I'm down to these! Great reports! If this many is too much hassle, please run one. I figured it'd be easier in one email rather than fill up a bunch of posts.
1FTWW33P04ED72837
1FTSW21P96EB54975
1FTSW21P55EC63061
1FTSW21P96EA89366
1FTWW33P35EC21587
Thanks.
OASIS RESULT:
1FTWW33P04ED72837
02/19/2008
22:02:30
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
10/02/2004 BUILD DATE
05/21/2004 SALE MILEAGE
00363
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
| On-line 1878
END OF OASIS REPORT FOR 1FTWW33P04ED72837
Standard Claims List For Model Year 2004
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 2 2E06 030402 * 9A543 * D02 42 5023
AWS Claim Key: 2500500 Trx Code: 2 Labor Hrs: 14
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2004 Doc #:05416751
Cust Comments: CUST STATES CRANK NO START
Tech Comments: SSEMBLE VEH, REFILL OIL & COOLANT, ROAD TEST, REPROGRAM PCM, TCM & FICM. REMOVE TURBO, INTAKE MANIFOLD, COOLING FAN, BELT & VARIOUS OTHER PARTS TO ACCESS SPENT EXCESSIVE TIME WITH HOTLINE TO DETERMINE CAUSE CONTACT ID 109431698, REPORT #4KHEA003, SPOKE WITH
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 10 3A03 * * * * * * 12360
AWS Claim Key: 6091614 Trx Code: 04B24 Labor Hrs: 11.6
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:06571951
Cust Comments: RECALL #04B24 DELAYED SHIFT
Tech Comments: TRAN R&I COMPLETER TRANS OVERHAUL INCLUDING VALVE BODY REPLACE OTA FLUSH LINES, INSTALL REMOTE TRANS FILTER KOT RECALL 04B24
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 10 * * * * * * * 12360
AWS Claim Key: 6091615 Trx Code: 05S34 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:06571952
Cust Comments: RECALL #05S34
Tech Comments: RECALL 05S34 INSTALL FICM REPAIR KIT & ICP CONNECTOR PER RECALL 05S34, OP E
AWS Claim Key: 6110209 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:06571953
Cust Comments: RECALL #59B01
Tech Comments: RECALL 59B01 CUST ASSURANCE TEST
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 10 6J01 011401 XF1Z 5421970 AA L17 42 12360
AWS Claim Key: 6091616 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2005 Doc #:06571954
Cust Comments: CUST STATES DRIVERS DOOR WILL NOT UNLOCK WITH KEY
Tech Comments: R AND R PANEL TO REPL.ARM ON LOCK CYLINDER,CAME APART
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 10 2H01 030008 5C3Z 6K682 AA D36 42 12980
AWS Claim Key: 6253080 Trx Code: S07 Labor Hrs: 9.5
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2005 Doc #:06631051
Cust Comments: CUST STATES BLOWS BLACK SMOKE AND SLUGGISH
Tech Comments: PERFORM DIESEL DIAG 6005F F23, CODES P0401, P2293,P2296, MONITOR PID DATA, FOUND STUCK EGR VALVE, BIASED EBP SENSOR, TURBO OVERBOOST CONDITION, REMOVE EGR VALVE, FOUND EXCESSIVE CARBON BUILDUP, REMOVE EGR COOLER AND INTAKE MANIFOLD TO CLEAN, REPLACE REPLCE EGR VALVE, EBP SENSOR, TURBO ASSY AND LEAKING TURBO INLET Y PIPE, PROGRAMPCM, TCM, FICM, TO LATEST CALIB ROAD TEST APPROX 25 MILES, CNV
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 16 5A09 050201 5C3Z 4676 AA L88 D1 15047
AWS Claim Key: 8180757 Trx Code: E84 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:05-JAN-2006 Doc #:07344951
Cust Comments: CUST STATES PINION SEAL LEAKING
