OASIS RESULT:
1FTSW21P35EA45636
02/28/2008
21:38:19
FCXWS446
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/31/2005 BUILD DATE
08/21/2004 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
2169 - CAN 2007 NEW 60/300000 DIESELCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 CAD
OWNER NAME: ROBERT VANNESTE
OPTIONS:
EXPIRATION DATE: 03/31/2010
DISTANCE: 300,000
RENTAL: 35 UP TO 10 DAYS
TOWING: 0 CAD
CONTRACT SOLD BY: CAN A4620
ESP CONTRACT START DATE: 03/31/2005
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
WARRANTY REPAIR HISTORY
07/16/2007
DEALER: Cardeager Ford Sales Ltd.
WARRANTY CLAIM NUMBER: 034448 ODOMETER: 159479K
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9C968CA FUEL PRESSURE REG 001 061706A 01 BROKEN/CRACKED
5C4Z 9A543B PUMP ASY-FUEL INJECT 001
3C3Z 6B898AA GASKET OIL RETURN LI 001
3C3Z 9E933AA GSKT-EGR TO-TH-BDY 001
3C3Z 9T514AD KIT-HDW TRBCH MTNG 001
4C3Z 9B246A KIT-FUEL SYSTEM SERV 001
I D S TEST ALL CYL CODES P0261 P0264 P0267 P0270 P0273 P0276 P0279 P0282 P2 291 LOW ICP 350 CRANKING I P R CRANKING ACESS & REPLACE H PRESSURE PUMP HOS ES ETC
07/04/2007
DEALER: Capital Ford Lincoln Inc
WARRANTY CLAIM NUMBER: 300462 ODOMETER: 158669K
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9J460A SENSOR ASY EGR PR VL 001 070504A 42 DOES NOT OPERATE PROPERLY
5C3Z 12224A 3 WAY VACUUM CONNECT 001 061906C
6C3Z 6C640C CONNECTION A/C DUCT 001 062302A
6C3Z 6C640B CONNECTION A/C DUCT 001 12650D9
CXO 10W304LSD 003 12650D25
3C3Z 6731AA ELEMENT ASY OIL FILT 001
F5UZ 19D990AB ORIFICE-EXPANSION 001
1W1Z 19E889JB O RING - A/C COMP 003
1W1Z 19E889DC O RING - A/C COMP 001
CVC 7A 001
5C3Z 4A322AA SEAL FRT WHL HUB 001
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001
4C3Z 6K682CBRM TURBO CHG-EXH DRIVE 001
3L3Z 12B579AB SENSOR EEC MASS AIR 001
CARRY OUT PERFORMANCE DIAGNOSIS RETREIVE CODES P2263 P0404 P0470 P0113. PINP OINT TEST ROADTEST WITH NGSFOUND EGR VALVE STICKING. REMOVE CLEAN EGR AS PER TSB 06 19 06 VALVE FAILED REPLACE VALVE, TURBO VANES STICKING REMOVE TURBO AND INSPECT., REPLACE TURBO AS PER 06 23 2, FOR CODE P0113 FOUND MASS AIR FL OW SENSOR OUT OF RANGE, REPLACE SENSOR , FOR CODE P0470 FOUND EXHAUST BACK P
05/07/2007
WARRANTY CLAIM NUMBER: 296696 ODOMETER: 150642K
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6079C GASKET SET-VALVE GRI 001 8005D 42 DOES NOT OPERATE PROPERLY
4C3Z 9P456AF COOLER - EGR 001 6051AT
3C3Z 10884AA SENDER-WATER TEMP 001 6731A
3C3Z 9433AA GASKET SET-MANIFOLD 001 OSL
CXO 10W30LSP12 001
W300013 004
W300051 004
6C3Z 9T515A KIT-TUBE TRBCH OIL R 001
3C3Z 8575AA THERMOSTAT 001
3C3Z 8620DB BELT-W/PUMP FAN&GENE 000
CVC 7A 002
CXO 10W30LSD12 004
CXO 10W304LSD 003
3C3Z 6565AA ROD PUSH 001
3C3Z 6564AA ARM-VALVE ROCKER 001
3C3Z 6564BA ARM-VALVE ROCKER 001
3C3Z 6564CA ARM-VALVE ROCKER 004
4C3Z 6564AA ARM-VALVE ROCKER 001
CXT 6LSP12 012
