New to the site, looking to join the 7.3 club and thinking of buying this 03.
1FTSW31P73EB99320
Thanks!
Standard Claims List For Model Year 2003
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 0 2E06 100101 3C3Z 9275 BA A85 42 70
AWS Claim Key: 805588 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 02594 - * Name: SMITH FORD-MERCURY Ph: 806-8286291 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2003 Doc #:06319652
Cust Comments: CHECK FUEL GUAGE ONLY GOES HALF WAY
Tech Comments: INOP EEC (QUICK TEST) DIAGNOSIS
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 10 2E01 * * * * * * 20901
AWS Claim Key: 3834473 Trx Code: 03B05 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:18-DEC-2003 Doc #:12733205
Cust Comments: 03B05 ICP SENSOR REPLACEMENT
Tech Comments: REPLACE ICP SENSOR PER CAMPAIGN
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 10 2G05 * * * * * * 20901
AWS Claim Key: 3834472 Trx Code: 03B06 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:18-DEC-2003 Doc #:12733206
Cust Comments: 03B06 COLD OPERATION CALIBRATION PRODUCT ENHANCEMENT
Tech Comments: PERFORM COLD SATRT CALIBRATION UPDATE PER CAMPAIGN
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 10 * * * * * * * 20901
AWS Claim Key: 3834471 Trx Code: 57B98 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:18-DEC-2003 Doc #:12733207
Cust Comments: 57B98 FREE MOTORCRAFT OIL FILTER CHANGE
Tech Comments: REPLACED OIL AND FILTER
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 18 * * * * * * * 33764
AWS Claim Key: 7785124 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2004 Doc #:14725401
Cust Comments: CAMPAIN 04S15 GROUND STUD
Tech Comments: PERFORMED 04S15 CAMPAIN
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 18 6X04 0109XX * 17683 * M05 07 33764
AWS Claim Key: 7785123 Trx Code: E84 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2004 Doc #:14725402
Cust Comments: CUSTOMER STATES THE PASSENGER SIDE MIRROR IS INOP
Tech Comments: PERFORMED CHECK AND FOUND NO POWER TO MIRROR REPAIRED WIRING HARNESS FOR MIRROR REPAIR
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 18 5S88 000615 * NPF * L69 82 33764
AWS Claim Key: 7785122 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2004 Doc #:14725403
Cust Comments: CUSTOMER STATES THE FUEL GAUGE IS INOP AFTER VEH IS FILLED, IT WILL TAKE ABOUT TWO DAYS FOR GAUGE TO
Tech Comments: PERFORMED CHECK AND CHECKED TSBS FORD IS WORKING ON REPAIR NO REPAIR AT THIS TIME INSPECTION
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 18 7T09 191001 * 14B205 * L07 07 33764
AWS Claim Key: 7766237 Trx Code: S07 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2004 Doc #:14725405
Cust Comments: CUSTOMER WOULD LIKE AUTO LOCKS TURNED OFF
Tech Comments: REPROGRAMED GEM FOR LOCK OFF FETURE
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 20 7M01 150101 * 18806 * A16 42 35283
AWS Claim Key: 8210443 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2004 Doc #:15253501
Cust Comments: CUSTOMER STATES THE C D PLAYER IS INOP
Tech Comments: ORDERD NEW C D PLAYER
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 20 7M01 150101 3C3T 18C815 AA A07 42 35283
AWS Claim Key: 8822529 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-OCT-2004 Doc #:41581209
Tech Comments: REQUESTING DEALER'S P/A CODE 08502
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 26 1D01 03XXXX 3C3Z 6701 AA L65 D8 51588
AWS Claim Key: 10351171 Trx Code: E72 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:06-APR-2005 Doc #:16507401
Cust Comments: CUSTOMER STATES OIL LEAK
Tech Comments: ENGINE OIL LEAKING, DIE TEST FOUND OIL LEAKING FROM MAIN SEAL AND OIL PUMP HOUSING. REMOVED PUMP RANGE RESEAL, REMOVED TRANS REPLACE MAINSEAL REASSEMBLE. ROAD TEST FOUND NO OTHER LEAKS
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 26 2E06 030008 3C3Z 9E527 AE D13 42 51588
AWS Claim Key: 10384040 Trx Code: E72 Labor Hrs: 3.6
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:06-APR-2005 Doc #:16507402
Cust Comments: CUSTOMER HAD FUEL FILTERS REPLACED DUE TO WATER FUEL LIGHT COMING ON, VEH. IS KNOW RUNNING ROUGH
Tech Comments: ENGINE PERFORMACE DIAG. FOUND CODE P0282. 2264 IN PCM FOUND FUEL FOUND CLEAN. DIO INJECORT BUZZ PASS KEY IN ENGINE OFF REPLACE INJ. 8 AND LOWER OTHER 7 REPLACE INJ 8 AND FUEL SEP WATER SERVO. REASSEMBLE ROAD TEST OK.
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 28 1H03 030008 4C3Z 9F452 A D36 42 56446
AWS Claim Key: 11270783 Trx Code: E72 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:28-JUN-2005 Doc #:17129801
Cust Comments: CUSTOMER STATES THE ENGINE HESSITATES AND OR MISSES UNDER LOAD ON HILLS
Tech Comments: DIAG TEST LOEO, SCAN FUEL TEST ENGINE EGR DIAG. VERIFY CUSTOMER CONCERN CIN POINT TEST. VERIFY EGR STICKING REPLACED EGR VALVE CLEAR CODES AND RETEST
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 36 1B01 03XXXX 3C3Z 6619 DA L65 D8 71532
AWS Claim Key: 13127859 Trx Code: E72 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2006 Doc #:18794901
Cust Comments: CUSTOMER STATES OIL LEAKING FROM FRONT OF ENGINE AREA SEEMS TO BE LEAKING FROM FRONT CROSS MEMBER
Tech Comments: ENGINE OIL DYE TEST FOUND OIL PUMP HOUSING LEAKING. R&I RADIATOR TO EXCESS PUMP. REPLACED CRANK SEAL RETESTED COOLING SYSTEM AFTER RAPAIR ROAD TESTED FOUND NO OTHER LEAKS
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 36 * * * * * * * 72161
AWS Claim Key: 13172605 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:18880402
Cust Comments: 59B01 TEST DRIVE CAMPAIGN
Tech Comments: PERFORMED TEST DRIVE CAMPAIGN
AWS Claim Key: 13172604 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:21-FEB-2006 Doc #:18880403
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: PERFORMED RECALIBRATION CAMPAIGN 06E17
1FTSW31P73EB99320 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 12-JAN-2003 14-MAR-2003 152555 USA 40 2H01 030008 3C3Z 6K682 BARM P59 42 78188
AWS Claim Key: 14063760 Trx Code: E72 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 08502 - * Name: COURTESY FORD LINCOLN MERCURY Ph: 503-2551771 St:OR Ctry Cd: USA Reg Cd: NA Repr Date:22-JUN-2006 Doc #:19768101
Cust Comments: CUSTOMER STATES THE TRANS IS NOT SHIFTER PROPER SMOKE COMING FROM UNDER VEH.
Tech Comments: ENGINE PERFORMANCE DIAG KEY ON ENGINE OFF PASS REPEAT TEST PASS INJECTOR BUZZ PASS KEY ON ENGINE RUNNING PASS REMOVED AIR FILTER FOUND TURBOE BLOWING OIL IN TO EXHAUST REPLACE TURBO ROAD TESTED
Thanks, it looks like it has had some oil leaking issues and a turbo replacement.
hmm... now I'm not so sure....
thanks a million for the report!
