OASIS RESULT:
1FTSW21P95EC40494
See bottom of the OASIS result for contact ID
01/29/2006
20:12:14
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
. AXLE CODE
3L ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
03/07/2005 BUILD DATE
02/14/2005 SALE MILEAGE
04200
ARN MESSAGES
BEFORE REPLACING THROTTLE BODY (-9E926-) SEE TSB 05-14-04
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
05B35
ENGINE CONTROL MODULES-RECALIBRATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
11/08/2005
DEALER: Boggus Ford
WARRANTY CLAIM NUMBER: 087963 ODOMETER: 012871M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 9F836AA PEDAL & SENSOR ASY 001 9725B 42 DOES NOT OPERATE PROPERLY
INSPECT LEAK FOUND LINES RETIGHTEN NO MORE LEAKS REPLACE PEDAL ***. ACCELE RATOR NOW WORKING FINE ROAD TEST OK.
09/14/2005
DEALER: Boggus Ford
WARRANTY CLAIM NUMBER: 083978 ODOMETER: 008144M
LABOR OP
CONDITION CODE
CONDITION DESC
5C3Z 7G391BA SOLENOID ASSY 001 7000A 42 DOES NOT OPERATE PROPERLY
5C3Z 7902AB CONVERTER ASY 001 7000AXQ
3C3Z 7A136AA GASKET - FRT PUMP TO 001 7000AZJ
3C3Z 7A248BA OIL SEAL FRT OIL PUM 001 7000A2
000 7000A2ZG
000 7000A11
000 12650D
000 12650DX1
ROAD TEST ELEC DIAG WDS NO CODES REMOVE TRANS TO INSPECT INTERNAL PARTS O-H TRANS REPLACE CONVERTER & SOLENOID BODY FLUSH LINES ROAD TEST OK.
09/14/2005
DEALER: Boggus Ford
LABOR OP
CONDITION CODE
CONDITION DESC
9OO4 78589 002 1007D1 13 OUT OF ROUND
5C3Z 1007DA WHEEL ASSY 001 1007D2C
000 1007AT
R&I SPARETIRE-RIM
1FTSW21P95EC40494 T/F7 T/F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2005 07-MAR-2005 152097 USA 7 3A15 070100 5C3Z 7G391 BA P59 42 8144
AWS Claim Key: 2025410 Trx Code: S07 Labor Hrs: 10.2
Dlr Cd-Sub Cd: 04515 - * Name: BOGGUS FORD Ph: 956-6867411 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2005 Doc #:08397851
Cust Comments: WILL NOT SHIFT PROPERLY OVER DRIVE LIGHT IS FLASHING
Tech Comments: ROAD TEST ELEC DIAG WDS NO CODES REMOVE TRANS TO INSPECT INTERNAL PARTS O H TRANS REPLACE CONVERTER & SOLENOID BODY FLUSH LINES ROAD TEST OK.
1FTSW21P95EC40494 T/F7 T/F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2005 07-MAR-2005 152097 USA 7 5K01 040401 5C3Z 1007 DA N25 13 8144
AWS Claim Key: 2068013 Trx Code: 2 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 04515 - * Name: BOGGUS FORD Ph: 956-6867411 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:14-SEP-2005 Doc #:08397852
Cust Comments: THERE IS A VIBRATION 62 63 CHECK AND ADV,(REAR END )
Tech Comments: R&I SPARETIRE RIM
1FTSW21P95EC40494 T/F7 T/F T/BC T/BD T/E A1 T/BE T/YB 14-FEB-2005 07-MAR-2005 152097 USA 9 5T01 031801 5C3Z 9F836 AA P51 42 12871
AWS Claim Key: 2413600 Trx Code: S07 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04515 - * Name: BOGGUS FORD Ph: 956-6867411 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:08-NOV-2005 Doc #:08796351
Cust Comments: HAS TRANNS LEAK WILL NOT SHIFT PORPERLY
Tech Comments: INSPECT LEAK FOUND LINES RETIGHTEN NO MORE LEAKS REPLACE PEDAL ***. ACCELERATOR NOW WORKING FINE ROAD TEST OK.
