VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
. AXLE CODE
D1 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
05/05/2003 BUILD DATE
04/05/2003 SALE MILEAGE
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
BEFORE REPLACING 7.3L DIESEL TURBO PEDESTALS (-6N639-) SEE TSB 04-20-02
BEFORE REPLACING MIRROR ASSEMBLY (-17682/17683-), SEE TSB 03-23-02
CUDL MESSAGES
THIS VEHICLE HAS A CLOSED CUDL CONTACT
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
VERIFY VIN/WARRANTY COVERAGE
VEHICLE SOLD IN CANADA
SERVICE INFO MAY BE UNAVAILABLE
03L12
ENGINE EMISSION CONTROL INFORMATION (EECI) LABEL REPLACEMENT
EXTENDED COVERAGES
2127 - CAN 2003 NEW 36/150000 PREMIUMCARE W/ ROADSIDE ASSIST.
STANDARD DEDUCTIBLE: 100 CAD
OWNER NAME: AARON DORISH
OPTIONS:
EXPIRATION DATE: 05/05/2006
DISTANCE: 150,000
RENTAL: 35 UP TO 10 DAYS
TOWING: 0 CAD
CONTRACT SOLD BY: CAN A6040
ESP CONTRACT START DATE: 05/05/2003
THE ROAD HAZARD TIRE COVERAGE BENEFIT EXTENDED TO ELIGIBLE FORD MOTOR
COMPANY VEHICLES IS ONLY IN EFFECT DURING THE TERM OF THE NEW VEHICLE
LIMITED WARRANTY.
REPAIR HISTORY
11/29/2005
DEALER: Waterloo Ford Lincoln Sales Lt
WARRANTY CLAIM NUMBER: 566647 ODOMETER: 079636K
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F2
000 6005F6
000 6005F13
000 6005F18
000 6005F33
000 9527AR
ROAD TESTED WITH CUSTOMER. VERIFIED MISSING UNDER LAOD. PERF 6L PRECHECKS AN D ALL SELF TESTS, NO CODES. CHEKCED FUELPRESSURE AND QUALITY. ALL OK.PERFORM ENHANCED INJ DIAG FOUND CYL #7 BAD,R+R #7 INJ AND RETEST-RUNS OK AND NO MIS S.NOTE;WEHAD JUST REPLACED #7 INJ ON R.O.565023,IT HAD NOW FAILED AGAIN.
11/02/2005
WARRANTY CLAIM NUMBER: 565023 ODOMETER: 076800K
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9T517AA KIT-REG FUEL PRESS 001 6020A D8 FAILED GASKET/SEAL
3C3Z 9P456AE COOLER - EGR 001 6020AXA
3C3Z 8592AB CONNECTION-CYL HD WA 001 6020AZN
3C3Z 6019CA COVER ASY-TIMING GEA 001 8005D
3C3Z 8255AA GASKET WATER OUTLET 001
3C3Z 9C165AA KIT-FU/FLTR SE 001
3C3Z 8507AA GASKET WATER PUMP 001
3C3Z 6C755AA KIT-TUB OIL FLTR 001
6C3Z 5A231AA CLAMP-MUFFLER 001
CXC 10C 002
3C3Z 9P458AA KIT - VLV EGR 001
4C4Z 8592AA CONNECTION-CYL HD WA 001
STEAM CLEAN COOLANT FROM VALLEY OF ENGINE, PERF COOLANT PRES AND CYL HEAD EX TERNAL LEAKAGE TESTS. FOUND EGR COOLER LEAKINR+R EGR COOLER. FOUND COOLANT T UBE ON FRONT COVER LEAKING AS WELL,TRY TO REMOVE BADLY SEIZED TUBE BUT COULD NOT WITOUT BREAKING FRONT COVER,REPLACE FRONT COVER,ASSEMBLED ENGINE RAN AN D CHECKED FOR LEAKS.
11/02/2005
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9E527AE NOZZLE ASY-FUEL INJE 004 ADD 42 DOES NOT OPERATE PROPERLY
000 6005F
000 6005F1X1
000 6005F2
000 6005F6
000 6005F8
000 6005F13
000 6005F18
000 6005F19
000 6005F20
000 6005F33
000 9527AT
VERIFIED HART STARTING AND RUNS ROUGH. PERF 6L DIAG PRECHECK FOUND NO OBVIOU S PROBLEMS. PERF KOEO, KOER, INJECTOR SELFTEST, NO CODES PRESENT. PERFORM DI ESEL DIAG.SEE ATTACHED CHART-PERFORM ENHANCED INJECTOR DIAG,FOUND #1 #7 BAD AND ALSO #3.#5 WERE WEAK ON CYL CONTRIBUTION TESTS-REPLACE ALL RIGHT SIDE IN JECTORS.
