OASIS RESULT:
1FTWW31P45EC95572
02/19/2008
21:48:52
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/17/2005 BUILD DATE
04/08/2005 SALE MILEAGE
00036
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/15/2008
DEALER: Ken Knapp Ford Sales Ltd
WARRANTY CLAIM NUMBER: 200342 ODOMETER: 104759K
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9C968CA FUEL PRESSURE REG 001 051203A 42 DOES NOT OPERATE PROPERLY
4C3Z 9F838A SENSR ASY F/I TIMING 000 061706A
4C3Z 9B246A KIT-FUEL SYSTEM SERV 001 MTBOLT
3C3Z 6731AA ELEMENT ASY OIL FILT 000
4C4Z 8592AA CONNECTION-CYL HD WA 001
CHK FOR NO START-CHK OIL LEVEL/QUALITY-NO CODES-REMOVE STUCK IPR FILTER FROM O LD-WIGGLE TEST ICP/IPR--COMPLETE TSB-REMOVE SEIZED/DAMAGED BOLT FRO EXHAU ST SH IELD IN ORDER TO ACCESS IPR TO BE ABLE TO REMOVE-MONITOR-WONT GO OVER 400PSI,R EMOVE ROCKER COVERS AND AIR CHECK HIGH PRESS/OIL SYSTEM-COMPLETE TS B-REPLACE S TCFITTING-ERASE ALL CODES AND RETEST OK
01/15/2008
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65850 MOTORCRAFT BATTERY 001 10654C 42 DOES NOT OPERATE PROPERLY
000 10654C1
DIAG AND REPLACE BATTERY-NEC TO REPLACE 1 BATTERY-RETEST OK
| On-line 1878
END OF OASIS REPORT FOR 1FTWW31P45EC95572
Standard Claims List For Model Year 2005
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 6 7K11 130101 5C3Z 10849 SD G29 42 14489
AWS Claim Key: 3737353 Trx Code: S07 Labor Hrs: 1.5
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:08-FEB-2006 Doc #:16961801
Cust Comments: TACH READING AT 2700RPM AT IDLE
Tech Comments: WDS TEST PINPOINT TEST TACH REQUIRED REPLACED INSTRUMENT CLUSTER ENTER AS BUIL T DATA RETEST OK.
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 6 * * * * * * * 14489
AWS Claim Key: 3737354 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:08-FEB-2006 Doc #:16961803
Tech Comments: RECALL 05B32 COMPLETED
AWS Claim Key: 3737355 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:08-FEB-2006 Doc #:16961804
Tech Comments: RECALL 05B35 COMPLETED
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 10 6N01 010805 5C3Z 2820878 AAM B63 07 22152
AWS Claim Key: 5091661 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:01-JUN-2006 Doc #:17485001
Cust Comments: REPORT ON ALL DOOR MOULDING LIFTING PARTS ORDERED
Tech Comments: VERIFY CONCERN AND NEC TO REPLACE ALL FOUR DOOR MOULDINGS RE CHECK OK
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 10 5V09 120307 6C3Z 2A451 A C05 42 22152
AWS Claim Key: 5091662 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:01-JUN-2006 Doc #:17485002
Cust Comments: REPORT ON A/C WILL ONLY BLOW ON DEFROST MODE
Tech Comments: VERIFY CONCERN AND NEC TO REPLACE VACUUM PUMP HARNESS RE CHECK OK
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 10 6A11 010809 4C3Z 16450 CAA F11 D7 22152
AWS Claim Key: 5124725 Trx Code: E84 Labor Hrs: 1.2
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:01-JUN-2006 Doc #:17485003
Cust Comments: REPORT ON RUST ON REAR BUMPER AND BOTH RUNNING BOARDS
Tech Comments: VERIFY CONCERN AND NEC TO REPLACE REAR BUMPER AND BOTH RUNNING BOARDS RE CHECK OK
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 11 6N04 010802 5C3Z 16720 NA B63 81 24451
AWS Claim Key: 5258396 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:12-JUL-2006 Doc #:17680501
Cust Comments: REPORT ON ALL F 350 EMBLEMS PEELING
Tech Comments: VERIFY CONCERN AND NEC TO REPLACE TAILGATE EMBLEM AND PASS FRT EMBLEM
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 12 6A13 010203 * 16005 * F13 P3 25030
AWS Claim Key: 5384229 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:17-JUL-2006 Doc #:17699901
Cust Comments: REPORT ON DULL PAINT ON RT FRT FENDER
Tech Comments: INSPECT FOR DULL PAINT ON DOOR AND FENDER FOUND TO BE CHALKING BASE COAT ON FE NDER AND RIGHT FRONT DOOR DETRIM BOTH PANELS AND REFINISH FAIRVIEW PO#65076 CHALKING HAS MAY CAUSES 1/ INSUFFICIENT CURING OF THE PRIMER BEFORE APPLICATION OF THE TOPCOAT 2/ TOO THIN OF FEW COATS OF TOPCOAT WERE APPLIED 3/INADEQUATE FLASH TIME BE
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 12 6P07 010301 * 3820124 * F13 P3 25030
AWS Claim Key: 5418025 Trx Code: E84 Labor Hrs: 0
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:17-JUL-2006 Doc #:17699902
Cust Comments: REPAIR DULL PAINT ON RIGHT FRONT DOOR
Tech Comments: OSL SUBLET BODYSHOP FAIRVIEW COLL TO PAINT DOOR AS NEC TOO THIN OR FEW COATS OF TOPCOAT APPLIED
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 16 1H03 030804 3C3Z 9P455 AB D42 55 37207
AWS Claim Key: 6632467 Trx Code: E84 Labor Hrs: 2
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:08-DEC-2006 Doc #:18355401
Cust Comments: REPORT NO POWER MORE POWER BEFORE
Tech Comments: IDS TESTS, PINPOINT TESTS, DTC P0404. PERFORMED EGR CLEANING AND POSITION TEST REPROGRAMMED TO LATEST UPDATES. RETESTED OPERATION OK.
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 30 2E04 03XXXX 4C3Z 9B246 A D50 42 65094
AWS Claim Key: 9345969 Trx Code: E72 Labor Hrs: 10.2
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:15-JAN-2008 Doc #:20034201
Cust Comments: REPORT ON CRANKS OVER BUT NO START INTERMITTENT
Tech Comments: CHK FOR NO START CHK OIL LEVEL/QUALITY NO CODES REMOVE STUCK IPR FILTER FROM O LD WIGGLE TEST ICP/IPR COMPLETE TSB REMOVE SEIZED/DAMAGED BOLT FRO EXHAUST SH IELD IN ORDER TO ACCESS IPR TO BE ABLE TO REMOVE MONITOR WONT GO OVER 400PSI,R EMOVE ROCKER COVERS AND AIR CHECK HIGH PRESS/OIL SYSTEM COMPLETE TSB REPLACE S TCFITTING ERASE ALL CODES AND RETEST OK
1FTWW31P45EC95572 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 08-APR-2005 17-AUG-2005 4B8046 CAN 30 7A01 140101 BXT 65 850 C26 42 65094
AWS Claim Key: 9374309 Trx Code: BAT03 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B8046 - * Name: KEN KNAPP FORD SALES LTD Ph: 519-7766447 St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:15-JAN-2008 Doc #:20034206
Cust Comments: WEAK OR LOW ELECTICAL POWER
Tech Comments: DIAG AND REPLACE BATTERY NEC TO REPLACE 1 BATTERY RETEST OK
