I have had my truck in the shop several (about 4) times over the last few months and it is getting worse not better. I think I should look at a report and see what they are doing to it.
My VIN# is 1FTSW21P05EA41320
Thanks,
OASIS RESULT:
1FTSW21P05EA41320
03/18/2007
19:52:12
FCXWS45
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING HIGH PRESS. PUMP FOR HARD START OR OIL LEAK, SEE TSB 06-17-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
06/18/2005 BUILD DATE
08/18/2004 SALE MILEAGE
05920
59B01
ELIGIBLE FOR ONE-TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIONS RECALL 05E15 OR 06E17 FOR DETAILS.
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
02/14/2007
DEALER: Timberland Ford
WARRANTY CLAIM NUMBER: 051584 ODOMETER: 023533M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682BA TURBO CHG-EXH DRIVE 001 062302A 42 DOES NOT OPERATE PROPERLY
FOLLOW PINPOINT TEST IN PCED MANUAL REMOVE TURBO AND INSPECT ROATEST AND MON ITOR PIDS VGTDC85% MGP 19PSI EGRVP EXTREMELY CHOPPY EBPA 17 PSI PERFORM TSB 06 23 02 DISASSEMBLE TURBO RUST PRESENT IN DRAIN CASE REPLACE TURBO PER TSB
01/05/2007
WARRANTY CLAIM NUMBER: 051036 ODOMETER: 022352M
LABOR OP
CONDITION CODE
CONDITION DESC
6C3Z 9F759A WIRE ASY FUEL VAPOR 001 062212B 42 DOES NOT OPERATE PROPERLY
6C3Z 9B249A HEADER-FUEL FILTER 001
DIAG VEHICLE AND VERIFY CONCERN WATER IN FUEL LIGHT IS ON PER TSB 06-22-12 REMOVE AND REPLACE WIF SENSOR DISSASSEMBLE AND CLEAN HFCM CK DTCS AND REPRO GRAM MODULE
01/05/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E527 NOZZLE ASY-FUEL INJE 000 062203A 42 DOES NOT OPERATE PROPERLY
DIAG VEHICLE AND VERIFY HARD STARTS COLD RUN OASIS AND VERIF Y TSB 06-22-03 PER TSB REPROGRAM THE FICM AND ROADTEST
END OF OASIS REPORT FOR 1FTSW21P05EA41320
Thanks for the info.
My dealer is still having troible getting it figured out but they haven't given up yet. It's going back in next week to try again.
