Standard Claims List For Model Year 1999
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 0 5G05 040001 * FRONT * H24 W6 7
AWS Claim Key: 1941382 Trx Code: 1 Labor Hrs: 2.4
Dlr Cd-Sub Cd: 04462 - * Name: RANDALL REED'S PLANET FORD Ph: 281-4469171 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-MAY-1999 Doc #:13987901
Cust Comments: H24 CUSTOMER STATES:STEERING WHEEL NOT CENTERED.
Tech Comments: 1 CHECK AND CORRECT CASTER CAMBER TOE IN, CCW6
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 6 2E06 130301 F81Z 9275 EA D50 42 6820
AWS Claim Key: 5159215 Trx Code: 2 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 04402 - * Name: JOE MYERS FORD Ph: 713-8968200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-OCT-1999 Doc #:289553A
Cust Comments: VEHICLE WAS RUNNING ROUGH WOULD NOT IDLE
Tech Comments: 6820 WF 12 12 9E527 9275 42 RAN COMPLETE DIAG SHEET FOUND ALL PASS CODES ALL PRESS OK.DID FIND AN INTERMITENT TRANS SHIFT CODE.WHICH WAS A RESULT AF AN ENGINE PROBLOME.REPLACED FUEL PUMP AND FUEL PICK UP SCREEN IN TANK.(MTIME 4.2 HR NO LA BOR OPS).REPLACED PUMP DUE TO HISTORY OF PUMP FAILURES WITH THIS PUMP.REPLACED FUEL PICK UP S CREEN.DID FIND SCREEN LOOSE ON PICK UP TUBE.
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 6 6Y21 * * * * A98 * 6820
AWS Claim Key: 5159216 Trx Code: 99S11 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 04402 - * Name: JOE MYERS FORD Ph: 713-8968200 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:19-OCT-1999 Doc #:289553B
Cust Comments: NAC 99S11 BRACKET AND BED BOLT RECALL
Tech Comments: 6820 WF RECALL 99S11 OPS 99S11B 1.5 HR INSTALLED BED STRAPS AND BRACKET PER RECALL.
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 37 6H19 010702 F81Z 26253A24 AA B63 33 26579
AWS Claim Key: 20846240 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01618 - * Name: HILLCREST FORD LINCOLN-MERCURY Ph: 936-2953784 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:07-MAY-2002 Doc #:01486551
Cust Comments: WEATHERSTRIP AT BOTTOM OF LEFT REAR DOOR LOOSE
Tech Comments: . WEATHERSTRIP REAR DOOR GLASS REPLACE
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 42 6J14 011404 F81Z 25218A42 AA L17 42 45775
AWS Claim Key: 21699422 Trx Code: P05 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 01618 - * Name: HILLCREST FORD LINCOLN-MERCURY Ph: 936-2953784 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2002 Doc #:02395951
Cust Comments: DOOR LOCKS IN OP AT TIMES
Tech Comments: BODY CHASSIS ELECTRIAL (BCE) TEST
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 42 7T03 060901 F85Z 2L373 AB H19 42 45775
AWS Claim Key: 21699423 Trx Code: P05 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 01618 - * Name: HILLCREST FORD LINCOLN-MERCURY Ph: 936-2953784 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2002 Doc #:02395952
Cust Comments: ABS AND OD LIGHTS FLASH, SPEEDO IN OP AT TIMES
Tech Comments: REAR ANTI LOCK BRAKE SYSTEM DIAGNOSIS
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 42 6J14 0114XX F81Z 25218A43 AA L17 42 45775
AWS Claim Key: 21684595 Trx Code: SPW Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01618 - * Name: HILLCREST FORD LINCOLN-MERCURY Ph: 936-2953784 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:10-OCT-2002 Doc #:02395953
Cust Comments: C S DOOR LOCK ACTUATOR (SERVICE PART REPLACEMENT)
Tech Comments: TRIM PANEL FRONT DOOR REMOVE AND INSTALL
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 50 3A08 070105 XL3Z 7902 DARM P51 42 56210
AWS Claim Key: 22388144 Trx Code: P05 Labor Hrs: 11.2
Dlr Cd-Sub Cd: 01618 - * Name: HILLCREST FORD LINCOLN-MERCURY Ph: 936-2953784 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2003 Doc #:03678351
Cust Comments: TRANS NOT SHIFTING FROM 1ST TO 2ND
Tech Comments: ELECTRONIC TRANSMISSION DIAGNOSIS DIAGNOSIS
1FTNW21F7XED64478 T/F7 F T/BC T/BD T/E A1 T/DE T/DS 17-FEB-1999 17-MAY-1999 152046 USA 50 7C01 170503 XF1Z 14018 BA L19 42 56210
AWS Claim Key: 22381810 Trx Code: SPW Labor Hrs: 1
Dlr Cd-Sub Cd: 01618 - * Name: HILLCREST FORD LINCOLN-MERCURY Ph: 936-2953784 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:03-JUN-2003 Doc #:03678352
Cust Comments: INSIDE LIGHT STAYING ON