04/13/2005
DEALER: Team Ford Sales Limited
WARRANTY CLAIM NUMBER: 116927 ODOMETER: 054121K
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 2521452AA F/DR WDO W/S 001 MT21452 02 BENT/BUCKLED/KINKED
F81Z 2521453AA F/DR WDO W/S 001
REPLACED L AND R OUTER GLASS BELT MOULDINGS,VERIFY REPAIR BY VISUAL INSPECTI ON. MT- TIME TO REPLACE DOOR MOULDINGS
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 2 6Y20 000001 * MISC * A9* 82 5452
AWS Claim Key: 1588733 Trx Code: Z20 Labor Hrs: 0
Dlr Cd-Sub Cd: A6040 - * Name: UNIVERSAL FORD LINCOLN SALES LTD. Ph: 403-2912800 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:10-JUN-2003 Doc #:257657A
Tech Comments: CLAIMING FOR TOW AS PER REGION
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 2 2H01 030008 3C3Z 6K682 AARM D50 42 5452
AWS Claim Key: 1500117 Trx Code: S07 Labor Hrs: 12.2
Dlr Cd-Sub Cd: A6040 - * Name: UNIVERSAL FORD LINCOLN SALES LTD. Ph: 403-2912800 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:10-JUN-2003 Doc #:257657B
Cust Comments: ENGINE WILL NOT IDLE MAKES KNOCKING NOISE
Tech Comments: HOTLINE #3FJB017. PERFORM ALL NESS TESTS. FND LEAK FROM RT HEAD, REMOV RT SIDE VALVE CONER. AND GASKET. REMOV HI PRESS OIL RESIVOUR. POWER UP FUELDS. FND #3 INJECTOR LEAKING. REPLC #3 INJECTOR. RUN FUEL PUMP FOR 45 MINITES NO MORE LEAKAGE NOTED. OIL HAD ABOUT 12L OIL FUEL IN CRANKCASE. REPLACE TURBO AS PER TSB. UNABLE TO GET BOLT OUT OF TURBO, SIEZED. REMOVED FRONT TURBO HALF. REMOVE REAR TURBO HA
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 9 2G05 031405 * RECAL * D42 42 18442
AWS Claim Key: 4029548 Trx Code: E84 Labor Hrs: 2.9
Dlr Cd-Sub Cd: A6040 - * Name: UNIVERSAL FORD LINCOLN SALES LTD. Ph: 403-2912800 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:08-JAN-2004 Doc #:278576A
Cust Comments: ENGINE RUNS ROUGH AT IDLE AND HIGHWAY SPEEDS
Tech Comments: ENG PERF DIAG.KOEO.INJ.KOER.LOW IDLE STAB.EXH REST.BOOST PRESS.FUEL CONT.INTAKE REST.EGR POS.IPR.PWR BALANCE.REL COMP.REP PCM 3C3A*BDM 3U7A*FTC
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 15 2H01 030008 3C3Z 6K682 AARM D42 42 18869
AWS Claim Key: 6836162 Trx Code: S07 Labor Hrs: 13.4
Dlr Cd-Sub Cd: B6210 - * Name: TEAM FORD SALES LIMITED Ph: 780-4628300 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:28-JUN-2004 Doc #:09634001
Cust Comments: CHECK AND ADVISE FOR NO POWER ON ENGINE.CUSTOMER WAS DRIVING AND VEHICLE STARTED TO SHUDDER AND THEN DIED.
