Standard Claims List For Model Year 2001
1FTSX31FX1EC34319 T/F7 F T/BD T/CD T/E A1 T/DQ T/DS 20-FEB-2001 28-AUG-2001 158584 USA 0 * * * * * * * 157
AWS Claim Key: 2731023 Trx Code: 01S21 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 09473 - * Name: TENVOORDE FORD, INC. Ph: 320-2510540 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:01-AUG-2001 Doc #:162726A
Cust Comments: SEATBELT BUCKLE RETENTION
Tech Comments: INSPECT SEATBELTS OK
1FTSX31FX1EC34319 T/F7 F T/BD T/CD T/E A1 T/DQ T/DS 20-FEB-2001 28-AUG-2001 158584 USA 5 1F03 03XXXX B7AZ 8287 C L87 01 5589
AWS Claim Key: 6253145 Trx Code: 2 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 01842 - * Name: MOLL FORD, INC. Ph: 320-6320770 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:15-JAN-2002 Doc #:04436001
Cust Comments: LEAKING ENGINE COOLANT.
Tech Comments: PRESSURE CHECK, LEAKING AT THE LOWER RADIATOR HOSE. BROKEN CLAMP. REPLACED CLAMP, TESTED COOLANT & ADJUSTED.
1FTSX31FX1EC34319 T/F7 F T/BD T/CD T/E A1 T/DQ T/DS 20-FEB-2001 28-AUG-2001 158584 USA 7 1B03 030204 1C3Z 6K649 BA L65 D8 8220
AWS Claim Key: 7364084 Trx Code: 2 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 01842 - * Name: MOLL FORD, INC. Ph: 320-6320770 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2002 Doc #:04537501
Cust Comments: LEAKING ENGINE OIL.
Tech Comments: EXTERNAL LEAK AT OIL COOLER. RESEALED OIL COOLER & ROAD TEST, LEAK CHECK, OK.
1FTSX31FX1EC34319 T/F7 F T/BD T/CD T/E A1 T/DQ T/DS 20-FEB-2001 28-AUG-2001 158584 USA 9 5G05 040001 * FRONT * H21 W6 11960
AWS Claim Key: 8612994 Trx Code: 2 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01842 - * Name: MOLL FORD, INC. Ph: 320-6320770 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2002 Doc #:04651501
Cust Comments: CHECK STEERING, WANDERS AT TIMES.
Tech Comments: ALIGNED VEHICLE.
1FTSX31FX1EC34319 T/F7 F T/BD T/CD T/E A1 T/DQ T/DS 20-FEB-2001 28-AUG-2001 158584 USA 15 5N01 110301 F81Z 3E651 DA C50 42 19215
AWS Claim Key: 11525252 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01842 - * Name: MOLL FORD, INC. Ph: 320-6320770 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:06-NOV-2002 Doc #:04983801
Cust Comments: STEERING DAMPER LEAKED OUT THE OIL.
Tech Comments: REPLACED STEERING DAMPER SHOCK.
1FTSX31FX1EC34319 T/F7 F T/BD T/CD T/E A1 T/DQ T/DS 20-FEB-2001 28-AUG-2001 158584 USA 22 5V02 060302 * 2001 * H05 42 35863
AWS Claim Key: 14592225 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 01842 - * Name: MOLL FORD, INC. Ph: 320-6320770 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:04-JUN-2003 Doc #:053617A
Cust Comments: CHECK ALL BRAKES. CUSTOMER STATES PEDAL FEELS SOFT.
Tech Comments: REMOVE ALL WHEELS AND INSPECT BRAKES. OK
1FTSX31FX1EC34319 T/F7 F T/BD T/CD T/E A1 T/DQ T/DS 20-FEB-2001 28-AUG-2001 158584 USA 44 2I04 NANANA F81Z 12B533 AC D03 42 77800
AWS Claim Key: 19666631 Trx Code: E72 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 01842 - * Name: MOLL FORD, INC. Ph: 320-6320770 St:MN Ctry Cd: USA Reg Cd: NA Repr Date:15-MAR-2005 Doc #:065316A
Cust Comments: CUSTOMER STATES ENGINE STARTS HARD COLD ENGINE. CHECK AND ADVISE.
Tech Comments: CONFIRM HARD START COLD ENGINE. TEST GLOW PLUGS,OKTEST AND REPLACED GLOW PLUG CONTROL RELAY. RETEST OK.
