OASIS RESULT:
1FTSW21P06ED75008
05/15/2007
20:41:39
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/28/2006 BUILD DATE
04/13/2006 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
04/18/2007
DEALER: Murrey Motor Co., Inc.
WARRANTY CLAIM NUMBER: 037718 ODOMETER: 012883M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 6D083AA GASKET-RR COVER 001 6007D D8 FAILED GASKET/SEAL
VC 7B 002 6007A
YN 19 000 6007A38
3C3Z 6020CA GASKET CYL TIMING GE 001
5C3Z 6710AA GASKET SET-OIL PAN 004
OSP 002
3C3Z 6710BA GASKET SET-OIL PAN 001
3C3Z 6710CA GASKET SET-OIL PAN 001
3C3Z 6753AA GASKET OIL LEVEL IND 001
W300024 004
3C3Z 6619FA GASKET (OIL PUMP) 001
1F1Z 19E889AB O RING - A/C COMP 002
3C3Z 9433BE GASKET SET-MANIFOLD 001
3C3Z 6700BA OIL SEAL CYL FRT COV 001
3C3Z 6701AA CRANKSHAFT REAR SEAL 001
F8AZ 19B508AB 001
4C3Z 8507AA GASKET WATER PUMP 001
F6TZ 9160AA GSKT- FUEL FLTR BOWL 002
3C3Z 6731AA ELEMENT ASY OIL FILT 001
388898S 002
XO 15W40QSD 014
VERIFIED CONCERN, CLEAN ADD DIE AND RECHECK, LEAK VERIFIED LEAK COMING FROM BED PLATE, REPLACED GASKETS AT BEDPLATE, RETEST OK
10/11/2006
WARRANTY CLAIM NUMBER: 035903 ODOMETER: 006865M
LABOR OP
CONDITION CODE
CONDITION DESC
7E395 CABLE ASY TRNS SHIFT 000 7110A 07 IMPROPERLY ADJUSTED/FITS POORLY
CERIFIED CONCERN, ADJUSTED SHIFT LINKAGE
10/11/2006
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 2520124BB DOOR ASY-FRONT 000 24630A 07 IMPROPERLY ADJUSTED/FITS POORLY
VERIFIED CONCERN, ADJUSTED RIGHT REAR DOOR
END OF OASIS REPORT FOR 1FTSW21P06ED75008
