Standard Claims List For Model Year 2000
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 1 6A12 011801 * ENTRE * F12 P1 35
AWS Claim Key: 1458000 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-MAY-2000 Doc #:068800A
Cust Comments: OSL. VEHICLE HAS DEEP SWIRL MARKS IN PAINT.
Tech Comments: COMPLETE VEHICLE RUB OUT
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 2 1A03 030100 * 6005 * D36 82 1840
AWS Claim Key: 2901494 Trx Code: 1 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2000 Doc #:070651A
Cust Comments: CK WHEN PULLING SMALL TRAILER ON FREEWAY FOR WHILE ENG LACKS POWER AFTER EXITS IF REMOVE TRAILER WILL PERFORM BETTER SEE RICK ALLIE
Tech Comments: 1844 NPF ROAD TEST,PERFORM KOEO ON DEMAND SELF TEST,PASS RETRIEVE COUNT DTCS,PASS KOER SELF TEST PASS.INJECTION CONT.PRESSURE TEST,(1175 1200 PSI) OK.LOW IDLE STABILITY TEST (550 600 LBS) OK.INSTALL FLIGHT RECORDER.ADVISE CUST.TO RECORD & BRING BACK AT LATER DATE. VIEW RECORDED ARIAS ON FLIGHT RECORDER.NPF.AT THIS TIME.ADVISE CUSTMER TO PUT MORE MILES ON TRUCK.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 2 7S02 180102 * 14401 * C05 X2 1840
AWS Claim Key: 2901493 Trx Code: 1 Labor Hrs: 4.6
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2000 Doc #:070651C
Cust Comments: A C NOT GETTING COLD
Tech Comments: 3143 14401 X2 ROAD TEST CK A C OPERATION,INSTALL GAUGES CK PRESSURES,RECLAIM FREON,R&I INSP FIXED ORIFICE VALVE OK,RECHARGE A C,CK RECIRC DOOR OK,DIAG ELE BLEND DOOR,R&I CONTROLER CIRCUIT TEST,TRACE CIRCUITS 436 437 438,ACCESS DASH, REPAIR LOOSE TERMINAL AT C221,RECK OK...
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 2 6A13 010203 * 16006 * F13 P1 1840
AWS Claim Key: 2925559 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:05-JUL-2000 Doc #:070651D
Cust Comments: WHEEL MARKS IN PAINT ON LEFT FRONT FENDER AND LEFT REAR DOOR
Tech Comments: RUBBED OUT LEFT FRT FENDER LEFT REAR DOOR
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 5 6E01 011001 XC3Z 2560136 AAC T90 D4 3431
AWS Claim Key: 3046842 Trx Code: 1 Labor Hrs: 0
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2000 Doc #:074305A
Cust Comments: INSTALL SOP FOR DRIVERS ARM REST
Tech Comments: REPLACED CENTER ARMREST
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 15 2G01 031401 XU7Z 12A650 AA D36 42 11939
AWS Claim Key: 10154814 Trx Code: S07 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2001 Doc #:092111A
Cust Comments: CK AFTER DRIVE ON FREEWAY FOR 2 HR GETS OFF FREEWAY HAS NO POWER AFTER COOL DOWN RUNS O K SEE RICK ALLIE
Tech Comments: 11944 12A650 42 PERFORM PERFORMANCE DIAG.1 19.PERFORM PINPOINT TEST MA1 FOR CODE P0603.FOUND NESSARY TO REPLACE PCM.ROAD TEST.RETEST (SYSTEM PASS).
