Standard Claims List For Model Year 2006
1FTSW21P86EB11308 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-AUG-2005 10-FEB-2006 152182 USA 51 2E05 030404 * 9B249 * G32 49 99224
AWS Claim Key: 9092635 Trx Code: E72 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 04617 - * Name: CHAMPION FORD KATY Ph: 281-6754700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2010 Doc #:593498A
Cust Comments: CUSTOMER STATES THAT THE WATER IN FUEL LAMP IS ON
Tech Comments: 99230 DIESEL WARR..CC:49.. TSB 06 22 12B... VERIFY WATER IN FUEL LIGHT ON.. FUEL SAMPLE NORMAL.. REMOVE WIF SENSOR VERIFY COROSSION AND EXCESSIVE DEBRI IN HCFM.. REPLACE FAULTY WIF SENSOR .. CLEAN FUEL MANIFOLD .. REFLASH PCM TCM FICM WITH LATEST CALIBRATION.. RETEST OK
1FTSW21P86EB11308 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 31-AUG-2005 10-FEB-2006 152182 USA 51 2H01 030407 3C3Z 6C885 A D02 42 99224
AWS Claim Key: 9089466 Trx Code: E72 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 04617 - * Name: CHAMPION FORD KATY Ph: 281-6754700 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-2010 Doc #:593498B
Cust Comments: CUSTOMER STATES THAT THE VEHICLE LACKS POWER AND FUEL MILEAGE IS DOWN (NO POWER BEFORE BOOST KICKS IN)
Tech Comments: 99230 DIESEL WARR..CC:42..FP:UNISON RING VERIFY ENGINE LACKS POWER AT TIMES... PERFOMR DIESEL DIAG PERFORMANCE STEPS .. PERFORM VISUAL ENGINE INSPECTION CHECK OIL FOR LEVEL AND CONTAMINATION NORMAL.. CHECK SUFFICIENT CLEAN FUEL NORMAL.. CHECK INTAKE AIR RESTRICTION 2 IN H20.. EXHAUST RESTRICTION 26PSI.. PERFORM KOEO SELF TEST PASS.. RETRIEVE CONT CODES P0299 .. PERFORM KOER ON
Reactions: Wired For Fire
