Standard Claims List For Model Year 2006
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 10 5A09 0502XX E8TZ 4676 B L88 D8 27378
AWS Claim Key: 1673712 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2006 Doc #:12966701
Cust Comments: CK FOR REAR PINION SEAL LEAKING, SEEMS TO LEAK AFTER TOWING
Tech Comments: VERIFIED CONCERN. REPLACED LEAKING REAR PINION SEAL. FOUND VENT FOR REAR DIFF PLUGGED. CLEANED VENT LINE WITH AIR. ROAD TEST.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 10 2H02 030008 * 6F089 * E29 42 27378
AWS Claim Key: 1673713 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2006 Doc #:12966702
Cust Comments: CK ENGINE LIGHT IS ON, VEH HAS FLUTTER FROM ENGINE
Tech Comments: VERIFIED CONCERN. EEC TEST. PULLED CODE. REMOVED TURBO & CLEANED PER TSB. CLEAR CODE, RESET KAM. POST ROAD TEST.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 10 6H11 010702 F81Z 28253A24 AA T53 33 27378
AWS Claim Key: 1673715 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2006 Doc #:12966709
Cust Comments: CKFOR LOWER SEAL ON DRIVER QUAD DOOR COMING LOOSE
Tech Comments: VERIFIED CONCERN. REPLACED WEATHERSTRIP DUE TO FALLING OFF.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 10 6N04 010802 5C3Z 16720 SA B62 81 27378
AWS Claim Key: 1673716 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2006 Doc #:12966714
Cust Comments: CK FOR F350 BADGES PEELING
Tech Comments: VERIFIED CONCERN. REPLACED BOTH PEELING EMBLEMS
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 10 7S20 180103 * 14A107 * H19 42 27378
AWS Claim Key: 1673714 Trx Code: E83 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2006 Doc #:12966703
Cust Comments: CK FOR ABS LIGHT BEING ON
Tech Comments: VERIFIED CONCERN. TESTED ABS SYSTEM. REPLACED REAR SPEED SENSOR & WIRE HARNESS PER TSB.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 10 6A15 011803 5C3Z 25290D12 BAB B63 33 27428
AWS Claim Key: 1692157 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:05-SEP-2006 Doc #:31328901
Cust Comments: RH CAB & BOX SIDE STRIPES ARE COMING OFF
Tech Comments: VERIFIED CONCERN. REPLACED PEELING STRIPES ON RH BOX SIDE & CAB.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 14 5R88 000615 * NPF * C50 82 35550
AWS Claim Key: 2662091 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2007 Doc #:13899602
Cust Comments: WHEN HIT BUMPS, STEERING WHEEL SHIMMIES VIOLENTLY
Tech Comments: PERFORMED TSB, CHECKED ALL TIRE PRESSURES, SET TO 65 IN FRONT & 75 IN REAR.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 14 2E03 030008 * 9E527 * D13 42 35550
AWS Claim Key: 2662090 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2007 Doc #:13899601
Cust Comments: ON COLD START, ENG RUNS ROUGH
Tech Comments: VERIFIED CONCERN. REPROGRAMMED PCM & FICM AS PER TSB.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 14 5T03 110402 6C3Z 7210 CA B95 42 35550
AWS Claim Key: 2740492 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2007 Doc #:13899606
Cust Comments: CK FOR SHIFTER BOOT TEARING
Tech Comments: VERIFIED CONCERN. REMOVED & REPLACED SHIFTER LEVER. RETEST.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 14 6C05 010506 5C3Z 2827407 AAA B43 33 35550
AWS Claim Key: 2662092 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:08-JAN-2007 Doc #:13899603
Cust Comments: CK FOR DRIVER REAR DOOR TRIM PANEL COMING LOOSE
Tech Comments: VERIFIED CONCERN. REPLACED THE DOOR PANEL.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 15 6A15 011803 5C3Z 25290D13 BAB B63 33 35560
AWS Claim Key: 2812155 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:31443001
Cust Comments: LEFT REAR BOX SIDE STRIPES ARE COMING OFF
Tech Comments: VERIFIED CONCERN. REPLACED PEELING STRIPE.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 16 2H02 030008 * 6F089 * E29 42 39914
AWS Claim Key: 3121150 Trx Code: S07 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:12-FEB-2007 Doc #:14133002
Cust Comments: MIL IS ON, VEH RUNS FINE. FUEL ECONOMY HAS DROPPED
Tech Comments: VERIFIED CONCERN. EEC TEST. REPROGRAMMED PCM TO LATEST CALIBRATION. PINPOINT TEST. REMOVED TURBO & PERFORMED CLEANING PROCEDURE. CLEARED CODES, RESET KAM. ROAD TEST. STILL HAD CODE. REPLACED EBP SENSOR & POST ROAD TEST.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 16 2A01 031202 6C3Z 6C640 A L65 42 39914
AWS Claim Key: 3121151 Trx Code: S07 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:12-FEB-2007 Doc #:14133003
Cust Comments: CK FOR INTERCOOLER TUBE ON RH SIDE LEAKING OIL
Tech Comments: FOUND HOT SIDE CAC TUBE LEAKING. REPLACED TUBE.
1FTWX31P86EB53787 T/F7 F T/BD T/CD T/E A1 T/BE T/YB 06-OCT-2005 16-NOV-2005 153507 USA 17 7S20 031406 6E7Z 14S411 A D42 X2 43859
AWS Claim Key: 3241314 Trx Code: E81 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 03423 - * Name: WOODHOUSE FORD, INC. Ph: 402-4264126 St:NE Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2007 Doc #:14459703
Cust Comments: CK FOR VEH HAVING NO POWER
Tech Comments: VERIFIED CONCERN. PERFORMED DIESEL DIAGNOSIS. FOUND POOR CONNECTION AT VGT SOLENOID. REPLACED VGT CONNECTOR.
Reactions: adamfre