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 15 1G04 030504 F8TZ 6B209 BA E50 42 11939
AWS Claim Key: 10154815 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:07-AUG-2001 Doc #:092111B
Cust Comments: CK BELT PULLY TYPE NOISE EVEN WHEN SHUT OFF SEE RICK
Tech Comments: 11944 6B209 42 REPLACE DRIVE BELT & TENSIONER.A C & DUEL ALT.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 16 2G01 031401 XU7Z 12A650 AA D50 42 12162
AWS Claim Key: 10297634 Trx Code: E91 Labor Hrs: 6.3
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:13-AUG-2001 Doc #:092391A
Cust Comments: NO POWER ON ACCEL. COLD OR HOT ENGINE
Tech Comments: 12171 12A650 42 PERFORM PERFORMANCE DIAG.1 19.FOUND NEW CODES. P1248,1249 COUNT.PERFORM PINPOINT TEST DH1. FOUND NESSARY TO REPLACE MAP SENSOR.REROAD TEST TURBO BOOST STILL LOW.PERFORM NGS MONITOR TEST. FOUND BARO 14.5 PSI,EBP 14.5 PSI,MAP 9.4 PSI. GROUND MAP RETURN SIGNAL.RETEST,MAP STILL LOW. REINSTALL BREAK OUT BOX.NESSARY TO REMOVE PCM. TO INSTALL BREAK OUT BOX.TEST
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 16 * * * * * * * 12310
AWS Claim Key: 10851387 Trx Code: 01S24 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:07-SEP-2001 Doc #:093842A
Cust Comments: RECALL 01S24
Tech Comments: PERFORM RECALL 01S24
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 26 7S02 180102 * 14401 * D02 X4 16475
AWS Claim Key: 16932819 Trx Code: E83 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:01-JUL-2002 Doc #:111256A
Cust Comments: CRANKS WONT START TOWED IN RSA QUIT RUNNING 6 30 02 GOT STARTED THEN QUIT AGAIN
Tech Comments: 16479 TERMINAL X4 VEH.STARTED.PERFORM ROAD TEST.FOUND VEH.BUCKING INTERMITTENTLY.PERFORM PERFORMANCE DIAG.1 19. PERFORM PINPOINT TEST DF FOR CODE P0344. FOUND FRAIED WIRE IN CIRCUT 351 AT CMP CONNECTOR.REPAIR TERMINAL.RETEST,OK.CLEAR DTCS AND ROADTEST RETEST CODES PASS
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 32 2I04 030008 F4TZ 12A342 BA D03 42 19465
AWS Claim Key: 18953232 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:04-DEC-2002 Doc #:119670A
Cust Comments: HARD TO START COLD
Tech Comments: 19474 12B533,12A342 42 PERFORM GLOW PLUG SYSTEM DIAG.NESSARY TO REPLAC E GLOW PLUG CONTROL.REMOVE LT.VALVE COVER,REPLA CE #3 & 6 GLOW PLUGS.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 32 2A01 031201 1C3Z 9600 AA D36 42 19465
AWS Claim Key: 18953233 Trx Code: S07 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:04-DEC-2002 Doc #:119670B
Cust Comments: LACKS POWER ON ACCEL. SEE RICK
Tech Comments: 19474 9600 42 PERFORM PERFORMANCE DIAG.1 19.NORMAL DIAGNOSAS CANNOT PINPOINT CONDITION.REPLACE AIR CLEANER ASSEMBLY PER.01 9 5.REROAD TEST,OK.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 32 7B02 140201 F81Z 10346 EARM D02 42 19577
AWS Claim Key: 19142209 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:23-DEC-2002 Doc #:120661A
Cust Comments: CK CHARGING SYSTEM HAS TO JUMP TO START WHEN STARTS GET EXCESSIVE WHINE NOISE FROM TOP ALT.
Tech Comments: 19577 42 10346 VERFIY NO CRANK. JUMP START, RECHARGE BATTERIES RETESTED PASS TESTED CHARGING SYSTEM REPLACED ALT.,. TESTED INTERNAL OPEN RETESTED CHARGING OK 14.4, LOADED DRAW TESTED .06 AMPS NORMAL. STARTING OK
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 36 2B01 030701 F7TZ 12K073 A D03 42 20404
AWS Claim Key: 20370201 Trx Code: S07 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2003 Doc #:126496A
Cust Comments: HARD TO START AT TIMES COLD SLOW CRANK
