Standard Claims List For Model Year 2005
1FMSU43P65ED44600 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-JUL-2005 16-AUG-2005 171079 USA 9 * * * * * * * 5368
AWS Claim Key: 4568576 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05458 - * Name: EL CAJON FORD Ph: 619-5798888 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2006 Doc #:04784740
Cust Comments: 05E16 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: RECALL RECALIBRATIN OF CONTROL MODULE
1FMSU43P65ED44600 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-JUL-2005 16-AUG-2005 171079 USA 9 6H10 011104 YC3Z 7830479 AA G07 42 5368
AWS Claim Key: 4568579 Trx Code: 2 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05458 - * Name: EL CAJON FORD Ph: 619-5798888 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2006 Doc #:04784753
Cust Comments: SIDE WINDOW PANELS SQEEK
Tech Comments: SQUEAK REPLACE BOTH REAR QUARTER GLASS WINDOW MOTORS
AWS Claim Key: 4568577 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05458 - * Name: EL CAJON FORD Ph: 619-5798888 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2006 Doc #:04784741
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: PROGRAM INSTALL LABEL AND IF NECESSARY, REMOVE FLUID
1FMSU43P65ED44600 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-JUL-2005 16-AUG-2005 171079 USA 9 7D05 170104 6C3Z 15200 BA L26 42 5368
AWS Claim Key: 4568578 Trx Code: 2 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 05458 - * Name: EL CAJON FORD Ph: 619-5798888 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2006 Doc #:04784752
Cust Comments: FOG LIGHT INOP
Tech Comments: FOG LAMP BODY CHASSIS ELECTRICAL (BCE) TEST
1FMSU43P65ED44600 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-JUL-2005 16-AUG-2005 171079 USA 9 7D07 1702XX C2AZ 13466 C L26 46 5368
AWS Claim Key: 4568580 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05458 - * Name: EL CAJON FORD Ph: 619-5798888 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-MAY-2006 Doc #:04784754
Cust Comments: LIC PLATE LIGHT OUT
Tech Comments: BULB BULBS EXTERIOR REPLACE
1FMSU43P65ED44600 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-JUL-2005 16-AUG-2005 171079 USA 32 7D07 17XXXX XL3Z 13466 AA L26 46 18120
AWS Claim Key: 9644337 Trx Code: E83 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 05458 - * Name: EL CAJON FORD Ph: 619-5798888 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:01-APR-2008 Doc #:09420251
Cust Comments: FOG LAMP DOES NOT WORK
Tech Comments: PINPOINT TEST FOR POWER AND GROUND, OK. REPLACE BULB AND RETEST. CONFIRM REPAIR
1FMSU43P65ED44600 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-JUL-2005 16-AUG-2005 171079 USA 57 1D01 03XXXX 5C3Z 6710 AA L65 42 27872
AWS Claim Key: 11466083 Trx Code: E72 Labor Hrs: 15.9
Dlr Cd-Sub Cd: 05458 - * Name: EL CAJON FORD Ph: 619-5798888 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:17-APR-2010 Doc #:04476151
Cust Comments: CUSTOMER STATES THERE IS A ENGINE OIL LEAK.....PLEASE ADVISE
Tech Comments: INSPECT VEHICLE AND VERIFIED CUSTOMER CONCERN. FOUND ENGINE LEAKING AT BED PLATE SEAL. REMOVED ENGINE AND RESEALED BED PLATE. INSTALLED NEW TYPE REAR MAIN SEAL AND CLEANED CAC TUBES. REASSEMBLED AND RETESTED, ALL CHECKS OK.
1FMSU43P65ED44600 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-JUL-2005 16-AUG-2005 171079 USA 63 2H01 03XXXX * 6K682 * E29 42 28954
AWS Claim Key: 11617481 Trx Code: S07 Labor Hrs: 5.1
Dlr Cd-Sub Cd: 05458 - * Name: EL CAJON FORD Ph: 619-5798888 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:25-SEP-2010 Doc #:05316651
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT IS ON
Tech Comments: DIAGNOSE DIESEL ENGINE PERFORMANCE AND CHECK CODE PO299. FOUND TSB 09 16 05. CHECK VGT STUCK. REMOVE AND INSPECT TURBO, FOUND UNISON RING FROZEN TO CENTER HOUSING. CLEAN UNISON RING AND REPLACE CHRA. CHECK, OK.