Tech Comments: INSPECT REAR END FOR LEAK FOUND OIL LEAKING AT PINION SEAL REPLACED TOPED OFF OIL LEVEL
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 16 2A01 031202 5C3Z 6C646 DA N59 42 15242
AWS Claim Key: 8280863 Trx Code: E84 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:12-JAN-2006 Doc #:07377151
Cust Comments: CUST STATES LOUD NOISE IN ENGINE AND LOW POWER
Tech Comments: VERIFIED CONCERN, PERFORM DIESEL TESTS 6005F F12, FOUND HOLE IN INTERCOOLER TUBE CAUSING LOW BOOST PRESSURE, REPLACE CAC TUBE, REPROGRAM PCM, FICM, TCM TO LATEST CALIBRATION, ROAD TEST 10 MILES, COULD NOT REVERIFY CONCERN
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 20 * * * * * * * 17989
AWS Claim Key: 9405149 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2006 Doc #:07943751
Cust Comments: RECALL 05E15 DPFE
Tech Comments: RECALL 05E15 REPLACE EBP SENSOR PER RECALL 05E15
AWS Claim Key: 9405150 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2006 Doc #:07943752
Cust Comments: RECALL 59B01 TEST DRIVE
Tech Comments: RECALL 59B01 CUSTOMER ASSURANCE ROAD TEST
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 20 2E06 030008 4C3Z 9E527 AA D42 42 17989
AWS Claim Key: 9493444 Trx Code: S07 Labor Hrs: 5.9
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2006 Doc #:07943753
Cust Comments: CUST STS RUNS ROUGH WHEN COLD FOR ABOUT 1ST 15 MIN.S THEN SEEMS OK AFTER WARMED
Tech Comments: VERIFIED CONCERN, PERFORM FOLLOWING DIESEL ENGINE TESTS, 6005F F33, NO CODES AVAILABLE, PERFORM POWER BALNCE TESTS, & INJECTOR INTERRUPT TESTS, FOUND LOW PEAKS ON INJECTORS 2 3 8, REPLACE INJECTORS TO REPAIR, 2 LEFT BANK, 1 RIGHT BANK, ROAD TEST APROX 15 MILES WHEN COLD, COULD NOT REVERIFY CONCERN. OASIS CODE 215 581 739, NO TSBS OR SSMS FOR CONCERN.
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 20 5A06 050201 3C3Z 4880 AB K03 42 17989
AWS Claim Key: 9493445 Trx Code: E84 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:15-MAY-2006 Doc #:07943755
Cust Comments: CUST STS REAR AXLE CHATTER WHEN TOWING LIGHT LOADS
Tech Comments: NOISY REAR AXLE ASSEMBLY IN VEHICLE DIAGNOSIS
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 25 2E03 030402 4C3Z 9E527 AA D42 42 24818
AWS Claim Key: 10517578 Trx Code: S07 Labor Hrs: 4.7
Dlr Cd-Sub Cd: 04888 - * Name: SANTA FE FORD, INC. Ph: 386-4622802 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-OCT-2006 Doc #:03780701
Cust Comments: C/SENGINE/TRUCK HAS NO POWER SOUNDS ROUGH
Tech Comments: VERIFY CONCERN IDS DIAG.. INJECTOR BUZZ TET POWER BALANCE TEST FUEL CK. AIR CK. KOEO PASS KOERE PASS CONT. PASS.. START ENGINE COLD FOUND CYLS.# 1,3,6, SKIPPING/MISSING REMOVE AND REPLACE FAULTY FUEL INJECTORS ON #1,3,6, CYL.. CLEANED EGR VALVE RETEST AFTER REPAIR
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 28 1H03 030804 4C3Z 9P456 AF L87 D1 27709
AWS Claim Key: 11104594 Trx Code: S07 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2007 Doc #:08889651
Cust Comments: CUST STATES COOLANT LEAK
Tech Comments: LEAKING EGR COOLER ASSEMBLY REPLACE
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 28 2E03 030402 4C3Z 9E527 AA D13 42 27709
AWS Claim Key: 11104595 Trx Code: S07 Labor Hrs: 6.1
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2007 Doc #:08889654
Cust Comments: CUST STS RUNS ROUGH IN A.M.