Tech Comments: MT TSB OIL IN FUEL TESTS AND 2 OIL CHANGES,DIAG.CONCERN CONF.CONDITION,ENGINE RUNNING ROUGH & LACKING POWER,TURBOCHARGER VERY NOISY,DIAG.AS PER PCED AND OASIS TSB 040903,#2 INJ. P2263,ICP P2290,DRAINED 32L.OIL FROM CCASE,1,5,8 INJ.LEAKING REPL.ALL7 AS PER C.KOSTER,TURBO FAILED ENDPLAY REPL.,FUEL STILL IN OIL,POWER BAL.,REL.COMP. GOOD,CLEARED CODES PASS,BOOST 25PSI,REPL.FICM TO K272 17,VERIFI OK
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 15 5J01 040301 3C3Z 18124 CA H45 D8 19396
AWS Claim Key: 6877626 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: B6210 - * Name: TEAM FORD SALES LIMITED Ph: 780-4628300 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:09-JUL-2004 Doc #:09732102
Cust Comments: REPLACE THE LEAKING LEFT FRONT SHOCK
Tech Comments: REPLACED LEAKING SHOCK AS REQUIRED, REPAIR VERIFIED BY VISUAL INSPECTION 18124A .3
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 17 6P04 010301 * 3820125 * B09 07 23814
AWS Claim Key: 7755774 Trx Code: E84 Labor Hrs: 0.6
Dlr Cd-Sub Cd: B6210 - * Name: TEAM FORD SALES LIMITED Ph: 780-4628300 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:20-SEP-2004 Doc #:10237402
Cust Comments: CHECK AND ADVISE FOR RATTLE IN DRIVERS DOOR WHEN GOING OVER
Tech Comments: R TEST ROADTEST TO VERIFY CONCERN ALIGN LF DOOR AND R TEST,VERIFIED REPAIR OK
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 17 7A01 140100 * 70 * B09 07 23814
AWS Claim Key: 7853815 Trx Code: E83 Labor Hrs: 1
Dlr Cd-Sub Cd: B6210 - * Name: TEAM FORD SALES LIMITED Ph: 780-4628300 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:20-SEP-2004 Doc #:10237403
Cust Comments: CHECK AND ADVISE FOR RATTLE COMING FROM BACK OF CAB ON DRIVERS SIDE
Tech Comments: ROADTEST TO VERIFY CONCERN,RR QUARTER TRIM LR OF CAB, REMOVE AND REFIT QUARTER MOULDING AND REFIT FOR CAUSING NOISE, VERIFIED REPAIR OK
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 17 7K11 130101 3C3Z 10849 JA L69 42 23814
AWS Claim Key: 7755773 Trx Code: E83 Labor Hrs: 1.6
Dlr Cd-Sub Cd: B6210 - * Name: TEAM FORD SALES LIMITED Ph: 780-4628300 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:20-SEP-2004 Doc #:10237405
Cust Comments: CHECK AND ADVISE FOR FUEL GAUGE NOT COMING UP WHEN VEHICLE IS FILLED UP VEHICLE IS SHUT OFF .GAUGE DOES EVENTUALLY COME UP
Tech Comments: PERFORM BCE CLUSTER SELF TEST NO CODES ON DEMAND TEST PASS,PERFORM FUEL GAUGE TEST CLUSTER DOESNT CHANGE FAULTY CLUSTER,PERFORM BCE PROGRAMMABLE MODULE INSTALL REPLACED INSTRUMENT CLUSTER ASSY., CLEARED CODES BY FUNCTION AND RETEST.
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 19 7M01 150101 * 18806 * A16 42 28298
AWS Claim Key: 8756234 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: G6504 - * Name: FROSTEMP WESTERN LTD Ph: *-* St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:26-OCT-2004 Doc #:00902301
Cust Comments: WON'T PLAY CD'S STUCK
Tech Comments: R & R FOR REPAIR
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 19 7M01 150101 3C3T 18C815 AC A07 42 28298
AWS Claim Key: 8894489 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: B1996 - * Name: HALLA CANADA BELL BEAUBIAN Ph: *-* St:ON Ctry Cd: CAN Reg Cd: NA Repr Date:16-NOV-2004 Doc #:4917490C
Tech Comments: REQUESTING DEALER'S P/A CODE B6249
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 20 1H03 030008 3C3Z 9F452 AC E29 55 30118
