OASIS RESULT:
1FTNX21F2XEA23860
02/19/2008
21:52:19
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1999 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
ZF M6HD-C 6-SPEED AXLE CODE
31 ENGINE CALIBRATION
WARNING MESSAGES
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/09/1998 BUILD DATE
03/13/1998 SALE MILEAGE
07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION / REPLACEMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
| On-line 1878
END OF OASIS REPORT FOR 1FTNX21F2XEA23860
Standard Claims List For Model Year 1999
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 11 * * * * * * * 26719
AWS Claim Key: 1094594 Trx Code: 98B32 Labor Hrs: 0.7
Dlr Cd-Sub Cd: B6215 - * Name: CARSTAIRS FORD SALES 1983 Ph: 403-3373393 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:03-MAR-1999 Doc #:072159B
Cust Comments: BRAKE SHIELDS
Tech Comments: PERFORMED RECALL
AWS Claim Key: 1094595 Trx Code: 98S17 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B6215 - * Name: CARSTAIRS FORD SALES 1983 Ph: 403-3373393 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:03-MAR-1999 Doc #:072159C
Cust Comments: INSPECT STEER SHAFT
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 19 7M01 150102 * 18806 * A15 42 32229
AWS Claim Key: 5229226 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08299 - * Name: 20TH CENTURY FORD Ph: 208-7851900 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-1999 Doc #:03762151
Cust Comments: STATES THAT THE CD PLAYER IS NOT WORKING
Tech Comments: CD PLAYER IN OP PULL AND SEND OUT FOR REPAIRS INSTALL EXCHANGE
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 19 7W05 170503 XF1Z 10B987 AA L19 28 32229
AWS Claim Key: 5229227 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: 08299 - * Name: 20TH CENTURY FORD Ph: 208-7851900 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-1999 Doc #:03762152
Cust Comments: STATES THAT THE DOOR AJAR LIGHT COMES ON WHEN VEHICLE SITS IN THE HEAT DOME LIGHT FLICKERS ON OFF
Tech Comments: TEST SWTCHES FOUND DRIVERS DOOR SWTCH OPEN REPLACED DOOR AJAR SWTCH
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 19 7M01 150102 * 18C868 * A99 42 32229
AWS Claim Key: 6002533 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 67789 - * Name: SPEED-O-TACH, INC Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-1999 Doc #:20223207
Tech Comments: REQUESTING DEALER'S P/A CODE 08299
AWS Claim Key: 8931619 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 67789 - * Name: SPEED-O-TACH, INC Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-1999 Doc #:64624107
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 23 2B03 NANANA F81Z 12B533 AC D03 42 39683
AWS Claim Key: 7089882 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 08362 - * Name: BROADWAY FORD, INC. Ph: 208-5258500 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2000 Doc #:06355651
Cust Comments: HARD TO START WHEN COLD
Tech Comments: TEST GLOW PLUG SYS FOUND RELAY DEFECTIVE REPLACED RELAY
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 23 * * * * * * * 39683
AWS Claim Key: 7089883 Trx Code: 99S32 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08362 - * Name: BROADWAY FORD, INC. Ph: 208-5258500 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:02-FEB-2000 Doc #:06355653
Cust Comments: RECALL 99S32 AS PER LETTER NOTICE
Tech Comments: RECALL COMPLETED 99S32 COMPLETED
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 27 5T01 031801 F81Z 9F836 AB D03 42 43177
AWS Claim Key: 9405827 Trx Code: E72 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08362 - * Name: BROADWAY FORD, INC. Ph: 208-5258500 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:06-JUN-2000 Doc #:06888451
Cust Comments: THROTTLE SEEMS TO STICK VEHILCE WONT STAY AT STEADY SPEED GOES UP AND DOWN AND DOESNT SEEM TO HAVE ANY POWER WHEN TOWING
Tech Comments: ACCELERATOR PEDAL DEFECTIVE EEC (QUICK TEST) DIAGNOSIS
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 27 6R07 012005 F81Z 14B268 AA S39 42 44015
AWS Claim Key: 9948046 Trx Code: P05 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 08362 - * Name: BROADWAY FORD, INC. Ph: 208-5258500 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2000 Doc #:06958451
Cust Comments: AIR BAG LIGHT STAYS ON INSTALL SOP
Tech Comments: AIR BAG SWTCH MALFUNCTION AIR BAG RESTRAINT SYSTEM DIAGNOSIS
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 43 2E03 030400 * 9C968 * D41 42 64023
AWS Claim Key: 19557892 Trx Code: E72 Labor Hrs: 4
Dlr Cd-Sub Cd: 08484 - * Name: MADISON FORD-MERCURY, INC. Ph: 208-3563636 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:16-OCT-2001 Doc #:147145A
Cust Comments: SURGES AT 2000 RPMS IN 2ND AND THIRD GEAR
Tech Comments: TEST AND REPLACE CMP SENSOR AND I.P.R.