Tech Comments: VERIFIED CONCERN, PERFORM DIESEL TESTS 6005FF33, INJECTOR INTERUPT TEST DETERMINED LOW CONTRIBUTION ON CYLS 4 & 7, REPLACE INJECTORS TO REPAIR, 1 L 1 RIGHT BANK, RETEST, COULD NOT REVERIFY, REPROGRAM PCM, TCM & FICM TO LATEST CALIBRATION, ROAD TEST COULD NOT REVERIFY CONCERN.
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 28 2H01 030407 6C3Z 9T515 A N59 42 27709
AWS Claim Key: 11104596 Trx Code: E84 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2007 Doc #:08889655
Cust Comments: CUST STS AFTER ENGINE IS WARMED OR UNDER LOAD HEARS WOOOP NOISE AFTER LETTING OFF ACCELERATOR
Tech Comments: VERIFIED CONCERN, FOUND HIGH BOOST PRESSURE WHEN NOISE OCCURS, PERFORM TSB 062302 OP B, REMOVE, DISASSEMBLE, CLEAN & REINSTALL TURBO CHARGER, ROAD TEST, COULD NOT REVERIFY CONCERN
1FTWW33P04ED72837 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 21-MAY-2004 02-OCT-2004 124009 USA 28 2E03 030402 4C3Z 9E527 AA D42 42 27709
AWS Claim Key: 11104597 Trx Code: E91 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 04989 - * Name: PLANTATION FORD Ph: 954-5842400 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:06-JAN-2007 Doc #:08889656
Cust Comments: ENGINE RUNS ROUGH SPW
Tech Comments: PERFORM TEST 6005F33, LOW CONTRIBUTION CYL 7 AFTER 10 MILE ROAD TEST, SVC PART INJECTOR 7 RIGHT BANK, ROAD TEST, COULD NOT REVERIFY CONCERN
OASIS RESULT:
1FTSW21P96EB54975
02/19/2008
22:03:31
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2006 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
6F710D0A
ARN MESSAGES
WARRANTY START DATE
11/21/2005 BUILD DATE
10/16/2005 SALE MILEAGE
EXTENDED COVERAGES
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P96EB54975
OASIS RESULT:
1FTSW21P55EC63061
02/19/2008
22:04:11
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
ARN MESSAGES
WARRANTY START DATE
04/09/2005 BUILD DATE
03/01/2005 SALE MILEAGE
EXTENDED COVERAGES
10/15/2007
DEALER: Northside Ford
WARRANTY CLAIM NUMBER: 563050 ODOMETER: 033426M
LABOR OP
CONDITION CODE
CONDITION DESC
7C3Z 3504A GEAR ASY-STEERING 001 3504A 41 STICKS/BINDS/GRABS
XT 5BM 002 3001A
000 3001A6
GEAR BOX BINDING. ROAD TEST TO VERIFY CONCERN. INSPECT STEERING, LOOSEN LINK AGE GEAR BOX BINDING. REPLACE GEAR BOX, PURGE SYSTEM, CK ALIGNMENT & SET TOE . ROAD TEST AFTER REPAIR, OK
10/08/2007
WARRANTY CLAIM NUMBER: 562348 ODOMETER: 033066M
LABOR OP
CONDITION CODE
CONDITION DESC
BXT 65750 MOTORCRAFT BATTERY 002 10654CA 42 DOES NOT OPERATE PROPERLY
000 10654C1T
DEAD CELLS. CHARGING SYSTEM TEST 14.1 VOLTS 130 AMPS. TEST AND REPLACE BOTH BATTERIES. SERVICE CABLES & RD. TEST.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P55EC63061
Standard Claims List For Model Year 2005
1FTSW21P55EC63061 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 09-APR-2005 152056 USA 11 * * * * * * * 11044
AWS Claim Key: 3482976 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:49616501
Cust Comments: A99 C S PERFORM RECALL 05B35 RECALIBRATE ENGINE CONTROL MODULES
Tech Comments: REPROGRAM PCM PER 05B35 CAMPAIGN
1FTSW21P55EC63061 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 09-APR-2005 152056 USA 11 7S02 180102 * 10817 * L69 X2 11044