PERFORM COOLING SYSTEM DIAGNOSIS, FOUND EGR COOLER LEAKING TESTED FOR EXHAUS T GAS IN COOLANT, EXHAUST PRESENT INCOOLANT. DIAGNOSE HEAD GASKETS LEAKING R EMOVE AND REPLACE CYLINDER HEAD GASKETS REMVE AND REPLACE EGR COOLER SEND HE AD OUT TO BE INSPECTED FOR CRACKS AND WARPAGE HEADS WITH IN SPEC.REINSTALL A LL PARTS.CHANGE OIL TOP UP FLUID AND BLEED SYSTEM ROADTEST RECHECK FOR LEAKS
05/07/2007
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 6F089BA ACTUATOR ASSY 001 062302B 42 DOES NOT OPERATE PROPERLY
6C3Z 6K786EA CLAMP AIR COOLING 001 9527AR
6C3Z 9H465BA VALVE-THERM AIR CNTL 001
4C3Z 9E527AA NOZZLE ASY-FUEL INJE 001
CARRIED OUT PERFORMANCE DIAGNOSIS RETREIVE P0275 P0299 PINPOINT TEST ROADTES T WITH NGS FOUND TURBO VANES STICKINGAND #5 CYLINDER NOT CONTRIBUTING,REPLAE 5 INJECTOR RMVOE TURBO AND INSPECT AS PER 06-23-2 TURBO COKED CLEQAN AND RE INSTALL RETEST SYSTEM AND ROADTEST OK
05/07/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 42 DOES NOT OPERATE PROPERLY
APPROVAL THORUGH CUDL
04/17/2007
WARRANTY CLAIM NUMBER: 293472 ODOMETER: 146716K
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9P455AB SE E/G/R VLV 000 061906A 55 PLUGGED/RESTRICTED
6C3Z 9T515A KIT-TUBE TRBCH OIL R 000 062302B
6C3Z 6C640A CONNECTION A/C DUCT 000 070504A
9F452 TRANSDCR-EGR BACK PR 000
04/17/2007
WARRANTY CLAIM NUMBER: 295359 ODOMETER: 146716K
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 6C640A CONNECTION A/C DUCT 001 6646AH 55 PLUGGED/RESTRICTED
3C3Z 9P455AB SE E/G/R VLV 001 061906A
9F452 TRANSDCR-EGR BACK PR 000 MT9F452
CARRY OUT PEROFRMANCE DIAGNOSIS RETREIVE CODES P0487 P1408 FOUND BLUE CAC TU BE HOSE LEAKING LOSING BOOST PRESSURE, EGRVALVE SEIZED, IMPROPER PROGRAMMING INSTALLED REMOVE CLEAN AND RETEST EGR VALVE AS PER TSB REPLACE BLUE CAC TUB E HOSE REPROGRAM MODULES WITH AS BUILT DATA RETEST SYSTEM AND RETEST OK
03/29/2007
DEALER: Village Ford Lincoln Sales Ltd
WARRANTY CLAIM NUMBER: 113277 ODOMETER: 142395K
LABOR OP
CONDITION CODE
CONDITION DESC
000 05B32B
PERFORMED RECALL - 05B32- DE-GAS BOTTLE FILL LEVEL LABEL
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P35EA45636
Standard Claims List For Model Year 2005
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 9 2H01 031202 6C2Z 6K786 AA L65 42 34959
AWS Claim Key: 2953134 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B4538 - * Name: LANGENBURG MOTORS LTD Ph: 306-7432241 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:14-DEC-2005 Doc #:07720001
Cust Comments: CHACK OIL LEAK ON AIR COOLER DUCT.
Tech Comments: REPLACE CAC DUCT AND RELATED PARTS AS PER TSB 05 13 5. MT TIME FOR DIAGNOSIS.
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 9 5K01 040401 5C3Z 1015 MA B66 D4 34959
AWS Claim Key: 2953135 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: B4538 - * Name: LANGENBURG MOTORS LTD Ph: 306-7432241 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:14-DEC-2005 Doc #:07720002
Cust Comments: CHECK CHROME PEELING OFF OF LF RIM.