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 48 4B01 080201 F81Z 7548 AC P09 41 74674
AWS Claim Key: 20380505 Trx Code: SPW Labor Hrs: 4.2
Dlr Cd-Sub Cd: 08299 - * Name: 20TH CENTURY FORD Ph: 208-7851900 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:07-MAR-2002 Doc #:05516351
Cust Comments: CUST STATES THAT THE CLUTCH IS SQUEELING WHEN DEPRESS THE PEDAL
Tech Comments: THROW OUT BEARING SEIZED MANUAL TRANSMISSION ASSEMBLY REMOVE AND INSTALL
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 52 4B03 080203 F81Z 7A543 FA P09 42 80644
AWS Claim Key: 21286860 Trx Code: SPW Labor Hrs: 1.1
Dlr Cd-Sub Cd: 08299 - * Name: 20TH CENTURY FORD Ph: 208-7851900 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:16-JUL-2002 Doc #:05783751
Cust Comments: PARTS WARRANTY ON MASTER CYLINDER
Tech Comments: MASTER CYLINDER NO GOOD CYLINDER ASSEMBLY CLUTCH MASTER REPLACE
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 53 4B03 080203 F81Z 7A512 AA P09 42 81607
AWS Claim Key: 21327904 Trx Code: SPW Labor Hrs: 1.1
Dlr Cd-Sub Cd: 08299 - * Name: 20TH CENTURY FORD Ph: 208-7851900 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:23-JUL-2002 Doc #:05798551
Tech Comments: MASTER CYLINDER WONT HOLD PRESSURCYLINDER ASSEMBLY CLUTCH MASTER REPLACE
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 53 3M05 070301 1C3Z 7124 BA P09 42 82101
AWS Claim Key: 21666670 Trx Code: P01 Labor Hrs: 10.3
Dlr Cd-Sub Cd: 08299 - * Name: 20TH CENTURY FORD Ph: 208-7851900 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:30-JUL-2002 Doc #:05813451
Cust Comments: CUSTOMER STATES TRANS GRINDS IN GEAR
Tech Comments: REPLACED SYNCHRO
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 59 2B01 030701 F7TZ 12K073 A D02 46 86021
AWS Claim Key: 22148259 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 08484 - * Name: MADISON FORD-MERCURY, INC. Ph: 208-3563636 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:11-FEB-2003 Doc #:00013201
Cust Comments: WONT START
Tech Comments: TEST AND REPLACE SENSOR
1FTNX21F2XEA23860 T/F7 F T/BD T/BD T/E A1 T/VF T/DS 13-MAR-1998 09-APR-1998 4B6215 CAN 68 * * * * * * * 95556
AWS Claim Key: 22745165 Trx Code: 02S34 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 08484 - * Name: MADISON FORD-MERCURY, INC. Ph: 208-3563636 St:ID Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2003 Doc #:00402401
Cust Comments: 02S34 RECALL
Tech Comments: PERFORM RECALL 02S34
Discussion Starter · #5 ·
07S57
I am bit confused here (but maybe I am not reading this correctly) doesn't it state further down in the report that this was replaced? Also, should I be concerned about the tranny stuff?
