I'm hoping to be getting a 2005 F250 PSD so I can become a long time member here and lean a lot about this truck!
Vin#: 1FTSW21P85EC47954
Thanks so much.
OASIS RESULT:
1FTSW21P85EC47954
02/19/2008
22:09:22
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
3L ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 08-03-07
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 08-04-07
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/14/2005 BUILD DATE
02/23/2005 SALE MILEAGE
05B32
DE-GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
01/14/2008
DEALER: Wayne Akers Ford, Inc.
WARRANTY CLAIM NUMBER: 404705 ODOMETER: 091060M
LABOR OP
CONDITION CODE
CONDITION DESC
TAP5 RENTAL - LINC 000 82 FREIGHT/POSTAGE/MAINTENANCE
ENTERPRISE TAP LOANER
11/01/2007
WARRANTY CLAIM NUMBER: 399026 ODOMETER: 087282M
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9P456AF COOLER - EGR 001 8005D 42 DOES NOT OPERATE PROPERLY
3C3Z 6A642AA COOLER CRANKCASE OI 001 8100A
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 072109A
3C3Z 6C683AA FLTER-ENG OIL 001 6642A
F6DZ 8100A CAP ASY RADIATOR 001
VC 7B 002
87282 OIL COOLER AND EGR COOLER AND VALVE W 4707 PERFORM COOLANT PRESSURE T EST FOUND EGR COOLER LEAKI. OIL COOLER DAMAGE EGR OIL AND COOLANT TEMPERAT URE 25 F OUT SPECIFIED RANGE REPLACE OIL COOLER AND EGR COOLER AND LEAKING RADIATOR CAP REFILL AND ROADTEST AFTER ROAD TEST ENGINE SURGE PERFORM TSB 07-21-09 REPLACE EGR VALVE INCLUDES CLEAR CODE OPERATION 072109A RETEST OK
11/01/2007
LABOR OP
CONDITION CODE
CONDITION DESC
TAP3 RENTAL - LINC LESS S 000 82 FREIGHT/POSTAGE/MAINTENANCE
ENTERPRISE TAP LOANER DAYS
08/17/2007
WARRANTY CLAIM NUMBER: 392547 ODOMETER: 080051M
LABOR OP
CONDITION CODE
CONDITION DESC
VC 7B 002 8005D 42 DOES NOT OPERATE PROPERLY
VC 8 MOTORCRAFT BATTERY 001 8100A
4C3Z 9P456AF COOLER - EGR 001 9456A
F6DZ 8100A CAP ASY RADIATOR 001 8080A
5C3Z 9F452AA TRANSDCR-EGR BACK PR 001 061906C
6C3Z 8A080B COOLANT O/FLO BOTTLE 001
80051 EGR VALVE AND COOLER, OVERFLOW TANK AND CAP W 4707 PERFORM COOLING PRE SSURE TEST FOUND LEAK COMING FROM EGR COOLER AND TANK REPLACE EGR COOLER , C RAKED OVERFLOW TANK AND CAP RETEST OK AFTER ROAD TEST ENGINE LIGH ON P1335 A ND P0401 PERFORM NORMAL DIAG PERFORM TSB..06-19-06.... EGR CLEANING PROCEDUR E OPERATION 061906C .... REPLACE FAILED EGR VALVE RETEST OK AT THIS TIME
04/18/2007
DEALER: Advantage Ford of Stuart
WARRANTY CLAIM NUMBER: 023264 ODOMETER: 070682M
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9C407AB PUMP&ISOLATOR-FUEL E 001 9350E 42 DOES NOT OPERATE PROPERLY
000 9002A
WEAK FUEL PUMP 42 TAKE MANUAL FUEL PRESSURE 35 PSI TO LOW REPLACE FUEL OP UMP
| On-line 1878
END OF OASIS REPORT FOR 1FTSW21P85EC47954
Standard Claims List For Model Year 2005
1FTSW21P85EC47954 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2005 14-JUL-2005 124216 USA 9 7S01 1801XX * 13A576 * L29 46 29038
AWS Claim Key: 4142998 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 04879 - * Name: WAYNE AKERS FORD, INC. Ph: 561-5824444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:349621D
Cust Comments: L29 CUYST STATES TRAILER LIGHTS INOP CHECK
Tech Comments: 29038 SERV W 6541 INSPECTED VEHICLE FOR TRAILER LIGHTS INOP FOUND THAT CUSTOMER HAD BLOWN FUSE THAT NEEDED REPLACED REPLACED FUSE AND RETESTED TRAILER LIGHTING TO ENSURE THAT THEY WORK PROPERLY VEHICLE OK AT THIS TIME
1FTSW21P85EC47954 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2005 14-JUL-2005 124216 USA 9 * * * * * * * 29038