AWS Claim Key: 3482975 Trx Code: 2 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:49616502
Cust Comments: L69 C S VEH FUEL GAUGE READS FULL AND CUS CAN STILL ADD FUEL TO IT EVEN AFTER DRIVING 200 MILES THE FUEL GUAGE READS FULL UNTIL ABOUT 15 MILES LEFT SEE DAVE FIRST
Tech Comments: GROUND LOOSE NOT AMKING GOOD CONTACT CAUSING FUEL GAUGE TO READ ERRATIC. ROAD TEST VEHICLE TO VERIFY CONCERN. REINSTALL GROUND WIRE AT G 300
AWS Claim Key: 3482974 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:49616504
Cust Comments: A99 C S PERFORM RECALL 05B32 DE GAS FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: 05B32, PERFORM RECALL, INSTALL LABEL
1FTSW21P55EC63061 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 09-APR-2005 152056 USA 11 2G04 000615 * DIAG * D35 42 11044
AWS Claim Key: 3482973 Trx Code: 2 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-FEB-2006 Doc #:49616505
Cust Comments: D50 C S VEH IS GETTING POOR FUEL MILEAGE AT 11 MILES A GAL,
Tech Comments: ROAD TEST VEHICLE TO VERIFY CONCERN. EEC TEST PASS, DCL DISPLAY, PERFORM BOOST TEST 24 PSI. VEHICLE WORKING TO SPECS 214 456 675. UNABLE TO DUPLICATE OWNER CONCERN THIS REPAIR VISIT
1FTSW21P55EC63061 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 09-APR-2005 152056 USA 16 5V09 120307 6C3Z 2A451 A C20 28 15497
AWS Claim Key: 5406359 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-JUL-2006 Doc #:51639901
Cust Comments: C19 C S AC JUST STATED BLOWING OUT OF DEFROST VENTS ONLY
Tech Comments: OPEN CIRCUIT CAUSING A C TO BLOW OUT DEFORSTER ONLY. REPLACE ELECTRIC VACUUM MOTOR
1FTSW21P55EC63061 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 09-APR-2005 152056 USA 31 7A01 140101 BXT 65 750 D02 42 33066
AWS Claim Key: 8742863 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-OCT-2007 Doc #:56234801
Cust Comments: CUSTOMER STATES: HAS HAD A HARD TIME STARTING FOR A WEEK. BATTERY LOW, HAD TO JUMP START.
Tech Comments: DEAD CELLS. CHARGING SYSTEM TEST 14.1 VOLTS 130 AMPS. TEST AND REPLACE BOTH BATTERIES. SERVICE CABLES & RD. TEST.
1FTSW21P55EC63061 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 01-MAR-2005 09-APR-2005 152056 USA 31 5O01 110201 7C3Z 3504 A H22 41 33426
AWS Claim Key: 8794624 Trx Code: E84 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-OCT-2007 Doc #:56305001
Cust Comments: H22 OWNER STATES CK STEERING HARD TO TURN
Tech Comments: GEAR BOX BINDING. ROAD TEST TO VERIFY CONCERN. INSPECT STEERING, LOOSEN LINKAGE GEAR BOX BINDING. REPLACE GEAR BOX, PURGE SYSTEM, CK ALIGNMENT & SET TOE. ROAD TEST AFTER REPAIR, OK
OASIS RESULT:
1FTSW21P96EA89366
02/19/2008
22:05:48
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
6F710D0A
ARN MESSAGES
WARRANTY START DATE
12/07/2005 BUILD DATE
08/11/2005 SALE MILEAGE
EXTENDED COVERAGES
08/25/2007
DEALER: Cecil Atkission Ford
WARRANTY CLAIM NUMBER: 123471 ODOMETER: 014867M
LABOR OP
CONDITION CODE
CONDITION DESC
7000 TRANSMISSION ASY-AUT 000 7000F 42 DOES NOT OPERATE PROPERLY
TEST DROVE VEHICLE WITH CUSTOMER AND ABLE TO VERIFY CUSTOMER CONCERN. HOOK U P IDS AND RUN ELECTRICALTEST ON TRANSMISSION. ALL PASS CODES. ACCESS PIDS AN D MONITOR SENSORS. ALL OK AT THIS TIME. CONCERN IS NORMAL.
