA Repr Date:10-FEB-2006 Doc #:053679A
Cust Comments: INSPECT FOR NOISE IN ENGINE AND VEHICLE HAS NO POWER AND IS RUNNING ROUGH
Tech Comments: 89470 5 FAILED INJECTORS & EBP SENSOR. 42. PERFORM TESTS ON LINES #1 THRU #11 ON PERFORMAN CE SHEET FOR DTCS PO266,PO336,PO341,PO478,& P22 63 IN CONTINIOUS MEMEORY.ALLOW VEHICLE TO COLD SOAK OVERNIGHT & PERFORM ENHANCED COLD START UP POWER BALANCE TO VERIFY MISS ON #1,#5,#6,& #8 C YLINDERS WHEN COLD.PERFORM PINPOINT TEST FOR D TCS PO336,PO341,WAS UNABLE TO VERIFY FAULTS FOR
1FTSW31P13EB78804 T/F7 F T/BC T/CD T/E A1 T/VG T/YB 26-FEB-2003 17-MAR-2003 156652 USA 37 1A03 030008 3C3Z 6009 AARM N12 30 92570
AWS Claim Key: 13628868 Trx Code: E72 Labor Hrs: 24
Dlr Cd-Sub Cd: 01025 - * Name: JONES FORD, INC. Ph: 843-7443311 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:01631351
Cust Comments: TICKING NOISE FROM ENGINE REGARDLESS OF ENGINE TEMP WORSE ON DECCELLERATION
Tech Comments: PISTON MELTED ENGINE ASSEMBLY REMOVE AND INSTALL DISSEMBLE ENGINE LOW COMPRESSION ON CYL 2 AND 6 FOUND PISTONS MELTED REPLACE SHORT BLOCK ASSEMBLY RECHARGE AC