Tech Comments: CHECK OUT. REPLACE LF RIM.
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 9 6N04 010807 5C3Z 9942528 DA B66 05 34959
AWS Claim Key: 2953136 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B4538 - * Name: LANGENBURG MOTORS LTD Ph: 306-7432241 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:14-DEC-2005 Doc #:07720003
Cust Comments: CHECK NAMEPLATE PAINT COMING OFF.
Tech Comments: CHECK OUT. REPLACE NAMEPLATES ON FENDERS AND TAILGATE. MT TIME USED FOR NO LABOR OPERATION.
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 13 * * * * * * * 37272
AWS Claim Key: 4509963 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: B4538 - * Name: LANGENBURG MOTORS LTD Ph: 306-7432241 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:24-APR-2006 Doc #:06903801
Cust Comments: CUSTOMER WANTS RECALL 05E15 PERFORMED ON VEHICLE.
Tech Comments: PERFORM RECALL AS PER INSTRUCTIONS.
AWS Claim Key: 4509964 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B4538 - * Name: LANGENBURG MOTORS LTD Ph: 306-7432241 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:24-APR-2006 Doc #:06903802
Cust Comments: CUSTOMER ASSURANCE TEST DRIVE.
Tech Comments: CUSTOMER ASSURANCE TEST DRIVE.
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 25 * * * * * * * 88480
AWS Claim Key: 7441186 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: A4721 - * Name: VILLAGE FORD LINCOLN SALES LTD. Ph: 306-6937136 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:29-MAR-2007 Doc #:11327702
Cust Comments: PERFORM RECALL 05B32 DE GAS BOTTLE FILL LEVEL LABEL
Tech Comments: PERFORMED RECALL 05B32 DE GAS BOTTLE FILL LEVEL LABEL
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 25 1H03 030008 * 9F452 * D03 55 91165
AWS Claim Key: 7619317 Trx Code: S07 Labor Hrs: 0
Dlr Cd-Sub Cd: A4620 - * Name: CAPITAL FORD LINCOLN INC Ph: 306-5435410 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:17-APR-2007 Doc #:29347201
Cust Comments: HARD STARTING WHEN COLD
Tech Comments: CARRY OUT PERFORMANCE DIAGNOSIS RETREIVE CODES P0401 P2263 P0299 PINPOINT TEST FOUND EGR VALVE STICKING, TURBO VANESSTICKING, CHECK OASIS REPROGRAM MODULES AS PER TSB 07 5 4 REMOVE CLEAN AND RETEST EGR VALVE AS PER 06 19 6 VALVE OK REMOVE CLEAN AND RETEST TURBO AS PER TSB 06 23 2 TURBO OK RETEST SYSTEM AND ROADTEST OK
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 25 1H03 030008 * 9F452 * D36 55 91165
AWS Claim Key: 7918077 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: A4620 - * Name: CAPITAL FORD LINCOLN INC Ph: 306-5435410 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:17-APR-2007 Doc #:29535901
Cust Comments: BUCKING AND JERKING NLOSS OF POWER, TURBO BOOST GAUGE FLUCTUATING G
Tech Comments: CARRY OUT PEROFRMANCE DIAGNOSIS RETREIVE CODES P0487 P1408 FOUND BLUE CAC TUBE HOSE LEAKING LOSING BOOST PRESSURE, EGRVALVE SEIZED, IMPROPER PROGRAMMING INSTALLED REMOVE CLEAN AND RETEST EGR VALVE AS PER TSB REPLACE BLUE CAC TUBE HOSE REPROGRAM MODULES WITH AS BUILT DATA RETEST SYSTEM AND RETEST OK
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 26 1C03 03XXXX 5C3Z 6079 C L87 42 93604