AWS Claim Key: 4142999 Trx Code: 05B35 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 04879 - * Name: WAYNE AKERS FORD, INC. Ph: 561-5824444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:27-MAR-2006 Doc #:349621E
Cust Comments: 05B35 CUSTOMER SATISFATION PROGRAM 2005 2006 F250 350 450 550 AND EXCUSRION AND E350 450 VEHICLES ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: 29038 W 6541 PERFORMED RECALL O5B35 REPROGRAMMED PCM WITH UPDATED SOFTWARE
1FTSW21P85EC47954 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2005 14-JUL-2005 124216 USA 22 2E06 100106 3C3Z 9C407 AB D50 42 70682
AWS Claim Key: 7613634 Trx Code: E72 Labor Hrs: 2
Dlr Cd-Sub Cd: 04839 - * Name: ADVANTAGE FORD OF STUART Ph: 772-2870955 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:18-APR-2007 Doc #:02326403
Cust Comments: WONT CRANK
Tech Comments: WEAK FUEL PUMP 42 TAKE MANUAL FUEL PRESSURE 35 PSI TO LOW REPLACE FUEL OPUMP
1FTSW21P85EC47954 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2005 14-JUL-2005 124216 USA 26 1H03 030008 5C3Z 9F452 AA E29 42 80051
AWS Claim Key: 8468669 Trx Code: S07 Labor Hrs: 8.6
Dlr Cd-Sub Cd: 04879 - * Name: WAYNE AKERS FORD, INC. Ph: 561-5824444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:17-AUG-2007 Doc #:392547A
Cust Comments: E29 CUST STATES THAT COOLANT RESV KEEPS GOING LOW AND VEH BLOWING WHITE SOKE
Tech Comments: 80051 EGR VALVE AND COOLER, OVERFLOW TANK AND CAP W 4707 PERFORM COOLING PRESSURE TEST FOUND LEAK COMING FROM EGR COOLER AND TANK REPLACE EGR COOLER , CRAKED OVERFLOW TANK AND CAP RETEST OK AFTER ROAD TEST ENGINE LIGH ON P1335 AND P0401 PERFORM NORMAL DIAG PERFORM TSB..06 19 06.... EGR CLEANING PROCEDURE OPERATION 061906C .... REPLACE FAILED EGR VALVE RETEST OK AT THIS TIME
1FTSW21P85EC47954 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2005 14-JUL-2005 124216 USA 29 1H03 030804 4C3Z 9P456 AF D50 42 87282
AWS Claim Key: 9104155 Trx Code: S07 Labor Hrs: 7.1
Dlr Cd-Sub Cd: 04879 - * Name: WAYNE AKERS FORD, INC. Ph: 561-5824444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-NOV-2007 Doc #:399026A
Cust Comments: D50 CUST STATES THAT VEH COOLANT BOTTLE STILL GOING EMPTY
Tech Comments: 87282 OIL COOLER AND EGR COOLER AND VALVE W 4707 PERFORM COOLANT PRESSURE TEST FOUND EGR COOLER LEAKI. OIL COOLER DAMAGE EGR OIL AND COOLANT TEMPERATURE 25 F OUT SPECIFIED RANGE REPLACE OIL COOLER AND EGR COOLER AND LEAKING RADIATOR CAP REFILL AND ROADTEST AFTER ROAD TEST ENGINE SURGE PERFORM TSB 07 21 09 REPLACE EGR VALVE INCLUDES CLEAR CODE OPERATION 072109A RETEST OK
1FTSW21P85EC47954 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2005 14-JUL-2005 124216 USA 29 6Y20 000000 * TAP3 * A98 82 87282
AWS Claim Key: 9111481 Trx Code: TAP3 Labor Hrs: 0
Dlr Cd-Sub Cd: 04879 - * Name: WAYNE AKERS FORD, INC. Ph: 561-5824444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:01-NOV-2007 Doc #:399026C
Cust Comments: CUST STATES HE WILL BE IN NEED OF A RENTAL WHILE HIS VEHICLE IS IN THE SHOP
Tech Comments: ENTERPRISE TAP LOANER DAYS
1FTSW21P85EC47954 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-FEB-2005 14-JUL-2005 124216 USA 31 6Y20 000000 * TAP5 * A98 82 91060
AWS Claim Key: 9319638 Trx Code: TAP5 Labor Hrs: 0
Dlr Cd-Sub Cd: 04879 - * Name: WAYNE AKERS FORD, INC. Ph: 561-5824444 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:14-JAN-2008 Doc #:404705D
Cust Comments: LOANER VEHICLE GET YOUR RECEIPT
