Standard Claims List For Model Year 2004
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 0 6Y05 000001 * TDRIVE * A96 42 5
AWS Claim Key: 311710 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02651 - * Name: PENINSULA FORD OF PALO ALTO-PENINSULA FORD OF MENL Ph: 650-4936900 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-JAN-2004 Doc #:05907152
Cust Comments: 6.0 L DIESEL ROAD TEST
Tech Comments: X PERFORMED 6.0 DIESEL TEST DRIVE.
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 1 5G02 0401XX * 3B440 * H26 33 2105
AWS Claim Key: 427364 Trx Code: 2 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 07757 - * Name: FORD OF FAIRFIELD Ph: 707-4213300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2004 Doc #:02130451
Cust Comments: CUSTOMER STATES THE TRUCK PULLS TO RIGHT AND STEERING WHEEL IS NOT STRAIGHT
Tech Comments: STEERING PULLS RT
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 1 1D01 031001 * 6701 * L65 D8 2105
AWS Claim Key: 421635 Trx Code: 2 Labor Hrs: 6
Dlr Cd-Sub Cd: 07757 - * Name: FORD OF FAIRFIELD Ph: 707-4213300 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2004 Doc #:02130452
Cust Comments: CUSTOMER STATES THERE IS A OIL LEAK BETWEEN ENGINE AND TRANSMISSION
Tech Comments: OIL LEAK
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 4 6Y05 000001 * MAINT * A96 82 5314
AWS Claim Key: 825164 Trx Code: 0715S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00398 - * Name: VACAVILLE FORD-MERCURY, INC. Ph: 707-4487111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:12132901
Tech Comments: 1 PERFORM QCM 5K SERVICE.
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 5 1D01 030008 3C3Z 6701 AA L72 D8 7058
AWS Claim Key: 1216434 Trx Code: 2 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 07955 - * Name: RON DUPRATT FORD Ph: 707-6785555 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2004 Doc #:06109401
Cust Comments: CUSTOMER STATES THAT VEHICLE HAS OIL LEAKING FROM
Tech Comments: CHECKED OIL LEAK, CLEANED OIL LEAK, ROAD TESTED,RECHECKED FOUND REAR MAIN OIL SEAL LEAKING. REMOVETRANSMISSION, REPLACED REAR MAIN OIL SEAL, REINSTATRANS, CLEANED AREA, RECHECKED O.K.
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 5 2G02 030008 4C2Z 12A690 AB C30 42 7058
AWS Claim Key: 1216435 Trx Code: S07 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 07955 - * Name: RON DUPRATT FORD Ph: 707-6785555 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2004 Doc #:06109402
Cust Comments: CUSTOMER STATES THAT WHEN A/C IS ON OIL SMELL IS
Tech Comments: RAN DIAG. FOR A/C, A/C OPERATION O.K. FOUND GLOWPLUG HARNESS LEAKING OIL ONTO EXHAUST MANIFOLD.REMOVED AND REPLACED HARNESS, CLEANED OIL, ANDRECHECKED O.K.12A690
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 8 6Y05 000001 * MAINT * A96 82 9487
AWS Claim Key: 1748919 Trx Code: 0715S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 00398 - * Name: VACAVILLE FORD-MERCURY, INC. Ph: 707-4487111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-AUG-2004 Doc #:12411101
Cust Comments: PERFORM QCM 10K SERVICE.
Tech Comments: PERFORM SCHEDULED 10K SERVICE.
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 13 6Y05 000001 * MAINT * A96 82 12988
AWS Claim Key: 3681652 Trx Code: 0715S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 00398 - * Name: VACAVILLE FORD-MERCURY, INC. Ph: 707-4487111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-FEB-2005 Doc #:12802901
Tech Comments: NO WHEEL LOCK, CUSTOMER SAYS OK NOT TO ROTATE TIRES. PERFORM QCM 15K SERVICE.
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 19 6Y05 000001 * MAINT * A96 82 17016
AWS Claim Key: 6226491 Trx Code: 0715S Labor Hrs: 1.8
Dlr Cd-Sub Cd: 00398 - * Name: VACAVILLE FORD-MERCURY, INC. Ph: 707-4487111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2005 Doc #:13273601
Cust Comments: 15,000 SERVICE PER MAINTANCE CARE
Tech Comments: 1 15K QCM SERVICE. COMPLETED PER MANUAL
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 19 * * * * * * * 17016
AWS Claim Key: 6283247 Trx Code: 05S34 Labor Hrs: 1
Dlr Cd-Sub Cd: 00398 - * Name: VACAVILLE FORD-MERCURY, INC. Ph: 707-4487111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2005 Doc #:13273603
Cust Comments: RECALL CAMPAIGN NUMBER: 05S34
Tech Comments: 1 COMPLETED 05S34, RENTAL PROVIDED TO CUSTOMER.
