Just for your info Vin's that start in 3 are trucks built in Mexico. 1's are built in Kentucky
OASIS RESULT:
3FTNW21F22MA21225
09/17/2006
23:42:25
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2002 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
02/12/2002 BUILD DATE
11/29/2001 SALE MILEAGE
00155
WARNING MESSAGES
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 3FTNW21F22MA21225
Standard Claims List For Model Year 2002
3FTNW21F22MA21225 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 29-NOV-2001 12-FEB-2002 152246 USA 0 * * * * * * * 24
AWS Claim Key: 394758 Trx Code: TDM Labor Hrs: 0
Dlr Cd-Sub Cd: 04410 - * Name: NORTHSIDE FORD Ph: 210-5259800 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:11-DEC-2001 Doc #:66029101
Cust Comments: MISSING KEYLESS REMOTES
Tech Comments: KEYLESS REMOTES MISSING FROM DELIVERY
3FTNW21F22MA21225 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 29-NOV-2001 12-FEB-2002 152246 USA 8 5A06 0502XX F81Z 4026 BA L86 42 23969
AWS Claim Key: 2863313 Trx Code: E84 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 04485 - * Name: LEONARD KOVAR FORD COMPANY Ph: 361-5761221 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2002 Doc #:143457A
Cust Comments: CHECK FOR A REAL BAD VIB WHEN UNDER A LOAD AND PULLING TRAILER C MITCH
Tech Comments: 23969 REAR END CLUTCHES WAR CK AND REPLACE LOCKING CARRIER FOR REAR END
3FTNW21F22MA21225 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 29-NOV-2001 12-FEB-2002 152246 USA 8 5B04 050306 1C3Z 3B396 CB N58 42 23969
AWS Claim Key: 2704157 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04485 - * Name: LEONARD KOVAR FORD COMPANY Ph: 361-5761221 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2002 Doc #:143457B
Cust Comments: CHECK FOR A POPING NOISE WHEN TURNING THE STEERING WHEEL IN THE FRONT OF THE VEH
Tech Comments: 23969 HUBS NOT LOCKING IN RIGHT WAR CK AND REPLACE BOTH LOCKING HUBS RIGHT 1 TIGHT
3FTNW21F22MA21225 T/F7 F T/BC T/BD T/E A2 T/D8 T/DS 29-NOV-2001 12-FEB-2002 152246 USA 8 5R01 110401 * 3D677 * N58 42 23969
AWS Claim Key: 2704158 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04485 - * Name: LEONARD KOVAR FORD COMPANY Ph: 361-5761221 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-SEP-2002 Doc #:143457C
Cust Comments: CHECK FOR A RUBBING NOISE IN THE STEER WHEEL WHEN TURNING THE STEERING WEEL
Tech Comments: 23969 RUBBER DRY WAR CK AND LUBE RUBBER WHERE STEERING SHAFT GOES THROUGH FIRE WALL
OASIS RESULT:
1FTNX20F1YEB37514
09/17/2006
23:45:56
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 F-SERIES BODY STYLE
F-250 SUPER CAB 4X2 ENGINE
7.3L TURBO - DI
TRANSMISSION
ZF M6HD-C 6-SPEED AXLE CODE
ENGINE CALIBRATION
WARRANTY START DATE
08/09/2001 BUILD DATE
11/12/1999 SALE MILEAGE
00027
WARNING MESSAGES
EXTENDED COVERAGES
REPAIR HISTORY
04/15/2006
DEALER: Wichita Falls Ford Lincoln Mer
WARRANTY CLAIM NUMBER: 055808 ODOMETER: 074321M
LABOR OP
CONDITION CODE
CONDITION DESC
F81Z 8501FA PUMP ASY WATER 001 8005D D8 FAILED GASKET/SEAL
F6TZ 8575AA THERMOSTAT 001 8575B
VC 5 003 8501A
VC 8 MOTORCRAFT BATTERY 001
CHECK COOLANT LEAK PRESSURE TEST COOLING SYST
END OF OASIS REPORT FOR 1FTNX20F1YEB37514
Standard Claims List For Model Year 2000
1FTNX20F1YEB37514 T/F7 F T/BD T/BD T/B A1 T/VF T/DS 12-NOV-1999 09-AUG-2001 172203 USA 29 1B01 030205 * 6666 * L65 D1 33729
AWS Claim Key: 22011469 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 07708 - * Name: WINDWARD FORD Ph: 808-2667000 St:HI Ctry Cd: USA Reg Cd: NA Repr Date:29-NOV-2003 Doc #:01678051
Cust Comments: CUSTOMER RPTS CAR LOST OIL WHILE DRIVING AND THEN DIED CK AND RPT
Tech Comments: VERIFIED LEAKING HIGH PRESSURE PLTIGHTENED PLUG, RECHECKED FOR LEAKS OK, ROAD TESTED & RETESTED
1FTNX20F1YEB37514 T/F7 F T/BD T/BD T/B A1 T/VF T/DS 12-NOV-1999 09-AUG-2001 172203 USA 45 1G02 030008 F81Z 8501 FA L85 D8 53540
AWS Claim Key: 24133962 Trx Code: E72 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 04181 - * Name: WICHITA FALLS FORD LINCOLN MERCURY Ph: 940-6921121 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-MAR-2005 Doc #:03963851
Cust Comments: CHECK FOR WATER LEAKING FROM FRONT OF ENGINE
Tech Comments: CHECK WATER LEAK AT FRT ENGINE COOLING SYST PRESSURE TEST
1FTNX20F1YEB37514 T/F7 F T/BD T/BD T/B A1 T/VF T/DS 12-NOV-1999 09-AUG-2001 172203 USA 58 1G02 030008 F81Z 8501 FA L87 D8 74321
AWS Claim Key: 25292716 Trx Code: E72 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 04181 - * Name: WICHITA FALLS FORD LINCOLN MERCURY Ph: 940-6921121 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:15-APR-2006 Doc #:05580851
Cust Comments: CUSTOMER STATES LEAKING ANTIFREEZE FROM ENGINE CHECK AND ADVISE
Tech Comments: CHECK COOLANT LEAK PRESSURE TEST COOLING SYST
OASIS RESULT:
1FTSX30L91EC13534
09/17/2006
23:47:07
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 F-SERIES BODY STYLE
F-350 SUPER CAB 4X2 ENGINE
5.4L SOHC EFI
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
ENGINE CALIBRATION
1F714N0A
WARRANTY START DATE
02/20/2001 BUILD DATE
02/03/2001 SALE MILEAGE
WARNING MESSAGES
05S28
SPEED CONTROL SYSTEM MODIFICATION
EXTENDED COVERAGES
REPAIR HISTORY
END OF OASIS REPORT FOR 1FTSX30L91EC13534
