Standard Claims List For Model Year 2004
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 8 2G05 031405 * RECAL * D13 07 18223
AWS Claim Key: 793622 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04863 - * Name: DUVAL FORD Ph: 904-3876541 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-APR-2004 Doc #:03057451
Cust Comments: C S THAT THE ENGINE IDLE WILL SURGE UP AND DOWN WHEN 1ST START.
Tech Comments: CK OUT, VERIFY CONCERN. FOUND SURGE AT IDLE. KOEO P1111, KOEC P1111, KOER P1111. REPROGRAM PCM, TCM, FICM. RETEST AND ROAD TEST. ENG OPERATING NORMALLY.
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 9 2E05 100106 3C3Z 9B249 AB G29 46 22477
AWS Claim Key: 1095196 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04867 - * Name: MIKE SHAD FORD Ph: 904-7773673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2004 Doc #:06906102
Cust Comments: CS WATER IN FUEL LIGHT STAYING ON G29
Tech Comments: REPLACE WIF SENSOR
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 9 1D01 030008 3C3Z 6701 AA L65 D8 22477
AWS Claim Key: 1095195 Trx Code: E84 Labor Hrs: 4.9
Dlr Cd-Sub Cd: 04867 - * Name: MIKE SHAD FORD Ph: 904-7773673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2004 Doc #:06906105
Cust Comments: CS OIL LEAK AT REAR OF ENGINE L68
Tech Comments: ER ADDED REAR ENGINE SEAL LEAKING OIL...DIAGNOSE, R&R TRANS (4X4), REPLACE REAR ENGINE SEAL, POST TEST, OKAY
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 21 2E05 100106 3C3Z 9B249 AB G29 42 50034
AWS Claim Key: 5570533 Trx Code: E72 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04867 - * Name: MIKE SHAD FORD Ph: 904-7773673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:31-MAY-2005 Doc #:302951D
Cust Comments: CS WATER IN FUEL LIGHT COMES ON AT TIMES
Tech Comments: 50034 ELETICAL PINPOINT SENSOR SHORTED FOUND LITTLE WATER IN SYSTEM REPLACE WIF SENSOR
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 27 2E06 030008 3C3Z 9F838 EA D42 42 57299
AWS Claim Key: 7785186 Trx Code: E72 Labor Hrs: 0
Dlr Cd-Sub Cd: 04867 - * Name: MIKE SHAD FORD Ph: 904-7773673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-NOV-2005 Doc #:319750A
Cust Comments: CS ENGINE IDLES UP AND DOWN STARTING HOT OR COLD CS BLOWS SMOKE STARTING AND ON ACCEL BLACK
Tech Comments: 57299 REPLACED ICP SENSOR RAOD TEST OK
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 27 6Y20 000001 * MISC * A98 82 57299
AWS Claim Key: 8964479 Trx Code: P01 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 04867 - * Name: MIKE SHAD FORD Ph: 904-7773673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-NOV-2005 Doc #:319750B
Cust Comments: ENGINE IDLES UP AND DOWN STARTING HOT OR COLD BLOWS SMOKE
Tech Comments: DI DIAG SHEET, REPLACE ICP SENSOR
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 30 2E06 030008 4C3Z 9E527 AA D42 55 59985
AWS Claim Key: 8641724 Trx Code: E72 Labor Hrs: 8.7
Dlr Cd-Sub Cd: 04867 - * Name: MIKE SHAD FORD Ph: 904-7773673 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:327485A
Cust Comments: CS WILL NOT START TRYS TO AND WHEN IT WILL START HAS NO POWER
Tech Comments: 59995 REPLACE IPR EGR VALVE INJECTORS 1 5 8 AND 7 VERIFY 6.0 OK
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 36 * * * * * * * 64007
AWS Claim Key: 10110120 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04864 - * Name: MIKE DAVIDSON FORD Ph: 904-7253060 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2006 Doc #:00981240
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: RECALL 59BO1
AWS Claim Key: 10110121 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04864 - * Name: MIKE DAVIDSON FORD Ph: 904-7253060 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2006 Doc #:00981241
Cust Comments: 06E17 CONTROL MODULE RECALIBRATION
Tech Comments: RECALL 06E17
1FTSW31P24EA66028 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 02-SEP-2003 23-SEP-2003 124206 USA 41 1H03 030804 3C3Z 9P455 AB D50 55 65058
AWS Claim Key: 11127849 Trx Code: E72 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 00222 - * Name: BUTLER FORD-MERCURY, INC. Ph: 478-4539391 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:21981001
Cust Comments: CUSTOMER STATES ENGINE HAS A MISS WHILE DRIVING
Tech Comments: PO#3476 IDS DIAG CODE P0275,P0402,P0403,P0405 REMOVED & CLEANED EGR PER TSB 06 19 6.TEST DROVE VEH.TURBO IS OVERBOOSTING,REMOVED TURBO ,TURBO HAS CARBON BUID UP ON VGT VEINS & TURBINE WHEEL.CLEANED TURBO PER TSB 06 23 2 TEST DROVE.VEH IS OPERATING NORMALLY AT THIS TIME.