Tech Comments: 20404 12K073 42 PERFORM HARD START NO START DIAG.1 10.INSTALL BREAK OUT BOX,PERFORM PINPOINT TEST DF 1 FOR CODE P0344 CONT.REPLACE CMP SENSOR FOR INTERMITTENT SHORT,CLEAR DTCS RETEST PASS
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 36 5V01 0603XX * 1102 * N27 14 20404
AWS Claim Key: 20370199 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2003 Doc #:126496B
Cust Comments: AT TIMES WHILE DRIVING HWY AND APPLY BRAKES WILL PULSATE AND RUMBLE
Tech Comments: 20404 ROAD TESTED INSPECTED BRAKES FRONT PADS MEASURE OVER 5MM,REAR PADS MEASURE OVER 5MM ALSO.FRONT ROTORS MEASURE LF 1.493 RF 1.489 LR 1.182 RR 1.176.MACHINED BOTH FRONT ROTORS,AFTER MACHING ROTORS MEASURE LF 1.473 RF 1.469 DISCARD LIMIT 1.417 REROAD TEST OK.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 36 5N01 110301 F81Z 3E651 DA H21 42 20404
AWS Claim Key: 20370200 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:09-APR-2003 Doc #:126496C
Cust Comments: CUST CALLED SAYS FRONT STEERING SHOCK IS LEAKING FLUID
Tech Comments: 20411 3E651 PT CC42 INSPECTED STEERING LINKAGE,STEERING DAMPNER LEAKING.REPLACED STEERING DAMPNER,REROAD TEST OK.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 46 6E01 0110XX F81Z 25632A23 DA S07 D4 27923
AWS Claim Key: 22414867 Trx Code: P05 Labor Hrs: 0
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2004 Doc #:143020A
Cust Comments: OK REPLACE DRIVERS SEAT LOWER CUSHION PO 5 PER PAUL KEBERLY
Tech Comments: REPLACED DRIVERS LOWER SEAT CUSHION
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 46 6A06 010302 * 3824630 * F06 P3 27923
AWS Claim Key: 22414866 Trx Code: P05 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 02741 - * Name: PAT MILLIKEN FORD, INC. Ph: 313-2553100 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2004 Doc #:143020B
Cust Comments: OK REPAIR PAINT FLAKING DRIVER REAR DOOR OK PER PAUL KEBERLY P 05
Tech Comments: REPAIRED AND REFINISHED LEFT REAR DOOR
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 61 1D01 031001 * 6710 * L65 D8 38022
AWS Claim Key: 24430672 Trx Code: E72 Labor Hrs: 11.1
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:08065051
Cust Comments: DIESEL WARRTY OIL LEAKING 103 TOO DIAG ESP WARRTY
Tech Comments: PERFORMED OIL DYE TESTED. FOUND OIL LEAKING FROM THE OIL PAN GASKET. HAD TO REMOVE THE ENG. TO REPLACE THE OIL PAN GASKET. REPLACE BOTH INTAKE ORANGE SILCON HOSES AND CLAMPS.TRUBO CLAMPS CHANGE OIL FILTER. FILLED OIL AND COOLANT. ROAD TESTED. FOUND NO PROBLEMS AT THIS TIME.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 61 2E03 030008 F81Z 9C968 AB D13 42 38022
AWS Claim Key: 24430673 Trx Code: S07 Labor Hrs: 6.3
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:08065052
Cust Comments: DIESEL WARRTY TRUCK RUNNING REAL ROUGH ALSO HARD CRANK,SEE LINE 53
Tech Comments: PERFORMED DIESEL DAIG. SHEET FOUND CODE P1211. DID PIN POINT TESTED. FOUND THAT THE IPR SENSOR WAS BAD. REPLACE THE SENSOR. CLEARED CODES. ROAD TESTED. FOUND NO PROBLEMS AT THIS TIME. PERFORM HARD START DIAG,TEST GLOW PLUGS, FOUND ALL 8 HAD HIGH RESISTANCE,RPL ALL 8 GLOW PLUGS,COLD START MULTI TIMES, ALL OK
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 61 5G01 040101 2C3Z 5310 HA H21 01 38022
AWS Claim Key: 24420455 Trx Code: 0759D Labor Hrs: 5.3
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:08065054
Cust Comments: ESP WARRTY 126 TO DIAG CUST REQUEST CLUNKING IN FRONTEND AND LOOSENESS IN STEERING