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P96EA89366
Standard Claims List For Model Year 2006
1FTSW21P96EA89366 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2005 07-DEC-2005 152718 USA 11 1H03 030804 5C3Z 9J460 A E29 04 8527
AWS Claim Key: 1969062 Trx Code: S07 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 04589 - * Name: CECIL ATKISSION FORD Ph: 830-4265391 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2006 Doc #:118086A
Cust Comments: CHECK ENGINE OR SERVICE ENGINE SOON LIGHT ON.
Tech Comments: CONCERN VERIFIED.HOOK UP IDS AND RUN EEC VQUICK TESTS.CODE P0460 IN MEMORY. FLUID LEVEL INDICATOR SENSOR CIRCUIT MALFUNCTION.RUN PINPOINT.RUN INSTRUMENT CLUSTER QUICK TESTS AS PER PINPOINT TESTS QH1 AND QH2 OK.REPROGRAM PCM,TCM, AND FICM AS PER TSP 06 13 11.TEST DRIVE OK. REPIAR VERIFIED.
1FTSW21P96EA89366 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2005 07-DEC-2005 152718 USA 11 2H01 030407 5C3Z 6K682 DA E29 42 8852
AWS Claim Key: 2143462 Trx Code: S07 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 04589 - * Name: CECIL ATKISSION FORD Ph: 830-4265391 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:23-OCT-2006 Doc #:118281A
Tech Comments: CONCERN VERIFIED.HOOK UP IDS AND RUN EEC V QUICK TESTS.KOEO PASS,KOER PASS,KOEC P0299 TURBO BOOST.RUN PINPOINT TESTS.CLEAR CODE,ACCESSED MGP PID AND TEST DRIVE GOES TO 25 PSI BOOST AT WIDE OPEN THROTTLE OK CHECK CIRCUITS AND CONNECTOR TO VGT SOLENOIDOK. CALLED HOTLINE AND SPOKE TO DAN WAS ADVISED T O REMOVE TURBO AND DISASSEMBLE TO CK FOR RUST.REMOVE TURBO FOUND EXCESSIVE AMOUNTS OF RUST INSIDE TU
1FTSW21P96EA89366 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 11-AUG-2005 07-DEC-2005 152718 USA 21 3A11 070100 * 7000 * P51 42 14867
AWS Claim Key: 4427582 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04589 - * Name: CECIL ATKISSION FORD Ph: 830-4265391 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-AUG-2007 Doc #:123471A
Cust Comments: C S TRANSMISSION SLIPPING
Tech Comments: TEST DROVE VEHICLE WITH CUSTOMER AND ABLE TO VERIFY CUSTOMER CONCERN. HOOK UP IDS AND RUN ELECTRICALTEST ON TRANSMISSION. ALL PASS CODES. ACCESS PIDS AND MONITOR SENSORS. ALL OK AT THIS TIME. CONCERN IS NORMAL.