AWS Claim Key: 7934665 Trx Code: E72 Labor Hrs: 14.7
Dlr Cd-Sub Cd: A4620 - * Name: CAPITAL FORD LINCOLN INC Ph: 306-5435410 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:07-MAY-2007 Doc #:29669601
Cust Comments: LOSING COOLANT (L87)
Tech Comments: PERFORM COOLING SYSTEM DIAGNOSIS, FOUND EGR COOLER LEAKING TESTED FOR EXHAUST GAS IN COOLANT, EXHAUST PRESENT INCOOLANT. DIAGNOSE HEAD GASKETS LEAKING REMOVE AND REPLACE CYLINDER HEAD GASKETS REMVE AND REPLACE EGR COOLER SEND HEAD OUT TO BE INSPECTED FOR CRACKS AND WARPAGE HEADS WITH IN SPEC.REINSTALL ALL PARTS.CHANGE OIL TOP UP FLUID AND BLEED SYSTEM ROADTEST RECHECK FOR LEAKS AND EXHAUSTGAS IN C
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 26 2E03 030402 4C3Z 9E527 AA D36 42 93604
AWS Claim Key: 7926764 Trx Code: S07 Labor Hrs: 8.5
Dlr Cd-Sub Cd: A4620 - * Name: CAPITAL FORD LINCOLN INC Ph: 306-5435410 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:07-MAY-2007 Doc #:29669602
Cust Comments: BUCKING AND JERKING ON ACCELL LOSS OF POWER BLACK HEAVY SMOKE FROM
Tech Comments: CARRIED OUT PERFORMANCE DIAGNOSIS RETREIVE P0275 P0299 PINPOINT TEST ROADTEST WITH NGS FOUND TURBO VANES STICKINGAND #5 CYLINDER NOT CONTRIBUTING,REPLAE 5 INJECTOR RMVOE TURBO AND INSPECT AS PER 06 23 2 TURBO COKED CLEQAN AND REINSTALL RETEST SYSTEM AND ROADTEST OK
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 26 2E03 030008 * 9E527 * D36 42 93604
AWS Claim Key: 7999495 Trx Code: Z14D Labor Hrs: 0
Dlr Cd-Sub Cd: A4620 - * Name: CAPITAL FORD LINCOLN INC Ph: 306-5435410 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:07-MAY-2007 Doc #:29669603
Cust Comments: CLAIMING FOR DEDUCTIBLE
Tech Comments: APPROVAL THORUGH CUDL
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 28 2H01 030407 4C3Z 6K682 CBRM D21 42 98592
AWS Claim Key: 8179233 Trx Code: S07 Labor Hrs: 9
Dlr Cd-Sub Cd: A4620 - * Name: CAPITAL FORD LINCOLN INC Ph: 306-5435410 St:SK Ctry Cd: CAN Reg Cd: NA Repr Date:04-JUL-2007 Doc #:30046201
Cust Comments: LACK OF POWER ON ACCELL RUNNING ROUGH, TURBO GAUGE FLUCTUATING, HAR
Tech Comments: CARRY OUT PERFORMANCE DIAGNOSIS RETREIVE CODES P2263 P0404 P0470 P0113. PINPOINT TEST ROADTEST WITH NGSFOUND EGR VALVE STICKING. REMOVE CLEAN EGR AS PER TSB 06 19 06 VALVE FAILED REPLACE VALVE, TURBO VANES STICKING REMOVE TURBO AND INSPECT., REPLACE TURBO AS PER 06 23 2, FOR CODE P0113 FOUND MASS AIR FLOW SENSOR OUT OF RANGE, REPLACE SENSOR , FOR CODE P0470 FOUND EXHAUST BACK PRESSURE SENSOR OUT O
1FTSW21P35EA45636 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 21-AUG-2004 31-MAR-2005 4A4620 CAN 28 2E06 0304XX 5C4Z 9A543 B D02 01 99095
AWS Claim Key: 8243199 Trx Code: E72 Labor Hrs: 8
Dlr Cd-Sub Cd: B4077 - * Name: CARDEAGER FORD SALES LTD. Ph: 204-9378383 St:MB Ctry Cd: CAN Reg Cd: NA Repr Date:16-JUL-2007 Doc #:03444801
Cust Comments: TOWED IN ENG CRANKS BUT WILL NOT START
Tech Comments: I D S TEST ALL CYL CODES P0261 P0264 P0267 P0270 P0273 P0276 P0279 P0282 P2291 LOW ICP 350 CRANKING I P R CRANKING ACESS & REPLACE H PRESSURE PUMP HOS ES ETC