Tech Comments: ROAD TESTED VERIFIED NOISE AND MEMORY STEERING RAISED AND INSPECTED FOUND BOTH FRT LEAF SPRINGS BROKEN REPLACED BOTH FRT LEAF SPRINGS ALL BALL JOINTS LOOSE BINDING DRY REPLACED ALL FRT BALL JOINTS RESET CLEARVISION ROAD TESTED O.K.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 61 7N02 011103 YC3Z 3523395 BA G07 28 38022
AWS Claim Key: 24420456 Trx Code: 0759D Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:08065055
Cust Comments: ESP WARRTY 115 TO DIAG CUST REQUEST DRIVERSIDE REAR WINDOW INOP WONT GO DOWN
Tech Comments: INSPECT AND VERIFY DRIVERS REAR POWER WINDOW INOP , REMOVE DRIVERS DOOR PANEL , POWER AT WINDOW MOTOR , FOUND OPEN CIRCUIT IN WINDOW MOTOR NESS TO REPLACE MOTOR , RETEST OPERATION OK.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 61 7C01 170503 XF1Z 14018 BA L19 41 38022
AWS Claim Key: 24430674 Trx Code: E81 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:16-MAY-2005 Doc #:08065056
Cust Comments: 3 36 115 TO DIAG DOOR AJAR LT ON AND STAYING ON
Tech Comments: INSPECT AND VERIFY DOOR AJAR LIGHT ON , HOOK UP NGS PID OUT ALL DOORS RT AND LT FRT DOORS AJAR , NESS TO REMOVE RT AND LT FRT DOOR PANELS AND LATCHES FOUND RT AND LT PINSWITCHES STICKING , REPLACE RT AND LT FRTPINSWICTHES , RETEST OPERATION OK.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 65 6J14 0114XX 6L3Z 25218A43 AA L17 41 42078
AWS Claim Key: 24864324 Trx Code: 0759D Labor Hrs: 1.6
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2005 Doc #:09151051
Cust Comments: ESP WARRTY 115 TO DIAG ALL POWER DOOR LOCKS ARE INOP
Tech Comments: INSPECT AND VERIFY ALL POWER LOCKS INOP , NESS TO REMOVE ALL 4 DOOR PANELS ,CHECK FOR POWER AT ALL ACCAUTORS POWER PRESENT FOUND OPEN CIRCUIT IN ALL 4 POWER LOCK ACCUATORS REMOVE ALL 4 DOOR LATCHES , REPLACE ALL 4 POWER LOCK ACCUATORS , RETEST OPERATION OK.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 71 1D01 030203 F7TZ 6675 BBB L65 D7 51022
AWS Claim Key: 25246768 Trx Code: 0759D Labor Hrs: 9.9
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:00917251
Cust Comments: ESP WARRTY OIL LEAKING FROM UNDER ENGINE AREA
Tech Comments: DID OIL DYE TESTED FOUND OIL LEAKING FROM THE OIL PAN,REMAIN SEAL,ORANGE SILCON HOSE,HIGH PRESSURE PUMP O RINGS. NESS TO REMOVE THE ENG. DISCHARGE A C SYSTEM. RMV ENG, RPL RUSTED THREOUGH OIL PANRNMAIN SEAL,ORAGE SILCON HOSES,AND REPLACE THE HIGH PRESSURE PUMP O RINGS. PUT BACK TOGETHER. REFILLED COOLANT .CHANGE OIL FILTER.FILLED OIL. ROAD TESTED. FOUND NO LEAKS AT THIS TIME.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 71 1G02 030008 F81Z 8501 FA L87 D1 51022
AWS Claim Key: 25246769 Trx Code: 0759D Labor Hrs: 1.7
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:00917252
Cust Comments: ESP WARRTY COOLANT LEAKING
Tech Comments: DID COOLANT PRESSURE TESTED. 15 PSI. FOUND WATER PUMP LEAKING. REPLACE THE WATER PUMP,T STAT AND GASKET. REFILLED WITH COOLANT. ROAD TESETED. FOUND NO LEAKS AT THIS TIME.
3FTSW31F3YMA51898 T/F7 F T/BC T/CD T/E A2 T/DQ T/DS 17-APR-2000 16-MAY-2000 148024 USA 71 1H03 030804 4C3Z 9J460 A E29 42 51022
AWS Claim Key: 25246770 Trx Code: 0759D Labor Hrs: 3.8
Dlr Cd-Sub Cd: 02737 - * Name: VILLAGE FORD INC Ph: 313-5653900 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:02-MAR-2006 Doc #:00917253
Cust Comments: ESP WARRTY ENGINE LT ON AND TRUCK RUNS ROUGH
Tech Comments: DID DIESEL DAIG. SHEET FOUND CODES PO476. DID PIN POINT TESTS FOUND EBP SENSOR WAS CARBON UP AND THE EBP TUBE WAS CARBON UP TO. REPLACE THE EBP SENSOR AND EBP TUBE. CLEARED CODES. ROAD TESTED. RETESTED. FOUND NO PROBLEMS AT THIS TIME
man she was a piece of work