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 19 2H01 * * * * * * 17016
AWS Claim Key: 6226490 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00398 - * Name: VACAVILLE FORD-MERCURY, INC. Ph: 707-4487111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2005 Doc #:13273604
Cust Comments: RECALL CAMPAIGN NUMBER: 05B29
Tech Comments: 1 COMPLETED 05B29
AWS Claim Key: 6283248 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00398 - * Name: VACAVILLE FORD-MERCURY, INC. Ph: 707-4487111 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2005 Doc #:13273606
Cust Comments: PERFORM 59B01
Tech Comments: PERFORM 59B01
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 22 * * * * * * * 17671
AWS Claim Key: 7283741 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2005 Doc #:02201051
Cust Comments: RECALL 05E15
Tech Comments: RECALL 05E15 REPLACED EP SENSOR & REPROGRAM PCM. WPI
AWS Claim Key: 7283742 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2005 Doc #:02201052
Cust Comments: 59B01
Tech Comments: ***NOTE: VEHICLE DOES HAVE A DRIVEABLE CONCERN, AIR CLEANER TUBE WAS LOOSE, COULD CAUSE TURBO TO FAIL, CAUSING TURBO NOT TO BE WARRANTABLE
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 22 2H01 030008 4C3Z 6K682 AARM D42 42 17850
AWS Claim Key: 7488748 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:20-OCT-2005 Doc #:02236152
Cust Comments: NO POWER
Tech Comments: VERIFIED VGT STICKS AT TIMES. REMOVED AND INSP TURBO. CHECKED HISTORY, TURBO NOT DUSTED. HAD SVC MGR MN INSP AND VERIFIED OK TO REPLACE TURBO UNDER WARRANTY.
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 23 2A01 031202 5C3Z 6C646 DA L65 D8 18108
AWS Claim Key: 7788090 Trx Code: E84 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:05-NOV-2005 Doc #:02289551
Cust Comments: CHECK OIL LEAK
Tech Comments: WRONG CAC TUBE CAME IN, REORDERED CAC TUBE
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 23 5R13 110400 * 7A110 * P59 07 18108
AWS Claim Key: 7807208 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:05-NOV-2005 Doc #:02289552
Cust Comments: CHECK SHIFTER OFF ALIGNMENT
Tech Comments: WPI ADJUSTED SHIFT INDICATOR
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 24 2A01 031202 5C3Z 6C646 EA L65 33 18652
AWS Claim Key: 7877406 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2005 Doc #:02380851
Cust Comments: OIL LEAK USE SPO
Tech Comments: WPI REPLACED HOTSIDE CAC TUBE, TORQUE 09FT LBS, RECHECKED OK
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 26 6Y05 000001 * MAINT * A96 82 20145
AWS Claim Key: 8644060 Trx Code: 0715S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2006 Doc #:02602251
Cust Comments: 20K SERVICE ROTATE TIRES
Tech Comments: WPI PERFORMED 20K QCM SERVICE
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 32 7S12 180103 * 14A005 * L25 B4 22889
AWS Claim Key: 10439436 Trx Code: E83 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2006 Doc #:03196454
Cust Comments: WHEN VEH PUT IN NUTERAL, ALL INTERIOR LIGHT TURN ON
Tech Comments: WPI NOTICED CABLE WAS BEING RUBBED, REPAIRED WIRE, CHECKED OP OK
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 32 6Y05 000001 * MAINT * A96 82 22889
AWS Claim Key: 10191441 Trx Code: 0715S Labor Hrs: 1.3
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2006 Doc #:03196651
Cust Comments: 25K SERVICE
Tech Comments: WPI PERFORMED 25,000 MILE SERVICE
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 36 6Y05 000001 * MAINT * A96 82 26364
AWS Claim Key: 11105759 Trx Code: 0715S Labor Hrs: 2.2
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2006 Doc #:03486751
Cust Comments: 30K SERVICE
Tech Comments: WPI 30000 MILES (48000 KMS) NORMAL SCHEDULED MAINTENANCE
1FTNW21P74EB70330 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 22-DEC-2003 13-JAN-2004 172012 USA 36 7F02 011601 YF1Z 17528 AB A99 30 26364
AWS Claim Key: 11105760 Trx Code: 0715D Labor Hrs: 0.2
Dlr Cd-Sub Cd: 07761 - * Name: ORCHID ISLE AUTO CENTER Ph: 808-9351191 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2006 Doc #:03486851
Cust Comments: WIPER BLADES DOESNT WIPE WINDSHIELD CLEAN
Tech Comments: WPI WIPER BLADE FRONT REPLACE
