Standard Claims List For Model Year 2006
1FTWW31P76EB26745 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 19-SEP-2005 06-OCT-2005 152171 USA 6 1H03 030008 5C3Z 9F452 AA E29 42 10527
AWS Claim Key: 809857 Trx Code: S07 Labor Hrs: 3.5
Dlr Cd-Sub Cd: 04521 - * Name: TIPTON FORD, INC. Ph: 936-5647337 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2006 Doc #:181458A
Cust Comments: E29 C S SES LIGHT ON
Tech Comments: 10536 EGR VALVE 42 ROAD TEST, HOOKED UP WDS, PERFORMED PERFORMANCE DIAG P0401, MONITORED PIDS(EGR,EBP)ROAD TEST, FOUND EGR VALVE STICKING, REPLACED EGR VALVE, CLEARED CODES, ROAD TEST, RETEST
1FTWW31P76EB26745 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 19-SEP-2005 06-OCT-2005 152171 USA 6 7K11 130101 6C3Z 10849 JA L69 42 10527
AWS Claim Key: 809858 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 04521 - * Name: TIPTON FORD, INC. Ph: 936-5647337 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2006 Doc #:181458B
Cust Comments: L69 C.S FUEL GAUGE STUCK ON E AFTER REFUEL
Tech Comments: 10536 INSTRUMENT CLUSTER 42 ROAD TEST, HOOKED UP WDS, RETRIEVED CODES P0463 , MONITORED PIDS(FLI)ROAD TEST, LOWERED FUEL TANK, REMOVED PUMP, TESTED FUEL SENDER OK, TESTED GAUGE, FOUND INTERNAL OPEN IN CLUSTER, ORDERED PARTS REMOVED DASH PANEL, REMOVED CLUSTER, DOWNLOADED INFO TO NEW CLUSTER, REPLACED INSTRUMENT CLUSTE R, REPROGRAMMED CLUSTER, REINSTALLED DASH PANEL, ROAD TEST,
1FTWW31P76EB26745 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 19-SEP-2005 06-OCT-2005 152171 USA 6 7T03 060900 6C3Z 2C219 AA P59 42 10527
AWS Claim Key: 809859 Trx Code: S07 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 04521 - * Name: TIPTON FORD, INC. Ph: 936-5647337 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2006 Doc #:181458C
Cust Comments: P09 C S TRANSMISSION SEEMS TO SLIP HESITATE UNDER ACCELERATION AND VEH BOGS DOWN AT SHIFT POINTS
Tech Comments: 10536 ABS MODULE 42 ROAD TEST, HOOKED UP WDS, RETIREVED CODES C1145 , C1155, C1175, P0500, MONITORED PIDS(SPEED SENSORS)ROAD TEST, REMOVED C135, CHECKED POWERS AND GROUNDS TO MODULE OK, CALLED HOTLINE, REMOVED C150 AT LF SPEED SENSOR, HOOKED UP AMP GAUGE INLINE ON CIRCUIT 522, SPUN WHEEL, 10MA, READING OK, CHECKED POWER TO SENSOR OK, FOUND INTERNAL OPEN IN ABS MODULE, REPLACED
1FTWW31P76EB26745 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 19-SEP-2005 06-OCT-2005 152171 USA 7 7S20 010505 * 14A205 * G29 24 11324
AWS Claim Key: 826418 Trx Code: 2 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 04521 - * Name: TIPTON FORD, INC. Ph: 936-5647337 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2006 Doc #:182520A
Cust Comments: G29 C S TRAILER DISCONNNECTED DISLPLAYS WHILE TRAILER IS HOOKED UP AND IN TOW.
Tech Comments: 11324 TRAILER PLUG IN BED 24 1.0 VERFIEIED CONCERN PERFORMED EEC SELFTEST C2807 C2808 PERFRMED PINPOINT TEST D1 YES D2 YES D3 N O REMOVED TRAILER CONNECTOR IN BEDSIDE FOUND CE NTER PIN FOR TRAILER BACKUP LIGHTS TO BE LOOSE AND SHORTING BETWEEN WIRING PINS REMOVED LOOSE AND UNUSED PIN REASSEMBLED AND RETEST ALL OK AN D CLEARED CODES RETEST ALL PASS
1FTWW31P76EB26745 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 19-SEP-2005 06-OCT-2005 152171 USA 9 6F33 010702 3C3Z 2520708 AA B63 42 14339
AWS Claim Key: 1244406 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04521 - * Name: TIPTON FORD, INC. Ph: 936-5647337 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2006 Doc #:185166D
Cust Comments: C S WEATHER STRIPPING AROUND PASS DOOR HAS A HOLE IN IT
Tech Comments: 14351 WEATHERSTRIPPING 42 REPLACED RF DOOR WEATHERSTRIPPING
1FTWW31P76EB26745 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 19-SEP-2005 06-OCT-2005 152171 USA 9 6C06 010502 5C3Z 2502344 AAA T53 34 14339
AWS Claim Key: 1244407 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04521 - * Name: TIPTON FORD, INC. Ph: 936-5647337 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:26-JUN-2006 Doc #:185166E
Cust Comments: C S TRIM ALONG PASS FRONT DOOR HAS A WORN PLACE HAS ALWAYS BEEN LIKE IT
Tech Comments: 14351 PASS. KICK PANEL 42 REPLACED PASS. SIDE KICK PANEL
1FTWW31P76EB26745 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 19-SEP-2005 06-OCT-2005 152171 USA 10 2G04 031401 * 12A650 * D42 42 15896
AWS Claim Key: 1315406 Trx Code: S07 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06295 - * Name: TOWN & COUNTRY AUTOPLEX, INC. Ph: 970-6410051 St:CO Ctry Cd: USA Reg Cd: NA Repr Date:13-JUL-2006 Doc #:01786351
Cust Comments: CSR STS WHILE DRIVING UP HILL TRANS DOWNSHIFTS OUT OF HIGH AND THE WATER TEMP GAUGE GOES UP TO HOT AND THEN BACK DOWN TO OK HAPPENS WHEN TRAILER IS ON
Tech Comments: VERIFIED CONCERN CHECKED FOR CODES FOUND NO CODES PRESENT CHECKED COOLING SYSTEM NO LEAKS, CHECKED FAN OPERATION ALL OK. CHECKED FOR RESTRICTED RADIATOR FLASHED PCM TCM TO LATEST LEVEL ALL OK
Wow- sounds like a problem truck. Not as interested anymore. Thanks for running it. I appreciate the info.
no problem just let me i am always on here and fmcdealer so i can run them all day long
