Thanks for you in advance for tackin time to view. i was looking at a 2003 F250 6.0 PSD for my first vehicle if you could please tell me the oasis report i would appreacate it =) vin: 1FTSX31P43EC75119
Thank you so much
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 3 2C01 030603 3C3Z 11002 AARM D02 42 2061
AWS Claim Key: 1921879 Trx Code: 2 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:24-JUL-2003 Doc #:01970251
Cust Comments: CUST STATES NO START, (HAD TO PUSH START)
Tech Comments: STARTER DIAGNOSED & REPLACED STARTER, RECHECK OK
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 14 * * * * * * * 11888
AWS Claim Key: 6481379 Trx Code: 03E03 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2004 Doc #:02749940
Cust Comments: 03E03 POWERTRAIN CONTROL MODULE & FUEL INJECTOR CONTROL MODULE RE CALIB
Tech Comments: 03E03 NEW CALIBRATION, REFLASH PCM,LABEL, RECHECK OPERATION OK
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 14 7C01 011404 XF2Z 14018 AA A85 42 11888
AWS Claim Key: 6481380 Trx Code: E83 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2004 Doc #:02749951
Cust Comments: CUST STATES DOOR AJAR LITE IS ON HALF THE TIME
Tech Comments: STICKY AJAR SWITCHES VERIFY, ACCESS, REPLACE DOOR AJAR SWITCHES IN BOTH DOORS
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 20 * * * * * * * 18074
AWS Claim Key: 9063482 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-DEC-2004 Doc #:03238252
Cust Comments: CAMAPIGN 04S15 NEG BATT TERMINAL
Tech Comments: 04S15 PERFORMED RECALL 04S15
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 20 1H03 030008 3C3Z 9F452 AC D13 42 18074
AWS Claim Key: 9063481 Trx Code: E84 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:16-DEC-2004 Doc #:03238251
Cust Comments: CUST STATES CHECK ENGINE LIGHT IS ON
Tech Comments: EBP SENSOR& EGR VALVE VERIFIED, PULLED CODES, REPLACE EBP SENSOR & EGR VALVE AND RECHECK
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 28 4A01 080103 3C3Z 7550 ADRM P31 01 26431
AWS Claim Key: 11811019 Trx Code: E84 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:05-AUG-2005 Doc #:03792551
Cust Comments: CUST STATES THE CLUTCH WENT OUT TOWED IN
Tech Comments: FOUND DISC BROKEN REPL CLUTCH ASSY
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 36 * * * * * * * 34154
AWS Claim Key: 13483398 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:04385240
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: CAMPAIGN 59B01 PERFORMED CAMPAIGN 59B01 NO FAULTS DETECTED .
AWS Claim Key: 13483399 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:04385241
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: CAMPAIGN 06E17 PERFORMED CAMPAIGN 06E17
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 38 5I01 110204 3C3Z 3A674 AARM H21 42 36553
AWS Claim Key: 13993089 Trx Code: P05 Labor Hrs: 4.1
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-2006 Doc #:04597452
Cust Comments: REPLACE POWER STEERING PUMP & STEERING BOX (EXCESSIVE PLAY & SEEPAGE)
Tech Comments: PWR STEERING PUMP & STEERING BOX CONFIRMED EXCESSIVE STEERING PLAY,PER RO 45811, P.S. PUMP SEEPING,
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 38 5N01 110301 6C3Z 3304 D N50 41 36553
AWS Claim Key: 13993090 Trx Code: P05 Labor Hrs: 4
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-JUN-2006 Doc #:04597453
Cust Comments: REPLACE INNER & OUTER DUST SEALS (FRONT AXLES),O RINGS, DRAG LINK & END LINK,STEERING DAMPENER
Tech Comments: DUST SEALS TORN REPLACED INNER & OUTER TIE RODS, DRAG LINK, DUST SEALS, OIL SEALS,
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 38 5N01 110301 6C3Z 3304 D H21 33 36558
AWS Claim Key: 14000343 Trx Code: P08 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2006 Doc #:04605651
Cust Comments: EXCESSIVE PLAY ON BALL SOCKET ON END LINK
Tech Comments: BALL SOCKET COMING APART REPLACED END LINK DUE TO COMING APART AT BALL SOCKET, RECHECK OK
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 38 5O01 110201 2C3Z 3504 AARM H21 33 36558
AWS Claim Key: 13993091 Trx Code: P08 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:13-JUN-2006 Doc #:04605652
Cust Comments: STEERING BOX IS LOOSE INSIDE, TOO MUCH PLAY
Tech Comments: EXCESSIVE PLAY REPLACE STEERING BOX ASSEMBLY FOR EXCESSIVE PLAY, RECHECK, TEST DR
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 41 1H03 030804 3C3Z 9P456 AE E29 D1 39176
AWS Claim Key: 14332688 Trx Code: E72 Labor Hrs: 10
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2006 Doc #:04767251
Cust Comments: CUSTOMER STATES THE CHECK ENGINE LIGHT IS ON, REPORT
Tech Comments: VERIFIED CK FOR CODES P0401 P0676 PERFORM DIESEL PPTS TRACE TO AND REPLACE THE EGR COOLER
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 44 2E01 030008 3C3Z 9F838 EA L65 D1 42092
AWS Claim Key: 14666793 Trx Code: E72 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-NOV-2006 Doc #:05026551
Cust Comments: CUSTOMER STATES THERE IS AN ENGINE OIL LEAK.
Tech Comments: ICP LEAKING OIL VERIFIED CONCERN.PERFORMED DIAGNOSTIC TESTS.FOUND ICP LEAKING.
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 51 2H02 030008 * 6F089 * E29 42 48021
AWS Claim Key: 15337509 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:20-JUN-2007 Doc #:056939A
Cust Comments: CUSTOMER STATES THE CHECK ENGINE LIGHT IS ON VEHICLE HAS NO POWER, REPORT
Tech Comments: 48021 VERIFIED R AND R ICP SENSOR AND CONNECTOR AND CLEAN EGR VALVE STILL LOW BOOST REPLACE TURBO ASSY AND RECHECK OK
1FTSX31P43EC75119 T/F7 F T/BD T/CD T/E A1 T/VG T/YB 26-MAR-2003 02-MAY-2003 172461 USA 52 2H01 030008 3C3Z 6K854 DA E29 55 49152
AWS Claim Key: 15417146 Trx Code: E72 Labor Hrs: 4.3
Dlr Cd-Sub Cd: 07873 - * Name: BILL BRANDT FORD INC Ph: 925-6343551 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:26-JUL-2007 Doc #:057789A
Cust Comments: T90 CUSTOMER STATES CHECK ENGINE LIGHT COMING ON AGAIN.CHECK AND ADVISE.
Tech Comments: 49152 LEAK AT Y PIPE VERIFIED COMPLAINT QUICK TESTED GOT CODE P0401.CMDTC,PASSED KOEO.PASSED KOER.RAN OASIS AND ROAD TESTED TO MONITOR PIDS .RAN EGR TESTS PASSED ROAD TESTED WITH DATA LOGGER FOUND SLIGHTLY LOW BOOST,SMOKE CHECKED EXHAUST SYSTEM,FOUND LEAK AT LEFT EXHAUT Y PIPE ORDERED PARTS.R&R LEFT TURBO INLET PIPE, Y PIPE ASSEMBLY,BOLTS,NUTS AND GASKETS.RERAN EGR TEST
