OASIS RESULT:
1FTSW21P76EA09336
02/15/2008
21:46:34
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/13/2005 BUILD DATE
05/17/2005 SALE MILEAGE
00051
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
Standard Claims List For Model Year 2006
1FTSW21P76EA09336 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 17-MAY-2005 13-JUL-2005 172459 USA 1 7D04 170100 * 13208 * B02 42 477
AWS Claim Key: 21879 Trx Code: 1 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 07874 - * Name: GRASS VALLEY FORD-LINCOLN-MERCURY Ph: 530-2733326 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:312374A
Cust Comments: CUST STATES LEFT SIDE SKID PLATE BOLTS WERE LOOSE AND HAS TEMPORARY BOLTS IN PLACE ONLY , NEW BOLTS ARE HERE
Tech Comments: INSTALLED PROPER BOLTS TO TRANSFER CASE SKID PL ATE ON DRIVERS SIDE
1FTSW21P76EA09336 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 17-MAY-2005 13-JUL-2005 172459 USA 1 5A09 0502XX E8TZ 4676 B L88 42 477
AWS Claim Key: 21880 Trx Code: 1 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 07874 - * Name: GRASS VALLEY FORD-LINCOLN-MERCURY Ph: 530-2733326 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-JUL-2005 Doc #:312374B
Cust Comments: CUST STATES HAS FLUID LEAK FROM REAR DIFF PINION SEAL , REQUEST TO CLEAN UNDERCARRIAGE AFTER REPAIRED
Tech Comments: REPLACED REAR PINION SEAL AND FLANGE
1FTSW21P76EA09336 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 17-MAY-2005 13-JUL-2005 172459 USA 1 6N01 010806 2C3Z 99291A40 BAA B63 42 648
AWS Claim Key: 15798 Trx Code: 1 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07874 - * Name: GRASS VALLEY FORD-LINCOLN-MERCURY Ph: 530-2733326 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:29-JUL-2005 Doc #:312649A
Cust Comments: CUST STATES RIGHT SIDE BEDTOP MOLDING IS DISTORTED
Tech Comments: REPLACED MOLDING NO LABOR OP MTIME FOR THIS PARTICUALAR MOULDING
1FTSW21P76EA09336 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 17-MAY-2005 13-JUL-2005 172459 USA 6 5N01 110301 5C3Z 3304 BA H21 33 5505
AWS Claim Key: 304187 Trx Code: 1 Labor Hrs: 1
Dlr Cd-Sub Cd: 07874 - * Name: GRASS VALLEY FORD-LINCOLN-MERCURY Ph: 530-2733326 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2006 Doc #:317139A
Cust Comments: CUSTOMER REPORTS THE STEERING SEEMS TO HAVE PLAY VEHICLE WANDERS
Tech Comments: R R DRAG LINK AND INSPECTED AND ALIGNED INSPECTED AND ALIGNED CAMBE AND TOE SET
1FTSW21P76EA09336 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 17-MAY-2005 13-JUL-2005 172459 USA 6 5H01 040201 5C3Z 5560 FA H44 42 5505
AWS Claim Key: 309561 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 07874 - * Name: GRASS VALLEY FORD-LINCOLN-MERCURY Ph: 530-2733326 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2006 Doc #:317139C
Cust Comments: CUSTOMER REPORTS THE VEHICLE SEEMS TO SIT TOO LOW IN THE REAR
Tech Comments: REPLACED BOTH LEAF SPRINGS
1FTSW21P76EA09336 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 17-MAY-2005 13-JUL-2005 172459 USA 7 5I01 110204 * 3A674 * L68 33 9162
AWS Claim Key: 346051 Trx Code: 1 Labor Hrs: 2
Dlr Cd-Sub Cd: 07874 - * Name: GRASS VALLEY FORD-LINCOLN-MERCURY Ph: 530-2733326 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN-2006 Doc #:317551A
Cust Comments: CUSTOMER STATES POWER STEERING FLUID LEAK
Tech Comments: INSPECT FOR LEAK REMOVE AIR FILTER AND HOUSING REMOVE LEFT BATTERY AND TRAY FOR ACCESS TEST FOUNDSECTOR SHAFT BOLT LOOSE TIGHTEN DOWN AND LET RUN LEAK STOPPED LET SIT OVER WEEKEND INSPECT ON MONDAY NORMAL NO LEAKE REASSEMBLE VEH OK
1FTSW21P76EA09336 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 17-MAY-2005 13-JUL-2005 172459 USA 10 * * * * * * * 15523
AWS Claim Key: 837141 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07874 - * Name: GRASS VALLEY FORD-LINCOLN-MERCURY Ph: 530-2733326 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2006 Doc #:320108A
Cust Comments: EBP SENSOR,INSPECT REPLACE,CERTAIN 2004 6.0L ENGINES
Tech Comments: COMPLETED RECALL PER NOTIFICATION