OASIS RESULT:
1FTWW33P35EC21587
02/19/2008
22:06:47
FCXWS446
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
4N ENGINE CALIBRATION
ARN MESSAGES
WARRANTY START DATE
02/25/2005 BUILD DATE
01/30/2005 SALE MILEAGE
EXTENDED COVERAGES
| On-line 1878
END OF OASIS REPORT FOR 1FTWW33P35EC21587
1FTWW33P35EC21587 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-JAN-2005 25-FEB-2005 152745 USA 3 6H19 011103 F81Z 2521452 AA B66 34 1491
AWS Claim Key: 952659 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 08233 - * Name: ACCESS FORD, LTD. Ph: 361-2653673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2005 Doc #:040439A
Cust Comments: C S EXTERIOR WINDOW SCRAPERS AT BOTH FRONT DOORS ARE WARPED
Tech Comments: 1491 VERIFIED CONCERN REMOVED AND REPLACED WEATHER STRIP ON BOTH DOORS (WINDOW SCRAPERS) FRONT DOORS ALSO REPLACED DRIVERS REAR DOOR WEATHER STIP(WINDOW SCRAPER)
1FTWW33P35EC21587 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-JAN-2005 25-FEB-2005 152745 USA 3 7M81 150301 * 18808 * A06 42 1491
AWS Claim Key: 952660 Trx Code: 2 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08233 - * Name: ACCESS FORD, LTD. Ph: 361-2653673 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:20-MAY-2005 Doc #:040439B
Cust Comments: C S DRIVERS SIDE DOOR SPEAKER RATTLES WHEN PLAYED
Tech Comments: 1491 TO RADIO SALES AND SERVICE FOR DIAGNOSIS; REPLACED DOOR SPEAKER
1FTWW33P35EC21587 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-JAN-2005 25-FEB-2005 152745 USA 14 2H01 031202 5C3Z 6K775 AA D42 01 16758
AWS Claim Key: 4142371 Trx Code: S07 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 04520 - * Name: CHUCK BROWN FORD Ph: 979-7434111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2006 Doc #:07741401
Cust Comments: CUST STATE ENGINE STARTED BACKFIRING CUST HEARD ONE LOUD POP AND ENGINE LOST POWER CHECK ENGINE LIGHT CAME ON AND BLOWING BLACK SMOKE
Tech Comments: DIESEL ENGINE DIAG FOUND BLOWN TURBO INTERCOOLER REPLACED INTERCOOLER AND RETEST CHECK FOR TURBO BOOST OK
1FTWW33P35EC21587 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-JAN-2005 25-FEB-2005 152745 USA 14 * * * * * * * 16758
AWS Claim Key: 4142372 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04520 - * Name: CHUCK BROWN FORD Ph: 979-7434111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2006 Doc #:07744001
Cust Comments: RECALL 05B32 DE GAS BOTTLE FILL LEVEL LABEL
Tech Comments: INSTALLED LABEL PER RECALL
AWS Claim Key: 4142373 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04520 - * Name: CHUCK BROWN FORD Ph: 979-7434111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:29-MAR-2006 Doc #:07744002
Cust Comments: RECALL 05B35 CONTROL MODULE RECALIBRATION
Tech Comments: RECALIBRATE PER RECALL
1FTWW33P35EC21587 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-JAN-2005 25-FEB-2005 152745 USA 15 2H01 030008 5C3Z 6K682 CA D42 42 17089
AWS Claim Key: 4484546 Trx Code: S07 Labor Hrs: 4
Dlr Cd-Sub Cd: 04520 - * Name: CHUCK BROWN FORD Ph: 979-7434111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2006 Doc #:07784901
Cust Comments: CUST STATES THROTTLE HAS VERY SLOW OR NO RESPONSE AT TIMES HEARS POPPING NOISE WHEN LET OFF ACCEL BLOWS BLACK SMOKE CHECK ENGINE LIGHT CAME ON
Tech Comments: EEC TEST DIESEL ENGINE PERFORMANCE DIAG P0238 P0299 P0478 REPLACED EGR VALVE VGT SENSOR AND TURBO CHARGER ASSEMBLY AND RETEST
1FTWW33P35EC21587 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 30-JAN-2005 25-FEB-2005 152745 USA 24 7A01 140101 BXT 65 750 D03 42 23302
AWS Claim Key: 7056587 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04520 - * Name: CHUCK BROWN FORD Ph: 979-7434111 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:31-JAN-2007 Doc #:08206503
Cust Comments: CUSTOMER LETS TRUCK SIT FOR 10 DAYS AT A TIME AND HAS HAD TROUBLE STARTIND AFTER THESE PERIODS
Tech Comments: ELECTRICAL DIAG FOUND BOTH BATTERIES BAD REPLACED