AWS Claim Key: 8915347 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: B6210 - * Name: TEAM FORD SALES LIMITED Ph: 780-4628300 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:13-DEC-2004 Doc #:10864501
Cust Comments: REPAIR FOR CHK ENG LIGHT IS ON
Tech Comments: PLUGGED EGR VALVE, NEW CALIBRATION. VERIFIED CONCERN. PERFORMED KOEO SELF TEST AS PER SYMPTOM CHART 8 CODES P0404 AND P2263 PRESENT. PERFORMED PIN POINT W AS PER PCED,PERF.EGR POSITION CHECK NOT WITHIN SPEC.,REM.AND INSP.EGR VALVE PLUGGED WITH CARBON REPLACED VALVE 0K,REPROGRAMMED PCM TO 3U7A FTE FROM 3U7A FTC,AS PER SSM 17048 OK, CHK.ENGINE LIGHT DID NOT COME BACK ON NO CODES, OK
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 24 6H19 011103 F81Z 2521452 AA B66 02 33629
AWS Claim Key: 10421395 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: B6210 - * Name: TEAM FORD SALES LIMITED Ph: 780-4628300 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:13-APR-2005 Doc #:11692701
Cust Comments: CUST SAYS BOTH FRONT DOOR WINDOW MOULDINGS AT BOTTOM OF WINDOW ON EXTERIOR OF DOOR ARE MALFORMED
Tech Comments: REPLACED L AND R OUTER GLASS BELT MOULDINGS,VERIFY REPAIR BY VISUAL INSPECTION. MT TIME TO REPLACE DOOR MOULDINGS
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 31 1H03 030804 3C3Z 9P456 AE L87 D8 47721
AWS Claim Key: 12542454 Trx Code: E72 Labor Hrs: 7.8
Dlr Cd-Sub Cd: A6010 - * Name: WATERLOO FORD LINCOLN SALES LTD. Ph: 780-4234330 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:02-NOV-2005 Doc #:56502301
Cust Comments: REPAIR FOR COOLANT LEAKING FROM REAR OF CYLINDER HEADS
Tech Comments: STEAM CLEAN COOLANT FROM VALLEY OF ENGINE, PERF COOLANT PRES AND CYL HEAD EXTERNAL LEAKAGE TESTS. FOUND EGR COOLER LEAKINR+R EGR COOLER. FOUND COOLANT TUBE ON FRONT COVER LEAKING AS WELL,TRY TO REMOVE BADLY SEIZED TUBE BUT COULD NOT WITOUT BREAKING FRONT COVER,REPLACE FRONT COVER,ASSEMBLED ENGINE RAN AND CHECKED FOR LEAKS.
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 31 2E06 030008 3C3Z 9E527 AE D13 42 47721
AWS Claim Key: 12556423 Trx Code: S07 Labor Hrs: 6.2
Dlr Cd-Sub Cd: A6010 - * Name: WATERLOO FORD LINCOLN SALES LTD. Ph: 780-4234330 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:02-NOV-2005 Doc #:56502302
Cust Comments: RUNS ROUGH AND IS HARD STARTING AFTER EGR REPLACED ON JOB#1 OF TIS CLAIM FOR COOOLANT LEAK.
Tech Comments: VERIFIED HART STARTING AND RUNS ROUGH. PERF 6L DIAG PRECHECK FOUND NO OBVIOUS PROBLEMS. PERF KOEO, KOER, INJECTOR SELFTEST, NO CODES PRESENT. PERFORM DIESEL DIAG.SEE ATTACHED CHART PERFORM ENHANCED INJECTOR DIAG,FOUND #1 #7 BAD AND ALSO #3.#5 WERE WEAK ON CYL CONTRIBUTION TESTS REPLACE ALL RIGHT SIDE INJECTORS.
1FTSW31P73EC81242 T/F7 T/F T/BC T/CD T/E A1 T/BE T/YB 05-APR-2003 05-MAY-2003 4A6040 CAN 32 2E06 030008 3C3Z 9E527 AE D13 42 49483
AWS Claim Key: 12583235 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: A6010 - * Name: WATERLOO FORD LINCOLN SALES LTD. Ph: 780-4234330 St:AB Ctry Cd: CAN Reg Cd: NA Repr Date:29-NOV-2005 Doc #:56664701
Cust Comments: REPAIR FOR ROUGH RUNNING. JUST REPLACED 4 INJECTORS ON RO# 565023 1
Tech Comments: ROAD TESTED WITH CUSTOMER. VERIFIED MISSING UNDER LAOD. PERF 6L PRECHECKS AND ALL SELF TESTS, NO CODES. CHEKCED FUELPRESSURE AND QUALITY. ALL OK.PERFORM ENHANCED INJ DIAG FOUND CYL #7 BAD,R+R #7 INJ AND RETEST RUNS OK AND NO MISS.NOTE;WEHAD JUST REPLACED #7 INJ ON R.O.565023,IT HAD NOW FAILED AGAIN
